Lagrange Multipliers
  • Thread starter snoggerT
find min/max:
f(x,y)=xy with constraint being 4x^2+9y^2=32
[gradient]f=[lambda]gradient g
I thought I understood the Lagrange problems, but I can't seem to get the minimum right on the last few problems. I get x=+/-2 and then plug back in to find y, then I use my critical points to find my min/max in f(x,y). I got 8/3 for my max on my problem (which is right), but can't get the minimum right. I set it up as such:
f(-2,-4/3)=xy and get +8/3 again, but the answer in the back of the book is -8/3 for the minimum. What am I doing wrong?
Answers and Replies
Dick
26,263
619
You aren't doing anything wrong. But how about f(2,-4/3) or f(-2,4/3)? Nothing in the problem forces x and y to have the same sign.
- Alright, then that makes sense. The book isn't very good at pointing things out like that.
while on the topic of lagrange...When you get into having 3 variables and 1 constraint, would you set up the problem as [lambda]=x=y=z? If so, how would you solve for the unknowns?
Dick
26,263
619
Well, you'll have three equations involving x,y,z and lambda coming from the gradient. Then you have the constraint equation in x,y,z. That's four equations in four unknowns. There's no special way to set it up, just derive the equations from the partial derivatives.
Related Threads on Lagrange Multipliers
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
