• Support PF! Buy your school textbooks, materials and every day products Here!
Lagrangian of a circuit
  • Thread starter T-7
T-7
64
Hello folks,
I could really do with a few hints with this. (As soon as possible!)
1. Homework Statement
For a repeated line of cells, two 'equations of motion' can be written:
[tex]C_{n}\dot{U_{n+1}} = I_{n}-I_{n+1}[/tex]
[tex]L_{n}\dot{I_{n}} = U_{n} - U_{n+1}[/tex]
where [tex]C_{n}[/tex] is the capacitance, [tex]U_{n+1}[/tex] the voltage after the nth cell, [tex]I_{n}-I_{n+1}[/tex] the charging current, [tex]L_{n}[/tex] the inductance.
Work out the Lagrangian that generated these equations.
You should find that
[tex]E = \sum_{n}\left( (1/2)\L_{n}\dot{Q_{n}}^{2} + (1/2)C_{n}U_{n+1}^{2} \right)[/tex]
and
[tex]H = (1/2)\sum_{n}\left( \frac{P_{n}^{2}}{L_n}} + \frac{(Q_{n+1}-Q_{n})^{2}}{C_{n}} \right)[/tex]
2. Homework Equations
Note that
[tex]Q_{n} = -\int I_{n} dt => C_{n}U_{n+1} = Q_{n+1} - Q_{n}[/tex]
3. The Attempt at a Solution
I have suggested a Lagrangian of
[tex]L = (1/2)L_{n}\dot{Q_{n}}^{2} + Q_{n}(U_{n+1}-U_{n}) + (1/2)C_{n}\dot{U_{n+1}^{2}} + U_{n+1}(I_{n}-I_{n+1})[/tex]
(which can be turned into a sum for all the repeated circuits)
but it doesn't seem convincing, despite the fact that you can recover the original 'equations of motion' using Euler-Lagrange equations (using Q and U).
I'm not sure how the energy is being derived from the Lag. in this case (in mechanics, it was always the case that L = T - U, hence E = T + U), and it seems clear that you aren't going to get either that expression for the energy or that Hamiltonian from my guess-work Lagrangian.
Any suggestions?
Many thanks!
Answers and Replies
I don't think Ulf would like this any more than Chris.
malawi_glenn
4,782
T-7
64
I think Anony. is under the impression that, being part of a set Q, this isn't up for discussion. According to the tutor I asked, we *can* discuss these Qs with other Physicists, exchange ideas, argue, etc. What we're not allowed to do is just copy someone's answer (which PhysicsForums also prohibits).
Related Threads for: Lagrangian of a circuit
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
