Last-minute concept problems (before exams)
In summary, the conversation discusses a physics problem involving determining the magnitude of the electric field at a certain point from the axis of a long nonconducting cylinder with a uniform charge density. The use of Gauss's Law is suggested, and the conversation delves into the differences in solving the problem inside and outside the cylinder. The correct equation is eventually determined to be E=2*(ro)*(pi)*(r)*(k), and a new circuit problem is introduced. However, there is some confusion about the diagram and the problem is not fully solved.
Flame
Hi. This thred will sort of be "my thread" i suspect for various concepts I still do not get after two semesters of college physics (my final is in two days). Without further ado, I'll ask my first question:
Here's how the problem reads:
A long nonconducting cylinder (radius = 12 cm) has a charge of uniform density (5.0 nC/m^3) distributed throughout its column. Determine the magnitude of the electric field 5.0 cm from the axis of the cylinder.
If they said to determinte it at a radius larger than the radius of the cylinder itself, I would most likely have no problem solvingit; but how do I solve it when they ask for the electric field 5 cm from the axis (i.e., r<R)?
The same way as it is outside. Outside, would you not determin it from the axis, rather than the radius? Thus, this is simply some distance from the axis, regardless of where the radius of said cylinder is?
So it makes no difference, then...
Using Gauss's Law (after being simplified) as follows:
E=(2*k*lambda)/r=(2*(9x10^9)*(5x10^-9))/0.05
I still don't come out with the correct answer (these questions are off of one of our previous tests for which we have the answers, but not how to solve them)
The answer, by the way, is supposed to come out to 14 N/C.
Am I using the wrong approach?
What have you tried?
Hint: Gauss' law, and a cylindrical gaussian surface inside the cilinder.
Think of what should happen with the E field:
1. What would you expect the E field to be at the center of the cylinder? (remember how it is defined... how would you expect a test charge to move if you had it at the center?)
2. You said you can solve it outside the cylinder. What do you get there?
3. How would you connect both results? (1 and 2).
This will probably give you a feeling for the kind of result you are looking for.
Of course it makes a difference!
It does makes a difference if you are inside or outside the cylinder. Say R is the radius of the cylinder and r the point at which you measure the field:
Outside, applying Gauss' law yields something like:
(gaussian integral up to r) = (charge up to R)
Since R is fixed and r is larger than R, when you solve for E you get
E = (coefficient) x (charge density) / r
OTOH, inside the cylinder, you get
(gaussian integral up to r) = (charge up to r)
Notice how the right hand side has now an r on it, so that it combines with the r in the left hand side, and you get a different dependence.
got it! :)
Thanks. I realized what I was doing wrong. I was using this certain problem as a template for what I was doing, only they were finding the charge of a certain distance from a LINE of charge. Hence, they were using (Lambda)*(L), rather than (ro)*(V), as I was supposed to.
The final equation, for anyone interested is:
where r is the distance from the axis, andk k=9x10^9
Thanks again. I'm sure I'll have more questions shortly.
Ok. I have a new one.
These circuit problems really get me sometimes. Maybe you can give me some general statements that I haven't caught onto yet to help me think through problems like this. here is goes:
If Va - Vb = 50V, how much energy is stored in the 54-uF capacitor shown?
The image that is shown is roughly this:
Code:
                    ------| 36uF |------
(a)------| 72uF |----                  -----(b)
                    ------| 54uF |------
My idea was to first combine the capacitors to find a single equivalent capacitor (which comes out to 80uF). I was trying to use the relationship:
(Ua)/q0-(Ub)/q0=Va-Vb
Together with this, I found the charge on the supposed 80mF capacitor by using the relationship Q=C(delta-V)
I'm stuck. Any ideas?
The diagram
Sorry the diagram didn't come out. it's supposed to be a single line with a 72uF capacitor on it. It then branches into two; one branch has a 36uF capacitor, and the other has a 54uF capacitor. The two then join back together. Hope it's easy enough to understand by just the words.
I haven't done any of these for a while, but I think you're on the right track: with the equivalent capacitance and deltaV, you can get the total charge. Then, you can get the charge and deltaV on each capacitor, and get the energy on the one you want...
you'll need to double check,... I'm a bit rusty on this, and about to fall sleep.
Good luck!
I don't see any 54uF capacitor on your picture.
Problem just doesn't look posted good enough for an answer.
Try it again, perhaps I can help
Make a .BMP and post it!
------| 64uF |------
It is the one marked "64".
Here:
Code:
Flame: you just need to put your ascii drawing between {CODE}{/CODE}
(in square instead of curly brackets)
AHA! And now it makes sense!
I would have to consult my book to get the answer, as this is one area of physics that I didn't remember to remember.
If you seriously need help, like if you don't get it in 2 days, I can dit it up. But there's probably some people tommorrow that will help ya.
But I do know the basics. From the change in voltage use forumula to get some value. Consolidate the capacitors. Use said value, plus total capicatance and work backwords. Consolidate first the last two only to get the first one. the opposite.
Originally posted by ahrkron
Here:
Code:
Don't know why...
I attach the file, tried both jpg and bmp. Neither one is showing up...
Ok,...
I think you need to:
1. get the total equivalent capacitance, C
2. Obtain the total charge in the circuit (from C and V),
3. "Unfold" the big C in two capacitances: one is the original C1 (72 uF), and the second one is the equivalent to the remaining two (call it C23).
4. From there, you can get the voltage difference on each of C1 and C23. IIRC, it goes like V23 = V(C1/(C1+C23)), but you'll need to double check this.
5. Once with V23 (which is the v. diff. in the system formed by C2 and C3), you know that the voltage across C3 is also V23 (so you can get the charge Q3).
6. Finally, you can get the energy from Q3 and C3.
Makes sense?
capacitance = C = q/V
U = (1/2)CV2
capacitors sum in series (I always think of "caparallel, plus plus plus")
Ceq=&sum;C}par
Ceq=1/&sum; (1/C)}ser
you should solve it with Kirchoff's rules:
input to every junction = output from every junction
and
sum of voltages around a closed loop = 0
1. What are some effective strategies for studying last-minute concept problems before exams?
Some effective strategies for studying last-minute concept problems include making flashcards, summarizing notes, practicing with past exams or study guides, and quizzing yourself or a study partner.
2. How can I manage my time effectively when studying last-minute concept problems?
To manage your time effectively when studying last-minute concept problems, consider breaking up your study time into smaller chunks and taking breaks in between. Prioritize the most important concepts and focus on understanding them rather than trying to cover everything at once.
3. Is it better to study alone or with a group for last-minute concept problems?
This ultimately depends on personal preference, but studying with a group can be beneficial as it allows for discussion and the opportunity to teach and learn from others. However, if you work better alone, it may be more effective to study by yourself.
4. Should I focus on memorizing or understanding last-minute concept problems?
It is important to strike a balance between memorizing and understanding last-minute concept problems. While memorization can be helpful for recalling information, it is important to also understand the underlying concepts and how they relate to each other.
5. How can I stay calm and focused while studying last-minute concept problems?
To stay calm and focused while studying last-minute concept problems, try to eliminate distractions and create a comfortable study environment. Take deep breaths and remind yourself of the progress you have made in your studies so far. Also, try to maintain a positive attitude and avoid getting overwhelmed by the amount of material you need to cover.
