• Support PF! Buy your school textbooks, materials and every day products Here!
Lagrangian problem
Mass m is connected to a string and is being whirled in a circle in a horizontal plane of a table. The string passes through a hole in the center of the circle and is being pulled with a constant velocity V starting at t=0 so the radius decreases. Initially the mass is at a distance r0 from the hole and is revolving with angular speed [tex]\omega_0[/tex]. Use Lagranges equations and Lagrange multipliers to find then tension in the string as a function of time.
I have attempted to write down the Lagrangian with the lagrange multipliers but i am not sure it is correct.
what i have is that the speed of the mass is given by:
[tex]v=r\omega = r\dot{\theta}[/tex] and i have that r = r0 - Vt so [tex]v=(r_0-Vt)\dot{\theta}[/tex]
Using this in 1/2mv^2 for the Lagrangian along with the constraint r-r0+Vt=0 my Lagrangian with lagrange multiplier was this:
[tex]\frac{m}{2}(r_0^2-2r_0Vt + V^2t^2)\dot{\theta}^2 + \lambda(r-r_0+Vt)=L[/tex]
and when doing the derivative [tex]\frac{\partial{L}}{\partial{\dot{r}}}[/tex] i have this is the partial with respect to V. is this correct? then i would solve for lambda and this would be my force of tension?
Answers and Replies
Related Threads for: Lagrangian problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
