Ladder - Equilibrium
  1. Nov 2, 2008 #1
    http://img206.imageshack.us/img206/8178/ladderjt1.png [Broken]
    A uniform 5.0-kg ladder is leaning against a frictionless vertical wall, with which it makes a 15* angle. The coefficient of friction between ladder and ground is 0.26. Can a 65-kg person climb to the top of the ladder without it slipping? If not, how high can the person climb? If so, how massive a person would make the ladder slip?
    2. Relevant equations
    [tex]
    \begin{gathered}
    \sum {\vec \tau } = \vec 0 \hfill \\
    \sum {\vec F} = \vec 0 \hfill \\
    \end{gathered}
    [/tex]
    3. The attempt at a solution
    So, I choose the end of ladder that is touching the floor to be the axis. Now I want to find the sum of the torques, then set them equal to zero. What I don't quite get in the equation is the sin(90-15) in the first term in the following equation my professor gave me:
    [tex]
    F_W L\sin (90^ \circ - 15^ \circ ) - M_p gL\sin (15^ \circ ) - M_L g\frac{L}
    {2}\sin (15^ \circ ) = 0
    [/tex]
    sin(90-15)? Technically, it should be the angle between the r and F....but this doesn't make sense to me....or perhaps 15* is meant to be the other angle in the triangle?
    If anyone can help, it would be greatly appreciated. Thank you!
  3. Nov 3, 2008 #2
    alphysicist
    Hi RedBarchetta,
    Yes, it's the other angle; the ladder makes a 15 degree angle with the wall, so the angle with the floor is 75 degrees. Once you correct your diagram, do you see why the angles your professor chose are correct?
