Latex vs. MS Word/MathType: Which is Better for Writing Equations?
In summary, the conversation discusses the use of LaTeX as opposed to MS Word with MathType. While MathType is convenient and user-friendly, LaTeX offers a more professional and polished appearance in documents and is favored by scientists. Some users also mention TeXnicCenter and MikTeX as good options for using LaTeX on Windows, while others suggest LyX as a user-friendly frontend for LaTeX. Additionally, MathType is mentioned as being capable of converting equations into LaTeX code for use in LaTeX documents.
exequor
393
I'm in the process of getting Latex running on my system but I've been wondering whether I should. I read articles from all over the net but I still can't find solid reasons why I should use Latex as opposed to MS Word with MathType. Does anyone have solid reasons why it is better, apart from the fact that it is loved by scientists?
With latex one can directly write the text in the same style as it is printed in journals or many books.
LaTeX will obviously require you to learn a lot of code and how to format them. For example, with LaTeX you may know how to insert an integral, but maybe not how to insert all of the arguments. MathType has templates for the same math expressions and provides boxes where arguments are needed so you know if you're missing something. MathType has the same style as textbooks and journals since it is identical to LaTeX. Why not just download a trial and test it out?
is mathtype like lyx or some other "latex-editor"?
"MathType is an intelligent mathematical equation editor designed for personal computers running Microsoft Windows or the Apple MacOS. It’s an application that allows you to create complex equations through simple point-and-click techniques, and then use them in documents, Web pages, or markup-based systems like ATEXL and MathML. Using MathType in conjunction with a word-processing, page-layout, or graphics application, you can easily create tests and class notes, technical reports, view-graphs, research papers, dissertations, slides, and even entire books. MathType is also the professional version of the Equation Editor that comes with Microsoft Word, Corel WordPerfect and many other popular applications, and provides a seamless upgrade to the capabilities found in Equation Editor."
... sounds pretty accurate, I personally do most of my stuff nowadays with Mathtype (speed and to some extent compatibility), but save "serious" stuff for LaTeX. Mathtype exceeds the capabilities of the standard equation editor (e.g. in Windows office) easily, but IMO LaTeX is still the real deal with respect to appearance and "performance".
Yes, I agree. Nothing beats LaTeX but when it comes to speed, I'd go MathType.
LaTeX is free. LaTeX is portable, running on many platforms. LaTeX is written in plain text... and doesn't need a fancy editor to modify it.
Note that http://www.dessci.com/en/products/texaide/ is free...
and can paste LaTeX in a .tex file and an image of the equation (as a Windows Metafile image) into Word or PowerPoint.
This TeXaide program gives you the best of both worlds. I would still setup latex/mitex for whatever reason. It is perfect the way it is but maybe an integrated environment should be created where you just work like you do in MS Word. By the way, is there such a all-in-one program?
A vary nice implementation of LaTeX and an associated gui for a Microsoft box is Techniccenter: www.toolscenter.org
I have used it in the past and was very happy with it. Incidentally, I used Word with Mathtype for my doctral dissertatioon, fought the formating all the time, after my advisor made changes I converted everything over to tex, reworked all the equations and put out a final product which looked much better than anyone elses that year at my school. I found that Mathtype didn't handle the complex equations very well.
You mean the TeXnicCenter! :smile: I agree, it seems to be a good IDE.
I decided to try out TeXnicCenter with the MiKTeX package and I think it's exemplar! The documents look great. How is this program free?!
If only I could find a free gui driven plotting program that exports to .eps. Any suggestions? While we are on the subject of LaTeX...
Are you using windows or *nix?
If your using *nix you can get xmgrace and it works good.
I alternate between *nix and Windows. I'll try xmgrace on my *nix box, but I cannot use one at work, so I need a decent windows software also.
Can you install cygwin on your Windows box?
http://x.cygwin.com/
Mathtype is the full-blown version of Equation Editor, I think. I also believe It is also capable of converting the equation into LaTex code. I know many people who type their complicated equations using it, convert them to LaTex, and then cut-and-paste into their LaTex document.
Zz.
I finished setting up TeXnicCenter, Miktex, Ghostscript and Ghostview. I must say it gives you the kind of feeling you get when you leave VB and move to C++.
z-component said:
... MathType has the same style as textbooks and journals since it is identical to LaTeX...
Mathtype is not identical to LaTeX, and has a distinctly different style. In my opinion, the symbols look messy in comparison to the Computer Modern font used by default by LaTeX.
For a very nice LaTeX frontend, take a look at LyX (http://www.lyx.org" ). Whilst knowing the fundamental structure of LaTeX is sometimes useful, it is by no means essential, and amongst many other benefits makes typing formulae as easy as in MathType. Best of all, it's free and open source, as well as cross-platform.
Okay, I am searching for the answer to this as well for my thesis. I am batteling with my advisors that I can be competent enough in MS Word to create a document in less time and with less headaches than it does in LaTex. I have been using word for ages, and I consider myself a fairly advanced user, even though with 2007, there are still a ton of new things I need to re-learn how to do. I am convinced that MS Word 2007 along with the latest MathType is good enough to use for professional documents. I think if someone can invest the time learning LaTex, I think I can spend less time learning the advanced tools of MS Office 2007 and be similarly competent in something which has a greater future and more useful in the outside world.
profroopchan said:
...I am convinced that MS Word 2007 along with the latest MathType is good enough to use for professional documents. I think if someone can invest the time learning LaTex, I think I can spend less time learning the advanced tools of MS Office 2007 and be similarly competent in something which has a greater future and more useful in the outside world.
If you intend producing papers for scientific publications in the future, I would recommend learning LaTeX, as it is almost a standard across different publications, so the time spent learning would be well invested. Else I'm sure you could manage fine with Word. As a compromise, you could try LyX (as I mentioned above) - it greatly lessens the learning curve.
I don't think it is a fair comparison to say the Word has a "greater future" than LaTeX, as they function in very different ways, and in my opinion are not greatly in competition with each other.
What other functions, other than math equations does LaTex bring to the document creation process? What does people in other fields use? Fields which does not need the intense math equations. What editor does people who write books write in? I know LaTex is EXTREMELY powerful, so is C/C++. C++ can be even used to create some of the old MS Office programs, but just because it is so powerful does not mean that the end user will go use C++ to create their documents. What other options does people in other fields have?
On a fundamental level, the design of LaTeX means that the user will write down a document semantically, rather than deal with formatting directly. That is, you would never set something as "bold, size 14", but as a "heading". These tags are then tied to a 'style' template, of which you will most often use ones built-in to LaTeX (alternatively your department may have their own). Moreover, all spacing is calculated when the finished document is generated, meaning that very little intervention is required to end up with a professionally laid-out document. There is also extensive cross-referencing and Bibliographic support, very useful for longer documents.
LaTeX can of course be used in other fields, although I don't believe it is that common. Whilst many scientific textbooks are written in LaTeX (one sign is the use of the 'computer modern' typeface), in other fields it would depend on the publisher.
I do not understand the spacing that you speak about, but doesn't MS Word have 'style' templates as well? You create a style called heading, which contains "bold, size 14", and for all headings, you just click "Heading". With this, you add a "table of contents" and it automatically number your table of contents for you. I am wondering if MS Word 2007 supports any plugins other than MathType would would automate any other short comings it may have. With a little time invested, I can become a professional Word 2007 user in no time. I have mastered previous versions of MS Word before.
So, what program does people in other professions use to produce documents?
I am a very large fan of the LyX project. It aims to be a WYSIWYM (What you see is what you mean) editor that uses LaTeX. It requires a distribution of LaTeX installed on the computer (MiKTeX serves me well on Windows, and TeXLive on Linux/UNIX), and it supports direct entry of TeX code for complicated equations.
I used to write my lab reports (I am still a student) in LaTeX code using LEd (another good editor) or Vim, but now I type every typed assignment I receive in LyX.
One feature I like about [tex]\LaTeX[/tex] is that it is a pure-text file, as opposed to a binary format [which requires Word or something fancy]. (Maybe the newer versions of Word use a different format now.)
At times, I might decide to make changes to a set of equations (e.g. use "y" instead of "x" everywhere). I would think it would be easier to make such changes in a LaTeX file than in a Word file [in which the equations are rendered with MathType or Equation Editor]. (Certainly, one would need more than a simple search and replace so as not to accidentally end up with "As an eyample...". I might write a script (in Perl, Python, or sed) to make the needed changes.)
In addition, I often write programs in Python or Maple that write [tex]\LaTeX[/tex] statements for very complicated sets of equations or create tables (generated from data). A point-and-click interface for such equations would be tedious to use... especially when possibly many changes are needed.
Are there any free converters to convert from MS Office 2007 to LaTex code? I already wrote a lot of things and equations in MS Office and would like to convert it to LaTex code.
http://www.tug.org/utilities/texconv/pctotex.html#wordtolatex
  • #31
Also, I'd like to just add that the majority of equations I put into latex, I just write up in mathematica (very quick) and copy as LaTeX (theres also a MathML copy) and just paste it into LEd. Saves a lot of time.
1. What is the main difference between Latex and MS Word/MathType for writing equations?
The main difference between Latex and MS Word/MathType is the underlying language used to create equations. Latex uses a markup language, while MS Word/MathType uses a graphical user interface. This means that Latex requires knowledge of coding and commands, while MS Word/MathType allows for a more user-friendly experience.
2. Which program is more commonly used for writing equations?
Latex is more commonly used for writing equations, especially in the scientific and mathematical communities. It is considered the standard for typesetting complex equations and formulas.
3. Is one program more accurate than the other for writing equations?
Both Latex and MS Word/MathType can produce accurate equations. However, Latex is known for its precise typesetting and ability to handle complex equations and symbols more efficiently.
4. Which program is more time-efficient for writing equations?
This ultimately depends on the user's proficiency with the programs. For those who are familiar with Latex's coding language, it may be more time-efficient. However, for those who are more comfortable with a graphical user interface, MS Word/MathType may be quicker.
5. Can equations written in one program be converted to the other?
Yes, equations written in Latex can be converted to MS Word/MathType and vice versa. However, the conversion may not always be perfect, and some formatting may need to be adjusted.
  • STEM Career Guidance
  • Electrical Engineering
