1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Latent Heat
  1. May 4, 2008 #1
    In an insulated vessel, 250 g of ice at 0 °C is added to 600 g of water at 18 °C. (a) What is the final temperature of the system? (b) How much ice remains when the system reaches equilibrium?
    2. Relevant equations
    Q = mL, Q = mc[tex]\Delta[/tex]T
    3. The attempt at a solution
    If I'm not mistaken: heat gained by ice = - heat lost by water
    [tex]Q_{ice} = -Q_{water} [/tex]
    [tex] \Rightarrow m_{ice}L_{ice} + m_{ice}c_{water} \Delta T = - m_{water}c_{water} \Delta T [/tex]
    [tex] \Rightarrow (0.25 kg)(3.33* \times 10^5 J/kg) + (0.25 kg)(4186 J/kg \cdot K)(T_{f} - 273.15 K) =
    - (0.6kg)(4186 J/kg \cdot K)(T_{f} - 291.15 K) [/tex]
    Which when I solve for [tex]T_{f}[/tex] gives me a ridiculous number.
    I've looked at the answer and it's 0.0 °C. What am I doing wrong?
  3. May 4, 2008 #2
    alphysicist
    Hi caesius,
    It appears not all of the ice has melted; so the heat absorbed by the melting ice is not
    (0.25)*3.33x10^5
    since only part of that mass has melted. How can you find out how much of the ice has melted?
  4. May 4, 2008 #3
    If I introduce an unknown mass of ice will I not have too many unknowns? I'm still stuck.
  5. May 4, 2008 #4
    alphysicist
    When you have a problem like this, probably the first thing to find out is if the ice completely melts or not. You can find this by calculating two separate things:
    total amount of heat loss to bring the water 18 degrees to zero degrees
    total amount of heat required to completely melt 250 grams of ice
    What do you get for these two numbers? Is there enough heat lost in the water going from 18 to 0 degrees to completely melt the ice?
    Once you have this information, that will tell you how to set up the general equation of heat lost=heat gained.
Similar Discussions: Latent Heat
  1. Latent heat (Replies: 3)
  2. Latent Heat (Replies: 1)
  3. Latent heat (Replies: 4)
  4. Latent Heat (Replies: 8)
  5. Latent heat? (Replies: 6)
Loading...
