ironcross77
- 21
Anyone has Matt Mcmohan's Labview program on measuring curie temparature. I here its free . but i cannot find it on the net
A Labview Curie Temperature VI is a virtual instrument (VI) created using the Labview programming language. It is used to measure the Curie temperature of a material, which is the temperature at which the material's magnetic properties change.
A Labview Curie Temperature VI works by sending a small current through a sample of the material and measuring its magnetic response at different temperatures. The VI then plots this data and calculates the Curie temperature based on the inflection point of the curve.
A Labview Curie Temperature VI can be used to test any material with magnetic properties, such as ferromagnetic, antiferromagnetic, or paramagnetic materials. These can include metals, alloys, and certain types of ceramics.
No, a Labview Curie Temperature VI is specifically designed to measure the Curie temperature of a material. Other material properties, such as thermal conductivity or specific heat, require different instruments and methods for measurement.
Yes, a Labview Curie Temperature VI requires a Labview software package and a compatible data acquisition device, such as a multimeter or oscilloscope. The specific equipment needed may vary depending on the setup and the material being tested.
