Latex Bibliography
  • LaTeX
  • Thread starter NeoDevin
Main Question or Discussion Point
[SOLVED] Latex Bibliography
Whenever I create a bibliography in latex using
Code:
\bibliographystyle{plain}
\begin{thebibliography}{1}
\bibitem{Reference 1}Details about Reference 1
\bibitem{Reference 2}Details about Reference 2
\end{thebibliography}
It puts the title `References' above it. Does anyone know how to make it omit the title?
Thanks
Answers and Replies
72 views and nobody knows how to do it? I figured it was probably somthing simple.
f95toli
439
Presumably the solution is to find a bibliography style file that does not write out "Reference".
The only other option is to start redefining various parameters, but that is usually extremely messy so it is not something I would recommend.
Latex is only simple as long as you follow the "templates" (sty-files etc), really customizing the appearance of your documents can be quite a daunting task.
You can just put \renewcommand{\bibname}{} into your preamble, although because that's just renaming the title to be nothing, you get quite a bit of white space above your references which I'm not sure how you could get rid of, although it is a crude way to achieve what you want.
Thanks, I'll play with that, and maybe some negative vertical space to fix it up.
It didn't work, it told me
Error: ! LaTeX Error: \bibname undefined.
Oh are you writing an article as opposed to a report/book?
Try \renewcommand{\refname}{}
Perfect, thanks. Using
and then
\vspace{-11mm}
before the bibliography seems to be about perfect.
Thanks so much.
Related Threads for: Latex Bibliography
  • Last Post
11K
  • Last Post
  • Last Post
