B KWh versus kW times Time
  1. Mar 16, 2017 #1
    Say I have a 60W device.
    I know running for one hour it uses 60 W x 3600 s = 216 kJ of energy.
    Does that mean it uses 216 kWh of energy?
    Or does kWh means 60 W x 1 hour = 60 kWh?
    I am confused because the units in 60 kWh is not in their simplified terms.
    More specifically, this pertains to a project that I am working on.
    From experimental values, I found that with X kg/s of water flowing through the heat exchanger and some temperature increase, I can find the power of the heat exchanger in kW.
    I would like to provide the values in BTU since that is just what people still use in the States.
    I realized BTU is an energy unit, not power, and 1 kWh = 3412 BTU.
    So I need to convert kW to kWh.
  3. Mar 16, 2017 #2
    davenn
    2017 Award
    you have a k in there that you shouldn't
    60 W x 1 hour = 60 Wh
    so going from what I wrote above
    a 1kW heater running for 1 hour = 1kWh
  4. Mar 16, 2017 #3
    Alright, thanks! I thought kWh is basically kJ. I guess kWh needs to convert by a factor of 3600 before it becomes kJ then.
  5. Mar 16, 2017 #4
    CWatters
    Yes that's possible/correct.
    I believe they actually use BTU/h (BTU per hour) but the "h" is sometimes omitted (bad practice).
    So you just need to use..
    1 kW = 3412 BTU/hr
  6. Mar 17, 2017 #5
    One thing worth remembering: a Joule is a Wattsecond.
    So 3600 J = 3600 W s = 1 W h = 0.001 kW h .
Have something to add?
Draft saved Draft deleted
Loading...
