Lagrange multiplers question
  • Thread starter Gekko
f(x,y,z)=4x^2+4y^2+z^2 subject to x^2+y^2+z^z=1
So I have:
F(x,y,z,c) = 4x^2+4y^2+z^2+L(x^2+y^2+z^2-1)
dF/dx = 8x+2xL
dF/dy = 8y+2yL
dF/dz=2z+2zL
Either x=y=0 and L=-1 OR z=0 and L=-4
For first case, z^2=1 therefore z=+/- 1 giving f(0,0,1)=1
For second case, x^2+y^2=1 2x^2=1 x=y=+/-sqrt(1/2) giving f(sqrt(1/2),sqrt(1/2),0)=4
Is this correct?
The minimum is therefore the first case giving f(0,0,1)=1?
Answers and Replies
Yup, it all looks right to me.
Does that mean both cases are valid? One is the maximum and one is the minimum?
epenguin
897
I'm assuming
is typo for
x^2+y^2+z^2 = 1.
Without using Lagrange you could subtract x^2+y^2+z^2=1 from f(x,y,z)=4x^2+4y^2+z^2 giving you 3(x2 + y2) = f - 1. As this LHS contains only squares it cannot be less than 0. Which is f=1. That is your minimum.
For the maximum looking at the form of f and your constraint you see that so to speak, x, y and z contribute indifferently to your constraint, but taking stuff away from z and investing it in x or y yields you more f. So z=0 will maximise f. The constraint is a sphere round the origin, but the the maximum of f is along a circle z=0, x2 + y2 = 1.
I think it is everywhere along that circle. From this you still get the maximum of f=4, but if I am not mistaken :uhh: your answer is not unique but all points satisfying this x2 + y2 = 1 are solutions to the maximum problem.
It is necessary to know the Lagrange method but surprisingly often you can solve problems without it - use the constraint to solve or simplify your problem and use symmetry between variables.
Thanks for your replies. Very helpful
Related Threads on Lagrange multiplers question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
