Homework Help: Laser resonant cavity
Tags:
  1. Nov 9, 2014 #1
    The fact that a laser's resonant cavity so effectively sharpens the wavelength can lead to the output of several closely spaced laser wavelengths, called longitudinal modes. Here we see how. Suppose the spontaneous emission serving as the seed for stimulated emission is of wavelength 633 nm, but somewhat fuzzy, with a line width of roughly 0.001 nm either side of the central value. The resonant cavity is exactly 60 cm long. (a). How many wavelengths fit the standing wave condition? (b) If only a single wavelength were desired would changing the length of the cavity help? Explain.
    2. Relevant equations
    L = n λ / 2
    3. The attempt at a solution
    n = 2L/λ
    n = 1895734.597
    For part one I have a feeling that n is not what were solving for. (Plus I'm not using the 0.001 nm width that is given).
    part b.
    Yes it would help, because if n is an integer number, wavelengths will end up interfering constructively in the cavity.
  3. Nov 9, 2014 #2
    mfb
    2017 Award
    Staff: Mentor
    You calculated n for the central wavelength. What about the lower and upper bound on the wavelength?
    No, but you'll need (a) to see how (b) is meant.
  4. Nov 9, 2014 #3
    would I still use the equation above?
  5. Nov 9, 2014 #4
    mfb
    2017 Award
    Staff: Mentor
    Sure, it is just a different wavelength value.
  6. Nov 9, 2014 #5
    so would I just add and subtract 0.001 from 633?
  7. Nov 10, 2014 #6
    mfb
    2017 Award
    Staff: Mentor
    Sure, what else?
  8. Nov 14, 2014 #7
    I ended up just solving for n, and using only integer values of n, and then adding and subtracting 1 integer value, and solving for lambda, until lambda was out of the limits (633.001 and 629.999)
  9. Nov 15, 2014 #8
    mfb
    2017 Award
    Staff: Mentor
    That is way too complicated, but it is possible.
Have something to add?
Draft saved Draft deleted
