Large/Infinite results
  1. Jun 18, 2015 #1
    Hello to all!
    I have written this 1D FDTD code but the results I take are very large and after some timestep they get to infinite/NaN... I really don't know what's wrong. The expressions I have used are the exact given solution for the Maxwell equations.
    Thank you for your help.
    Code (Fortran):
    program yee
        implicit none
        real :: Delta, tau,omega,n,mu,time,Eprev,Hprev
        real, dimension(:), allocatable :: sigma,eps,A,B,C,D,J
        real, dimension(:), allocatable :: E,H
        real, parameter :: pi=3.1415926
        integer :: i,m=10000, Length=5000,ls,k
        Allocate(E(Length),H(Length),sigma(Length),eps(Length))
        Allocate(A(Length),B(Length),C(Length),D(Length))
        Allocate(J(Length))
    !Initialization
        open(unit=1,file="Elektrfeld.txt")
        Delta=0.02d0
        tau=0.9d0*Delta
        omega=2.0d0*pi
        n=1.46d0
        mu=1
        ls=1000
        E(:)=0.0d0
        H(:)=0.0d0
        A(:)=0.0d0
        B(:)=0.0d0
        C(:)=0.0d0
        D(:)=0.0d0
        J(:)=0.0d0
        Eprev=0.0d0
        Hprev=0.0d0
        do i=1,Length
            if (i.le.6/Delta) then
                sigma(i)=1.0d0
            else if (i.gt.6/Delta .and. i.lt.((Length*Delta-6.0d0)/Delta))then
                sigma(i)=0.0d0
            else if (i.ge.(Length*Delta-6.0d0)/Delta .and. i.le.Length) then
                sigma(i)=1.0d0
            end if
        end do
        do i=1,Length
            if (i.lt.Length*0.5d0) then
                eps(i)=1.
            else if (i.ge.1100 .and. i.lt.(1100+2)) then
                eps(i)=n**2.
            else if (i.ge.(1100+2)) then
                eps(i)=1.
            end if
        end do
        do i=1,Length
            A(i)=(1.-sigma(i)*tau/(2.*mu))/(1.+sigma(i)*tau/(2.*mu))
            B(i)=(tau/mu)/(1.+(sigma(i)*tau)/(2.*mu))
            C(i)=(1.-sigma(i)*tau/(2.*eps(i)))/(1.+sigma(i)*tau/(2.*eps(i)))
            D(i)=(tau/eps(i))/(1.+sigma(i)*tau/(2.*eps(i)))
        end do
        write(*,*) "time"
        read(*,*) time
    !----------------Main calculation----------------
        do k=1,m        !time
            E(1)=0.0d0
            E(Length)=0.0d0
            J(ls)=sin(2.*pi*k*tau)*exp(-((k*tau-30.)/10.)**2.)
            do i=2,Length
                Eprev=E(i)
                E(i)=D(i)*(H(i)-H(i-1))/Delta+C(i)*E(i)-D(i)*J(i)
            end do
            do i=1,Length
                Hprev=H(i)
                H(i)=B(i)*(E(i)-E(i-1))/Delta+A(i)*Hprev
            end do
            if (k.eq.time ) then
                write(1,*) "-----",k
                do i=800,1200
                    write(1,*) E(i)
                end do
            end if
        end do
        close(1)
    end program yee
  3. Jun 18, 2015 #2
    phinds
    2016 Award
    we have "code" tags that get your code properly formatted. It would be a good idea if you modified your post to use them.
  4. Jun 18, 2015 #3
    Well, at quick glance, the second i-loop goes from 1 to Length and it contains the term E(i-1), this means that for i=1, you are calling on E(0) which is not defined...it is outside your program altogether given the way you allocated the arrays, their indexes start at 1.
Similar Discussions: Large/Infinite results
  1. Infinite Loop (Replies: 0)
  2. Infinite Databases? (Replies: 10)
Loading...
