Launch angle of projectile
In summary, at .5 of its maximum height, the speed of a projectile is .75 of its initial speed. Its launch angle was .5.
un0rth0d0x
At .5 of its maximum height, the speed of a projectile is .75 of its initial speed. What was its launch angle?
(1)V1y = V0y - gt
(2)y1-y0 = V0yt - .5gt^2
The part that really bothers me is the second part of the first statement: "the speed of a projectile ..." What is the speed of a projectile? What do i denote that as? V?...
So far I've gotten the following:
initial velocity y-component:
knowing: V1y = 0 (at max height)
V1y = V0y - gt
Voy = gt
substitute V0y into equation (2) gives max height:
y=.5gt^2
Any assistance would be most appreciated.
Thanks!
Hi un0rth0d0x,
welcome to PF. Hope we can help you here with you physics questions.
Since the projectile is subject to just a conservative force this problem can be solved using energy considerations.
Have you done the relevant theory concerning energy conservation yet?
Unfortunately I have not... This problem is sectioned in basic kinematics... So I'm totally oblivious to energy conservation.
Sorry
The "speed" of the projectile [tex]v[/tex] has two components [tex]v_x,\ v_y[/tex] of which the y-component changes and the x-components stays the same throughout the trajectory.
andrevdh: just out of interest, how would you sort this out using energy considerations alone? I have had a quick bash, and can't see an obvious way to do it...
anyway, I would approach this problem with kinematic equations of motion.
In situations like this, remember that if you're given letters or proportions then you effectively "know" the value, don't get scared just because there isn't an actual number. It seems that's exactly what you've done, so good on you.
Second, you should realize that any projectile motion problems involving no air resistance are simply parabolic geometry problems in disguise
third, always but always draw a diagram! it helps to visualise the problem.
Now, if you have the x components and the y components, what shape can you make with them?
As we know the speed of a projectile changes during its motion. The problem therefore says that the speed [tex]v[/tex] (the x- and y- components combined) at half maximum height will be 3/4 of the launching speed [tex]v_0[/tex].
Remember that the x - velocity component can be written as
[tex]v_x = v_o \cos(\theta _o)[/tex]
while we need to solve for
[tex]\theta _o[/tex]
energy at bottom:
[tex]0.5mv_o ^2[/tex]
energy in middle:
[tex]\frac{9}{32}mv_o ^2 + 0.5mgh[/tex]
energy at top:
[tex]0.5mv_o ^2 {cos}^2(\theta_o) + mgh[/tex]
The problems says that the speed at half the maximum height is 3/4 of the initial speed. Since the speed of the projectile is the combination of both speed components we can say that
[tex]v^2 = v_y ^2 + v_x ^2[/tex]
at half the maximum height this therefore becomes
[tex](\frac{3v_o}{4})^2 = v_y ^2 + v_o ^2 {cos}^2(\theta_o)[/tex]
Can you solve it now?
Thanks for your help!
-d0x
Sorry to bump such an old thread.
I am trying to figure out this exact question, and I see what steps they have taken in this thread, but I don't understand where to go from there. Any additional assistance would be appreciated, I am just plain stuck on this.
Thanks!
[tex]
[/tex]
Now we have one equation with two unknowns, so try to express vy in terms of v0. Hint: use vf^2 - vi^2 = 2ad. Twice.
1. What is the launch angle of a projectile?
The launch angle of a projectile is the angle at which it is released or fired from its initial position. It is measured from the horizontal axis to the direction of the projectile's motion.
2. How does the launch angle affect the trajectory of a projectile?
The launch angle is a critical factor in determining the trajectory of a projectile. A higher launch angle will result in a longer distance traveled, while a lower launch angle will result in a shorter distance but potentially a higher maximum height. The optimal launch angle for maximum distance is typically between 45-60 degrees, depending on other factors such as air resistance and initial velocity.
3. How is the launch angle calculated?
The launch angle can be calculated using trigonometry, specifically the tangent function. It is the ratio of the vertical height reached by the projectile to the horizontal distance traveled. The formula is θ = tan⁻¹ (y/x), where θ is the launch angle, y is the vertical height, and x is the horizontal distance.
4. Can the launch angle be adjusted to increase the range of a projectile?
Yes, the launch angle can be adjusted to increase the range of a projectile. As mentioned earlier, a higher launch angle will result in a longer distance traveled. However, there is an optimal angle for each situation, and adjusting the launch angle too high or too low may result in a shorter distance traveled.
5. What factors influence the optimal launch angle for a projectile?
The optimal launch angle for a projectile can be influenced by various factors, including air resistance, initial velocity, and the shape of the projectile. Air resistance can decrease the optimal angle, while a higher initial velocity or a more aerodynamic shape can increase it.
21K
