Homework Help: Lagrange's Identity
  1. Apr 22, 2014 #1
    From Mary Boas' "Mathematical Methods in the Physical Sciences" 3rd ed. Ch 3 Sec 4 problem 24
    Where A and B are vectors. What is the value of (AXB)^2+(A dot B)^2=? Comment: This is a special case of Lagrange's Identity.
    2. Relevant equations
    Cross product and dot product definitions.
    3. The attempt at a solution
    I get a nasty mess that ends up equaling A^2*B^2. That is what is supposed to equal, but I got such a large unwieldy result that I would have no idea that it all could be collapsed down to A^2*B^2 by simply looking at it. So I looked up the answer and saw that my mess is supposed to equal A^2*B^2. I tried it in SAGE and sure enough they are identical. However, I am not sure what the purpose of the exercise is supposed to help me understand other than expanding both sides to see that Lagrange's Identity indeed works.
    Am I missing something here? I have noticed with working with Mary Boas' book most solutions are very elegant and don't require a rat's nest of algebra. Usually if a mess results, I am doing it wrong :D
    Thanks,
    Chris Maness
  3. Apr 22, 2014 #2
    LCKurtz
    If A X B is a vector, what does it mean to square it? Or do you mean |AXB|^2?
  4. Apr 22, 2014 #3
    The book presents it that way, but she states if you see a vector^2 it is actually the dot product with itself. I cheated and peaked at the solutions manual and she actually didn't give the answer, but a fat hint.
    Use AXB=|A||B|*sin(x), and A dot B=|A||B|*cos(x).
    It is indeed very elegant with this hint.
    Thanks,
    Chris Maness
  5. Apr 22, 2014 #4
    LCKurtz
    You need to be more careful about the distinction between vectors and their magnitudes. Your statement above that I have highlighted makes no sense because you have a vector on the left and a scalar on the right. I think you made the same mistake in your original statement of the problem. Don't confuse AXB with |AXB|.
  6. Apr 22, 2014 #5
    Yes, I see the issue. She does write it just like that in the text with that statement for clarity.
    Thanks,
    Chris Maness
  7. Apr 22, 2014 #6
    lurflurf
    It is not confusion, it is operator overloading.
    It is very common (almost standard) to define.
    $$\mathbf{A}^2=\mathbf{A}\cdot \mathbf{A}=|\mathbf{A}|^2$$
    no confusion is likely to result the other self products are written
    $$\mathbf{A} \times \mathbf{A}=\mathbf{0} \\
    \mathbf{A} \mathbf{A}
    The hint form is slightly troubling it could be written unambiguously, for example
    $$(\mathbf{A}\times \mathbf{B})^2=\mathbf{A}^2 \, \mathbf{B}^2 \, \sin^2(x)=(|\mathbf{A}|\, |\mathbf{B}| \sin(x))^2 \\
    (\mathbf{A}\cdot \mathbf{B})^2=\mathbf{A}^2 \, \mathbf{B}^2 \, \cos^2(x)=(|\mathbf{A}|\, |\mathbf{B}| \cos(x))^2$$
  8. Apr 22, 2014 #7
    Yes, your first LaTeX line is in her text, and then it goes on to write (|AXB|)^2 as (AXB)^2.
    Chris
  9. Apr 22, 2014 #8
    LCKurtz
    Yes, I have seen that before too, and I don't care for it. But I have never seen it acceptable to write$$
    A\times B = |A||B|\sin\theta$$Students have enough trouble keeping vectors and scalars straight without overloading (abusing) the notation.
Have something to add?
Draft saved Draft deleted
