Homework Help: Laplace of F(ks)
  1. May 6, 2014 #1
    Compute the inverse laplace transform of F(ks)
    2. Relevant equations
    3. The attempt at a solution
    $$L^{-1} (F(ks)) = \frac{f}{|k|} \left( \frac{t}{k} \right)$$
    Correct?
  3. May 6, 2014 #2
    Mark44
    Staff: Mentor
    Why do you think you need the absolute value of k?
    What do you get from ##\mathcal{L}(f(t/k))##, using the definition?
  4. May 6, 2014 #3
  5. May 6, 2014 #4
    You could just the fact that ##\mathscr{F}[f](\lambda)=\frac{1}{\sqrt{2\pi}}\mathscr{L}[f](i\lambda)## if we assume that ##f(x)=0## for ##x<0##.
    Where the Fourier Transform is the following ##\mathscr{F}[f](\lambda)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{\infty}f(x)e^{-ix\lambda}dx##
    It should now be clearly what the inverse Laplace transform of the Fourier transform of a function is.
  6. May 7, 2014 #5
    I did a simple question. I hoped a yes or not...
  7. May 7, 2014 #6
    Your answer is correct. Sorry about earlier, I mistook the F to be the Fourier transform.
  8. May 8, 2014 #7
    Ok, thankyou!
Have something to add?
Draft saved Draft deleted
Loading...
