Laplace transform
[SOLVED] Laplace transform
Find the inverse laplace transform of [tex]\frac{e^{-2s} }{s^2 + s - 2}[/tex]
I'm able to do about half of the problem
using partial fractions, I've found
[tex]\frac{e^{-2s}}{3(s+1)}+\frac{e^{-2s}}{3(s-2)}[/tex]
I can find the inverse Laplace transform of the latter part of that expression [tex]1/3u_2(t) e^{t-2}[/tex] unfortunately, I don't know how I can modify the first part so that it's shifted by -2. Anyone know what I should do?
Answers and Replies
Use calculus of residues (have you taken complex analysis yet?)
1. The problem statement, all variables and given/known Anyone know what I should do?
Look in the wiki page about laplace transformations under 'time shifting'.
Unfortunately I haven't studied complex analysis.
I made an error in my original post (and I can't edit it for some reason)
It's now worse than before
[tex]s^2 + s - 2 = (s+2)(s-1)[/tex]
[tex]-\frac{e^{-2s}}{3(s+2)} + \frac{e^{-2s}}{3(s-1)}[/tex]
I see the time shift equation on wikipedia, but since the 's' is in the denominator I don't see how to shift either so that they match up with [tex]u_2(t)[/tex]
Hum, you seem to be misreading it, do this for your two terms separately
Step 1-- cover the exponential up with your hand. What's left is your 1/(s+2) (or 1/(s-1) for the other term) with your 3 and your signs of course. Call that F(s).
Step 2-- look up on a table the f(t) such that L[f]=F(s) from Step 1. Write that f(t) down.
Step 3-- now look on that exponential you were ignoring before (exp(-2s)) that's telling you that your answer will not be f(t), but instead be f(t-2)H(t-2) where H is the unit step function. So write that down.
Now repeat for the other term and then add the two expressions you get from Step 3 together.
got it now thanks, those steps are really handy
Related Threads on Laplace transform
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
