KVL rlc circuit
  1. Apr 7, 2015 #1
    Obtain the voltage Vx in the network of Fig.Q11, using the mesh current method.
    (Ans: Vx=4.35∠-194.5)
    2. Relevant equations
    3. The attempt at a solution
    I am not getting the correct answer, are my loop equations correct ?
    10 - 2*i1 + 2j*i1 -5j(i1+i2) -5(i1+i3) = 0
    4.33 + 2.5j - 10*i2 -5j(i1+i2) +2(i3-i2) -2j(i3-i2) = 0
    -10*i3 + 2j(i3-i2) -2(i3-i2) -5(i1+i3) = 0
    Therefore,
    i1(-7-3j) + i2(-5j) -5*i3 = -10........................(1)
    i1(-5j) + i2(-12-3j) + i3(2-2j) = -4.33-2.5j.....................(2)
    -5*i1 + i2(2-2j) + i3(-17+2j) = 0....................................(3)
  3. Apr 7, 2015 #2
    berkeman
    Staff: Mentor
    Some of the signs in the 2nd equation look wrong to me (but it's been a while since I used KVL -- I usually use KCL).
    Can you talk through why you chose the signs that you did for the 2nd equation?
  4. Apr 7, 2015 #3
    Okay, I have labeled the currents in my diagram
    4.33+2.5j, That's the voltage of the source in the second loop in complex form (Voltage rise so it's positive)
    -10*i2, Voltage drop across the resistor, hence negative sign
    -5j(i1+i2), Voltage drop across the inductor, negative sign
    +2(i3-i2), Positive sign because the loop is traveling opposite to the current direction as labeled
    -2j(i3-i2), Because impedance is negative for a capacitor and loop is travelling opposite in direction to current, so +*- = - sign
  5. Apr 8, 2015 #4
    NascentOxygen
    Staff: Mentor
    One of the difficulties is that we are not told which terminal of each source is (+) and which is (-), i.e., which is the reference terminal.
    Perhaps assume the marked current is indicative of the source polarity, though I don't know whether we can generalize that to other problems like this. :oldconfused:
    I do get the same equations as you, though haven't checked them.
    Perhaps reverse the voltage source in the second loop, and see whether you get the book's answer that way?
  6. Apr 8, 2015 #5
    I tried reversing it but still get the same answer, maybe im solving it wrong so here are my steps. I used crammers rule
    Determinant,
    7+3j ...........5j................5
    5j................12+3j...........-2+2j
    5.................-2+2j............17-2j
    Solving that I get, -73+405j
    Then for i3,
    7+3j............5j...............10
    5j...............12+3j..........4.33+2.5j
    5................-2+2j...........0
    Solving that I get, -744.52-100.77j
    Therefore i3 = (-744.52-100.77j)/(-73+405j)
    = 0.08 + 1.82j
    So V = (0.08+1.82j)*10
    = 0.8 + 18.24j
    Or, 18.26∠87.49
Have something to add?
Draft saved Draft deleted
Similar Discussions: KVL rlc circuit
  1. Basic Circuit - KVL (Replies: 1)
  2. RLC circuit. (Replies: 1)
  3. RLC circuit (Replies: 3)
Loading...
