Homework Help: Laplace Inverse of a solution
  1. May 4, 2012 #1
    laplace inverse of (40/(s^2+4s+5)^2)?
    2. Relevant equations
    I completed the square in the denominator to get 40/((s+2)^2+1)^2
    I know that I will get cosines and sines from the shape of it in the laplace inverse; however I'm stuck.
    3. The attempt at a solution
  3. May 4, 2012 #2
    I get the follwing result:
    [itex] 20e^{-2t}(\sin(t)-t\cos(t))[/itex]
    But couldn't find any formula, so i did it with Maple 15
  4. May 4, 2012 #3
    Ray Vickson
    It will be a lot easier if you first factor the expression p = s^2 + 4s + 5, then convert your expression 1/p^2 to partial fractions.
    RGV
  5. May 4, 2012 #4
    dikmikkel This answer is correct; however I don't know how to get there.
    Ray Vickson, we are not used to getting complex numbers.
  6. May 4, 2012 #5
    Ray Vickson
    You should get used to it; they are part of a standard toolkit and are used routinely in Physics, Engineering and Applied Math. However, if you don't want to use complex quantities you can use the convolution theorem instead: first get the inverse Laplace transform of 1/(s^2 + 4s + 5), then find that of 1/(s^2 + 4s + 5)^2 by convolution.
    RGV
