Lagrangian Mechanics: Variable Mass System?
In summary, the lagrangian of a dynamic system is the time derivative of the positional partial derivatives (position and velocity) of the lagrangian.
Supfresh
First, to make sure i have this right, lagrangian mechanics, when describing a dynamic system, is the time derivative of the positional partial derivatives (position and velocity) of the lagrangian of the system, which is the difference between the kinetic and potential energy of the system. (set equal to external forces on the system, Q)
L = T-U
is this right?
So my question is:
is the definition of a lagrangian, T-U, valid only for constant mass systems or can it still be used for variable mass systems? what about the derivatives of the lagrangian, would i need to find the partial derivative of the lagrangian with respect to mass? and finally, I am assuming the answers to these questions are very different if we are talking about a time varying mass vs a mass that varies with postion, yes?
Any help would be much appreciated. As I am sure you can tell, i am very lost at the moment
As background for what I am working on, it's a mass on a spring (assuming attached to a rigid/ non-moving body, so for now 1 degree of freedom) with the mass decresing with respect to time. Finally as the mass decreases there is a perodic downward force applied to the mass decreasing in amplitude proportional to the decrease in mass.
Hmmm, interesting question. My initial response was that it should still work as long as all the mass is accounted for, but then I saw your specific scenario. If mass was simply moving from body A to body B, both in the problem, I think it would work. If mass was a function of position, it would be differentiated in the partial derivatives. If it was a function of just time, it would be be differentiated in the total time derivative, so I don't see why it wouldn't work.
However, if mass was simply disappearing it seems like you would just have energy disappearing, which strikes me as something that would mess things up (since a big part of the lagrangian is the trade in energy between T and U).
But then your situation is even more interesting, because you actually are putting more T in, in the form of that force. Hmmm, let me think about this.
Well i ended up proceeding as i would in a constant mass problem and then just differentiating mass w/respect to time in the total time derivative. Which gave me the following diff equation:
[itex]\ddot{m}\ddot{x} + \dot{m}\dot{x} + kx + mg = F(t) [/itex]
substituting in F(t),
[itex]\ddot{m}\ddot{x} + \dot{m}\dot{x} + kx + mg = g(NM-\frac{tω}{2\pi}M)[\frac{1}{2}cos(ωt)+1][/itex]
Now to see if i remember how to use maple :eek:
1. What is a variable mass system in Lagrangian mechanics?
A variable mass system in Lagrangian mechanics refers to a system where the mass of the system changes over time. This could be due to the addition or removal of mass, or the conversion of mass into energy.
2. How is the Lagrangian of a variable mass system determined?
The Lagrangian of a variable mass system is determined by considering the kinetic and potential energies of all the particles in the system, as well as any external forces acting on the system. The Lagrangian is then expressed as a function of the generalized coordinates and their derivatives.
3. What are the advantages of using Lagrangian mechanics for variable mass systems?
One advantage of using Lagrangian mechanics for variable mass systems is that it allows for a unified approach to solving problems involving changing mass. It also simplifies the equations of motion by reducing the number of variables needed to describe the system.
4. Can Lagrangian mechanics be applied to systems with non-conservative forces?
Yes, Lagrangian mechanics can be applied to systems with non-conservative forces. The equations of motion can be modified to include non-conservative forces by adding an additional term to the Lagrangian, known as the Rayleigh dissipation function.
5. Are there any limitations to using Lagrangian mechanics for variable mass systems?
One limitation of using Lagrangian mechanics for variable mass systems is that it assumes the mass changes occur slowly and continuously. It may not accurately describe systems where the mass changes rapidly or in a discontinuous manner. Additionally, it may not be suitable for systems with complex external forces, such as those involving strong electromagnetic fields.
  • Mechanics
  • Mechanics
