Lame's Equation Maths Problem
  • Thread starter Jud
  • Tags
    stress
Jud
A steel pipe is 200mm internal diameter and 20mm thick. Calculate the safe internal pressure if the allowable stress is not to exceed 140Mpa.
σr = A-B/r^2[/B]
and
σtheta = A+B/r^2
Right so, I've got two equations.....
(eq1)140MPa =A+B/0.1^2
and
(eq2)0 = A-B/0.12^2
I need help getting A and B. Answers (A=57.38)and (B=0.826)
I know I need to use simultaneous equations. Could someone please give me a step by step solution as I'm stuck.
I have so far done -(eq2)+(eq1) to cancel out A.
and got
...140MPa = B/0.1^2 + B/0.12^2
I'm not sure what to do next to get B.
Answers and Replies
SteamKing
Staff Emeritus
12,798
1,670
Hint: use eq. 2 to get A in terms of B (or vice versa). Substitute back into eq. 1 and solve.
Jud
I don't understand, sorry. Could you elaborate with the values please.
SteamKing
Staff Emeritus
12,798
1,670
It's very simple. You've got A - B/0.12^2 = 0. Find A in terms of B, or B in terms of A.
Once you have found an expression for A or B, substitute that expression back into eq. 1, which will then be one equation in one unknown.
You're in algebra 101 here.
Jud
I.e. B = A/0.12^2
So,
140MPa = A + (A/0.12^2)/0.1^2?
SteamKing
Staff Emeritus
12,798
1,670
I.e. B = A/0.12^2
Uh, not quite. Remember, you've got
A - B/0.12^2 = 0
How did you come up with
B = A/0.12^2 ?
8,124
Jud, starting with A - B/0.12^2 = 0, solve for B, without skipping steps.
Jud
A = -B/0.12^2
A(0.12^2) = -B
SteamKing
Staff Emeritus
12,798
1,670
A = -B/0.12^2
A(0.12^2) = -B
So you're saying if A - 5 = 0, then A = -5. Check your work again.
Jud
-A(0.12^2) = -B
So, 140MPa = A + - A(0.12^2)/0.1^2
SteamKing
Staff Emeritus
12,798
1,670
-A(0.12^2) = -B
You can multiply both sides of the equation by -1 to obtain
A(0.12^2) = B
And how would you solve for A?
Friendly advice: I don't know anything about your academic background, but your apparent lack of understanding of algebra is going to prevent you from solving more complex problems than this. Try to take time and remedy this gap in your mathematical knowledge. ;)
Related Threads on Lame's Equation Maths Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
