Lagrange Interpolation
  1. Apr 21, 2006 #1
    In my comp physics class, we've been introduced to both c++ and fortran languages. For instance, for our first assignment, I am not sure how to go about investigating the quality of interpolation points for i.e f(x)=sin(x^2) by using n-point langrange interpolation, where n is an input parameter. On paper, I've already calculated P(x) (lagrange) for 10 points in the interval [0,5]. But, how should I start writing the program?
  3. Apr 22, 2006 #2
    -Job-
    Are you given the points or are you allowed to obtain the points with some strategy? If you have n points, then computing the Lagrange coefficients and interpolating polynomial, f(x), is not very hard. Mostly you should just follow the mathematical expression for the Lagrange coefficients. From what i remember if you have 3 points (x1,y1), (x2,y2), (x3,y3), then you will have 3 lagrange coefficients.
    [tex]Lg_{1} = \frac{(x-x_{2})(x-x_{3})}{(x_{1}-x_{2})(x_{1}-x_{3})}[/tex]
    [tex]Lg_{2} = \frac{(x-x_{1})(x-x_{3})}{(x_{2}-x_{1})(x_{2}-x_{3})}[/tex]
    [tex]Lg_{3} = \frac{(x-x_{1})(x-x_{2})}{(x_{3}-x_{1})(x_{3}-x_{2})}[/tex]
    Finally your f(x) is given by:
    [tex]
    f(x) = Lg_{1}*y_{1}+Lg_{2}*y_{2}+Lg_{3}*y_{3}
    [/tex]
    Basically the idea is straightforward. For each point you have a corresponding coefficient. So you should loop through all points. For each point's coefficient you need to consider all the other points, so you need to loop through those as well. Basically two for loops will do it. There are ways to optimize your algorithm so that it doesn't perform repeated subtractions.
    The following algorithm should give you the general idea (performs in O(n^2) steps):
    Code (Text):
    int n //number of points
    double xcoords = {x0, x1, x2... x(n-1)}; //the x coordinates of our n points
    double ycoords = {y0, y1, y2...y(n-1)}; //the y coordinates of our n points
    double xin; //the x whose f(x) we wish to compute
    double fx = 0;//the value of f(x)
    for(i=0; i<n; i++){
       double Lg = 1;
       for(j=0; j<n; j++){
          if(i != j){
             Lg *= (xin-xcoords[j])/(xcoords[i]-xcoords[j]);
       fx += Lg*ycoords[i];
  4. Apr 23, 2006 #3
    Thanks for your help. Just to confirm, the program says
    Write a program that implemets n-point Lagrange interpolation. Trean n as an input parameter. Apply the program to study the quality of the Lagrange interpolation to function f(x)=sin(x2) initially calculated in 10 uniform points in the interval [0.0, 5.0].
    So, does this mean that the user can select the n?
  5. Apr 23, 2006 #4
    -Job-
    Yes, that seems to be the case. You're given the function that you want to model with the interpolation polynomial, [tex]f(x)=sin(x^{2})[/tex]. Apparently you should start with n = 10, and allow the user to enter a larger value for n. Keep in my mind that the value of n includes the endpoints. So for n=10 you have the points x=0, x=5/(10-1), x=2*5/(10-1), x=3*5/(10-1), x=4*5/(10-1), x=5*5/(10-1)... x=(10-1)*5/(10-1)
    Basically, the x coordinate of the ith point ([tex]0 \leq i \leq n-1[/tex]) is given by:
    [tex]i*\frac{5}{n-1}[/tex]
    Then with the x coordinate you get the y coordinate using [tex]f(x)=sin(x^{2})[/tex] and you have your point. I would create a function getIthPoint(i, n) to make your life easier. This way you don't need arrays.
    Make sure to go over this in case i made a mistake.
  6. Apr 24, 2006 #5
    Hi, I have sort of worked on the code, but I am not getting it work. What am I doing wrong?
  7. Apr 24, 2006 #6
    Integral
    Staff Emeritus
    Where do you assign a value to xx(i)? You may want to evaluate you polynomial at many points in your interval (many ~ 100) at the same time you can compute the exact value. Your final print out would be, the interpolated value, the exact value and the difference. This would satisfy the "investigate" part of the problem.
    You could also try different interpolation points, both different number and different spacings. (more in fast changing areas, fewer in the slower changing areas etc)
  8. Apr 24, 2006 #7
    -Job-
    From a quick look at your code i see that your f(x) seems to be different. In your code you used:
    Code (Text):
    y[i]=sin(x[i]*2);
    However, in your initial post you mentioned that your f(x) was:
  9. Apr 24, 2006 #8
    Sorry, that was a mistake. It is supposed to be sin(x^2), but does everything else seem okay? I am not sure if xx should be 1,2,3... etc...
  10. Apr 25, 2006 #9
    Integral
    Staff Emeritus
    Your xx(i) should be much closer together then your interpolation points. You want to see how well the polynomial interpolation matches the original function, you must compute it at points away from your interpolating points. Take steps in the range of [itex] 2^ {-5}[/itex] to [itex] 2^{-8}[/itex]
  11. Apr 25, 2006 #10
    -Job-
    I did a quick c++ program with the code i posted previously, for testing:
    Code (Text):
    #include "stdafx.h"
    #include "math.h"
    #using <mscorlib.dll>
    using namespace System;
    double getY(double x){
        return sin(pow(x, 2));
    double interpolate(double xin, double n){
        double i, j;
        double fx = 0;
        for(i=0; i<n; i++){
            double Lg = 1;
            double ix = (double)i*5/(n-1);
            double iy = getY(ix);
            for(j=0; j<n; j++){
                if(i!=j){
                    double jx = (double)j*5/(n-1);
                    Lg *= (xin-jx)/(ix-jx);
            fx += Lg*iy;
        return fx;
    int _tmain()
        double x;
        for(x=0; x<=5; x+=0.05){
            Console::Write("x=");
            Console::Write(x);
            Console::Write("   f(x)=");
            Console::Write(getY(x));
            Console::Write("   P(x)=");
            Console::Write(interpolate(x, 100));
            Console::Write("\n");
        return 0;
    It's interesting that the above program correctly approximates the value of f(x) with P(x). However there are some values of x where P(x) is way off. I printed the approximations for various x's in the interval [0, 5] and from this data it seems that this behavior is caused by Runge's Phenomenon
    Here's the output (notice that P(x) is close to f(x)) for most values in [0, 5]. However in two areas near the endpoints it is way off, and increasing n causes it to be even farther off. This output was printed for n=100)
    Code (Text):
    x=0   f(x)=0   P(x)=0
    x=0.05   f(x)=0.00249999739583415   P(x)=4.7405971714772
    x=0.1   f(x)=0.00999983333416667   P(x)=7.32717058245029
    x=0.15   f(x)=0.0224981016105536   P(x)=8.35535776490926
    x=0.2   f(x)=0.0399893341866342   P(x)=8.30389975623207
    x=0.25   f(x)=0.0624593178423802   P(x)=7.55149792893023
    x=0.3   f(x)=0.089878549198011   P(x)=6.39189815050929
    x=0.35   f(x)=0.122193852192663   P(x)=5.04733241070067
    x=0.4   f(x)=0.159318206614246   P(x)=3.68044203885949
    x=0.45   f(x)=0.201118873846073   P(x)=2.40480075249365
    x=0.5   f(x)=0.247403959254523   P(x)=1.29415002869104
    x=0.55   f(x)=0.297907621896134   P(x)=0.390453673645189
    x=0.6   f(x)=0.35227423327509   P(x)=-0.289127018455357
    x=0.65   f(x)=0.410041898781764   P(x)=-0.746241477212139
    x=0.7   f(x)=0.470625888171158   P(x)=-0.996250617186627
    x=0.75   f(x)=0.53330267353602   P(x)=-1.06393441320525
    x=0.8   f(x)=0.597195441362392   P(x)=-0.979925507958984
    x=0.85   f(x)=0.661262123760472   P(x)=-0.777792890834096
    x=0.9   f(x)=0.724287174370143   P(x)=-0.491704375056283
    x=0.95   f(x)=0.784878485034067   P(x)=-0.15460115574461
    x=1   f(x)=0.841470984807897   P(x)=0.203177845645827
    x=1.05   f(x)=0.89233856416221   P(x)=0.554879854762585
    x=1.1   f(x)=0.935616001553386   P(x)=0.877984182326532
    x=1.15   f(x)=0.969332510867995   P(x)=1.15456004829728
    x=1.2   f(x)=0.991458348191687   P(x)=1.37138222153984
    x=1.25   f(x)=0.999965585678249   P(x)=1.51984664457424
    x=1.3   f(x)=0.992903651094118   P(x)=1.59572458589665
    x=1.35   f(x)=0.968489520283355   P(x)=1.59879036789899
    x=1.4   f(x)=0.925211520788168   P(x)=1.53235435658385
    x=1.45   f(x)=0.86194455517421   P(x)=1.40272967007313
    x=1.5   f(x)=0.77807319688792   P(x)=1.21865796634192
    x=1.55   f(x)=0.673617587361252   P(x)=0.990716706673673
    x=1.6   f(x)=0.549355436427125   P(x)=0.730727460028961
    x=1.65   f(x)=0.406931797351062   P(x)=0.451182114847959
    x=1.7   f(x)=0.24894678667315   P(x)=0.164701298765956
    x=1.75   f(x)=0.0790102167473866   P(x)=-0.116463126687781
    x=1.8   f(x)=-0.0982485937451118   P(x)=-0.380871930115067
    x=1.85   f(x)=-0.27722754488774   P(x)=-0.618281334851053
    x=1.9   f(x)=-0.451465752161427   P(x)=-0.819959441511353
    x=1.95   f(x)=-0.613833396107784   P(x)=-0.978932788734592
    x=2   f(x)=-0.756802495307931   P(x)=-1.09016136262222
    x=2.05   f(x)=-0.872798699517351   P(x)=-1.15064200299717
    x=2.1   f(x)=-0.954627771660217   P(x)=-1.15944165959111
    x=2.15   f(x)=-0.995962705156195   P(x)=-1.11766332362669
    x=2.2   f(x)=-0.991868757310913   P(x)=-1.02834869998609
    x=2.25   f(x)=-0.939334638675732   P(x)=-0.896322792250936
    x=2.3   f(x)=-0.837769480165098   P(x)=-0.727986547360243
    x=2.35   f(x)=-0.689418018619284   P(x)=-0.531064548463635
    x=2.4   f(x)=-0.499641883116905   P(x)=-0.31431545374582
    x=2.45   f(x)=-0.277014201809769   P(x)=-0.0872134555655052
    x=2.5   f(x)=-0.0331792165475613   P(x)=0.140390521812358
    x=2.55   f(x)=0.217560782359321   P(x)=0.35861885630802
    x=2.6   f(x)=0.458951486377685   P(x)=0.557919285686531
    x=2.65   f(x)=0.673781675524276   P(x)=0.729409734488984
    x=2.7   f(x)=0.845133411657213   P(x)=0.865206742529471
    x=2.75   f(x)=0.957819147348828   P(x)=0.958728546473952
    x=2.8   f(x)=0.999902258547975   P(x)=1.00496421787097
    x=2.85   f(x)=0.964165036726313   P(x)=1.00070074548939
    x=2.9   f(x)=0.849363378505475   P(x)=0.944700566935161
    x=2.95   f(x)=0.661095543640036   P(x)=0.837822804267547
    x=3   f(x)=0.412118485241771   P(x)=0.683082340715179
    x=3.05   f(x)=0.121973473857497   P(x)=0.485641890603811
    x=3.1   f(x)=-0.184164779400656   P(x)=0.252733362250751
    x=3.15   f(x)=-0.477425197790973   P(x)=-0.00649390614439077
    x=3.2   f(x)=-0.727877870349722   P(x)=-0.281199044676839
    x=3.25   f(x)=-0.907679875544638   P(x)=-0.559149145508065
    x=3.3   f(x)=-0.994432209303193   P(x)=-0.827090135588535
    x=3.35   f(x)=-0.97436266119118   P(x)=-1.07118500088798
    x=3.4   f(x)=-0.844895943776041   P(x)=-1.27751339125691
    x=3.45   f(x)=-0.616170006866291   P(x)=-1.43262455897897
    x=3.5   f(x)=-0.311119354981156   P(x)=-1.52413337537844
    x=3.55   f(x)=0.0361215260101955   P(x)=-1.54134682851958
    x=3.6   f(x)=0.383542755412577   P(x)=-1.47590593107628
    x=3.65   f(x)=0.686110730859183   P(x)=-1.32242536085987
    x=3.69999999999999   f(x)=0.901675770066375   P(x)=-1.07911041727123
    x=3.74999999999999   f(x)=0.997213718805396   P(x)=-0.748328005089993
    x=3.79999999999999   f(x)=0.954495430240934   P(x)=-0.337105352528581
    x=3.84999999999999   f(x)=0.774208286800343   P(x)=0.142472966637726
    x=3.89999999999999   f(x)=0.477637144914053   P(x)=0.673002406801439
    x=3.94999999999999   f(x)=0.105267874095546   P(x)=1.23166632243078
    x=3.99999999999999   f(x)=-0.287903316665018   P(x)=1.79035397548258
    x=4.04999999999999   f(x)=-0.640029556161847   P(x)=2.31603198329057
    x=4.09999999999999   f(x)=-0.892129364694352   P(x)=2.77141631217395
    x=4.14999999999999   f(x)=-0.998417846377416   P(x)=3.11599585491698
    x=4.19999999999999   f(x)=-0.935459140991685   P(x)=3.30746269580768
    x=4.24999999999999   f(x)=-0.708278021051184   P(x)=3.30360836509292
    x=4.29999999999999   f(x)=-0.35185858693223   P(x)=3.06474971550771
    x=4.34999999999999   f(x)=0.0728794083906834   P(x)=2.55675251696862
    x=4.39999999999999   f(x)=0.488564765772459   P(x)=1.75472546158502
    x=4.44999999999999   f(x)=0.815124497793637   P(x)=0.64746199983705
    x=4.49999999999999   f(x)=0.985525111565108   P(x)=-0.757287709903798
    x=4.54999999999999   f(x)=0.960459678867108   P(x)=-2.42662746237741
    x=4.59999999999999   f(x)=0.738706029703826   P(x)=-4.29531587423681
    x=4.64999999999999   f(x)=0.360355131767404   P(x)=-6.25745979870335
    x=4.69999999999999   f(x)=-0.0986905140096249   P(x)=-8.1569972322765
    x=4.74999999999999   f(x)=-0.540769321526501   P(x)=-9.77686113521475
    x=4.79999999999999   f(x)=-0.866851155826269   P(x)=-10.8267099303881
    x=4.84999999999999   f(x)=-0.999222150718628   P(x)=-10.9291046553546
    x=4.89999999999999   f(x)=-0.901291364088664   P(x)=-9.60400682013398
    x=4.94999999999999   f(x)=-0.589339660239126   P(x)=-6.25146496814124
    x=4.99999999999999   f(x)=-0.132351750097868   P(x)=-0.132351750099295
    Press any key to continue
    (notice the round off error in the increment of x, due to 0.05 being a repeating binary sequence, check this thread to see why this is dangerous :smile:)
  12. Apr 26, 2006 #11
    Thanks, that really cleared up alot of stuff. Yeah, I have used arrays in my code, and it was getting too complicated, but I am still not sure why my code didn't work with the arrays.
    Now, if I were to compare lagrange interpolation, to say, cubic spline interpolation, then it's be better to make a new function, right? Also, the x and y values are going to be pretty much the ones from the sinx^2 function, right? I am hoping to somehow use the lagrange interpolation function to sort of minimize the code I have to write for the cubic spline.
  13. Apr 26, 2006 #12
    -Job-
    I just want to correct something. The output that i posted was actually for n=10, that's why P(x) and f(x) are somewhat off. I meant to post the output with n=100 which is much better and you can clearly see Runge's Phenomenon:
    Code (Text):
    x=0   f(x)=0   P(x)=0
    x=0.05   f(x)=0.00249999739583415   P(x)=-60907171.41443
    x=0.1   f(x)=0.00999983333416667   P(x)=-38762.241528455
    x=0.15   f(x)=0.0224981016105536   P(x)=133888.976920124
    x=0.2   f(x)=0.0399893341866342   P(x)=-47477.1557530205
    x=0.25   f(x)=0.0624593178423802   P(x)=-676.321658577803
    x=0.3   f(x)=0.089878549198011   P(x)=-70.0563415465577
    x=0.35   f(x)=0.122193852192663   P(x)=-10.3323357821072
    x=0.4   f(x)=0.159318206614246   P(x)=-0.743757999126726
    x=0.45   f(x)=0.201118873846073   P(x)=0.242422729546865
    x=0.5   f(x)=0.247403959254523   P(x)=0.234926987631692
    x=0.55   f(x)=0.297907621896134   P(x)=0.297937142509013
    x=0.6   f(x)=0.35227423327509   P(x)=0.352142785624735
    x=0.65   f(x)=0.410041898781764   P(x)=0.410028523227198
    x=0.7   f(x)=0.470625888171158   P(x)=0.470635245914266
    x=0.75   f(x)=0.53330267353602   P(x)=0.533302801399181
    x=0.8   f(x)=0.597195441362392   P(x)=0.59719531855193
    x=0.85   f(x)=0.661262123760472   P(x)=0.661262069516314
    x=0.9   f(x)=0.724287174370143   P(x)=0.724287171972466
    x=0.95   f(x)=0.784878485034067   P(x)=0.784878488139338
    x=1   f(x)=0.841470984807897   P(x)=0.84147098533634
    x=1.05   f(x)=0.89233856416221   P(x)=0.892338563879778
    x=1.1   f(x)=0.935616001553386   P(x)=0.935616001445517
    x=1.15   f(x)=0.969332510867995   P(x)=0.969332510854974
    x=1.2   f(x)=0.991458348191687   P(x)=0.99145834818017
    x=1.25   f(x)=0.999965585678249   P(x)=0.999965585674027
    x=1.3   f(x)=0.992903651094118   P(x)=0.992903651094568
    x=1.35   f(x)=0.968489520283355   P(x)=0.968489520283317
    x=1.4   f(x)=0.925211520788168   P(x)=0.925211520787792
    x=1.45   f(x)=0.86194455517421   P(x)=0.861944555174197
    x=1.5   f(x)=0.77807319688792   P(x)=0.778073196887921
    x=1.55   f(x)=0.673617587361252   P(x)=0.67361758736126
    x=1.6   f(x)=0.549355436427125   P(x)=0.549355436427112
    x=1.65   f(x)=0.406931797351062   P(x)=0.406931797351064
    x=1.7   f(x)=0.24894678667315   P(x)=0.248946786673147
    x=1.75   f(x)=0.0790102167473866   P(x)=0.0790102167473904
    x=1.8   f(x)=-0.0982485937451118   P(x)=-0.0982485937451123
    x=1.85   f(x)=-0.27722754488774   P(x)=-0.27722754488774
    x=1.9   f(x)=-0.451465752161427   P(x)=-0.451465752161426
    x=1.95   f(x)=-0.613833396107784   P(x)=-0.613833396107783
    x=2   f(x)=-0.756802495307931   P(x)=-0.75680249530793
    x=2.05   f(x)=-0.872798699517351   P(x)=-0.872798699517349
    x=2.1   f(x)=-0.954627771660217   P(x)=-0.954627771660218
    x=2.15   f(x)=-0.995962705156195   P(x)=-0.995962705156194
    x=2.2   f(x)=-0.991868757310913   P(x)=-0.991868757310912
    x=2.25   f(x)=-0.939334638675732   P(x)=-0.939334638675732
    x=2.3   f(x)=-0.837769480165098   P(x)=-0.837769480165098
    x=2.35   f(x)=-0.689418018619284   P(x)=-0.689418018619284
    x=2.4   f(x)=-0.499641883116905   P(x)=-0.499641883116904
    x=2.45   f(x)=-0.277014201809769   P(x)=-0.277014201809769
    x=2.5   f(x)=-0.0331792165475613   P(x)=-0.0331792165475615
    x=2.55   f(x)=0.217560782359321   P(x)=0.217560782359322
    x=2.6   f(x)=0.458951486377685   P(x)=0.458951486377685
    x=2.65   f(x)=0.673781675524276   P(x)=0.673781675524275
    x=2.7   f(x)=0.845133411657213   P(x)=0.845133411657214
    x=2.75   f(x)=0.957819147348828   P(x)=0.957819147348828
    x=2.8   f(x)=0.999902258547975   P(x)=0.999902258547975
    x=2.85   f(x)=0.964165036726313   P(x)=0.964165036726314
    x=2.9   f(x)=0.849363378505475   P(x)=0.849363378505476
    x=2.95   f(x)=0.661095543640036   P(x)=0.661095543640036
    x=3   f(x)=0.412118485241771   P(x)=0.412118485241773
    x=3.05   f(x)=0.121973473857497   P(x)=0.121973473857497
    x=3.1   f(x)=-0.184164779400656   P(x)=-0.184164779400655
    x=3.15   f(x)=-0.477425197790973   P(x)=-0.477425197790976
    x=3.2   f(x)=-0.727877870349722   P(x)=-0.727877870349721
    x=3.25   f(x)=-0.907679875544638   P(x)=-0.907679875544638
    x=3.3   f(x)=-0.994432209303193   P(x)=-0.994432209303187
    x=3.35   f(x)=-0.97436266119118   P(x)=-0.97436266119119
    x=3.4   f(x)=-0.844895943776041   P(x)=-0.844895943776045
    x=3.45   f(x)=-0.616170006866291   P(x)=-0.616170006866324
    x=3.5   f(x)=-0.311119354981156   P(x)=-0.311119354981138
    x=3.55   f(x)=0.0361215260101955   P(x)=0.0361215260101664
    x=3.6   f(x)=0.383542755412577   P(x)=0.383542755412759
    x=3.65   f(x)=0.686110730859183   P(x)=0.686110730857785
    x=3.69999999999999   f(x)=0.901675770066375   P(x)=0.901675770068809
    x=3.74999999999999   f(x)=0.997213718805396   P(x)=0.997213718809361
    x=3.79999999999999   f(x)=0.954495430240934   P(x)=0.954495430259517
    x=3.84999999999999   f(x)=0.774208286800343   P(x)=0.77420828683213
    x=3.89999999999999   f(x)=0.477637144914053   P(x)=0.477637144984646
    x=3.94999999999999   f(x)=0.105267874095546   P(x)=0.105267874149488
    x=3.99999999999999   f(x)=-0.287903316665018   P(x)=-0.287903314886773
    x=4.04999999999999   f(x)=-0.640029556161847   P(x)=-0.64002955654917
    x=4.09999999999999   f(x)=-0.892129364694352   P(x)=-0.892129380112669
    x=4.14999999999999   f(x)=-0.998417846377416   P(x)=-0.998417955099416
    x=4.19999999999999   f(x)=-0.935459140991685   P(x)=-0.935459246420381
    x=4.24999999999999   f(x)=-0.708278021051184   P(x)=-0.708279101677588
    x=4.29999999999999   f(x)=-0.35185858693223   P(x)=-0.351858017815286
    x=4.34999999999999   f(x)=0.0728794083906834   P(x)=0.0728393961814019
    x=4.39999999999999   f(x)=0.488564765772459   P(x)=0.488707570655531
    x=4.44999999999999   f(x)=0.815124497793637   P(x)=0.814437266123537
    x=4.49999999999999   f(x)=0.985525111565108   P(x)=1.00134556766263
    x=4.54999999999999   f(x)=0.960459678867108   P(x)=1.00535734265019
    x=4.59999999999999   f(x)=0.738706029703826   P(x)=-0.916344799364983
    x=4.64999999999999   f(x)=0.360355131767404   P(x)=5.55297239198827
    x=4.69999999999999   f(x)=-0.0986905140096249   P(x)=-19.3321227061742
    x=4.74999999999999   f(x)=-0.540769321526501   P(x)=-1764.86886307135
    x=4.79999999999999   f(x)=-0.866851155826269   P(x)=-2493.22965470624
    x=4.84999999999999   f(x)=-0.999222150718628   P(x)=-218569.956219739
    x=4.89999999999999   f(x)=-0.901291364088664   P(x)=8161924.37235928
    x=4.94999999999999   f(x)=-0.589339660239126   P(x)=179083586.20583
    x=4.99999999999999   f(x)=-0.132351750097868   P(x)=-0.320717299305203
    For cubic splines i suppose you can use the same strategy for obtaining the points.
  14. Apr 27, 2006 #13
    Integral
    Staff Emeritus
    Nice work Job!
    Include a difference column (F(x) - PN) This will revel some structure in the interpolation errors.
    Yes, you should stay away from the end points of High order polynoimials they can get pretty snaky. Higher order is not always better, a lot depends on the behavior of your function in the region of your approximation. The end effects may cause some trouble linking to a cubic spline. I am not real sure what the OP has in mind so can't say much more with out more info.
    You want to use the http://www.cse.uiuc.edu/eot/modules/interpolation/chbshvp/" points as your interpolating set. This is the minmial error.
    Happy computing.:smile:
  15. Jul 7, 2006 #14
    Does anyone by any chance have that in fortran? i will be needing it and i unfortunately know almost nothing about fortran whatsoever
  16. Jun 3, 2008 #15
    Lagrange Interpolation using Newton
    Hello
    Can you help me with an inplementation of lagrange interpolating polynom using the Newton's formula? (that with divided differences). or smth appropiate to that, i wanna calculate the lagrange interp. polynom, but not using the barycentric formula
    p.s. the Input is the nodes to which i wanna calculate the polynom
