Proving N is a Composite Number: Larson 4.1.8 [SOLVED]
  • Thread starter ehrenfest
In summary, it is proven that the number N, consisting of 91 ones in decimal notation, is a composite number. This is shown by using the fact that if N has an even number of ones, it can be factored using the sum of powers. For the odd case of 91 ones, it was shown that N is divisible by (10^7 - 1)/9 and (10^13 - 1)/9. Therefore, N is a composite number.
ehrenfest
2,020
[SOLVED] larson 4.1.8
Let N be the number which when expressed in decimal notation consists of 91 ones:
1111...1111 = N
Prove that N is a composite number.
If N had an even number n of ones we could use the fact that
[tex]\sum_{i=0}^n x^i = (1+x)(x+x^3+x^5+...+x^{n-1}) = N [/tex]
evaluated at x=10. I tried doing lots of similar tricks for the odd case but nothing seems to factor completely.
Since 91=13*7, then 10^91 - 1 = 0 (mod 10^7 - 1) (and 10^91 - 1 = 0 (mod 10^13 - 1)) - prove this. And since 9N = 10^91 - 1, it follows that N is divisible by (10^7 - 1)/9 (and (10^13 - 1)/9).
1. What is a composite number?
A composite number is a positive integer that has more than two factors. In other words, it is a number that is divisible by more than just 1 and itself.
2. How do you prove that a number is composite?
To prove that a number is composite, you can show that it has at least three factors. This can be done by finding two numbers, other than 1 and itself, that multiply to equal the number in question.
3. Can every number be proven to be composite?
No, not every number can be proven to be composite. Prime numbers, which only have two factors (1 and itself), cannot be proven to be composite.
4. What is the significance of proving that a number is composite?
Proving that a number is composite is important in number theory and can also have practical applications. For example, it can be used in cryptography to ensure the security of data.
5. How does the Larson 4.1.8 method prove that a number is composite?
The Larson 4.1.8 method states that if a number, n, can be written as n = ab, where a and b are integers greater than 1, then n is composite. This method provides a clear and simple way to prove that a number is composite.
