1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Launching from Mars
  1. Oct 25, 2008 #1
    The Radius of Mars is R_m
    its mass is m
    The radius of Mars (from the center to just above the atmosphere) is R_m and its mass is m. An object is launched from just above the atmosphere of mars.
    A) what is the object's initial velocity if its final velocity is V_f
    2. Relevant equations
    a=(v^2)/R <--wat v is this?
    W=deltaKE
    3. The attempt at a solution
    i dont know how to start
    im thinking i need to calculate the gravity from mars?
    but if all im given is mass and radius
    how do i calculate it?
    i need to find the amount of work done by mars right?
  3. Oct 25, 2008 #2
    I think you need to use Newtons universal gravity law....
    F=(GM1M2)R^2
    This means that the force is equal to the constant G (6.67X10^-11) multiped by both masses, all of this divided by the distance between them squared.
    this will get you the Force.
    So now you have force, you know that Fnet=ma, so the acceleration will be {(Gm1m2)/R^2}/m
    finally, Vf^2-Vo^2=2a(x), so you simply solve using the above equation as a, and they just say to use Vo i believe
    I dont think this is a problem you shoudl get numbers for, it seems like a concept that you just want to work through with different equations and not really use numbers.
    This is just from what I understand.
    Good luck!
  4. Oct 26, 2008 #3
    im solving for Vo
    the object is launched from above the atmosphere
    im given the distance between object and mars (R_m)
    and I'm given the weight of mars (m)
    and I'm given Vf of the object
    so what I did (but I did not get a good answer)
    was use
    F=Gm1m2/r^2
    m1 = object
    m2 = mars
    r=distance from mars and object
    so the F equals
    F= Gm1m2/(R_m)^2
    and then I think I'm suppose this formua
    total W = deltaKE
    F*d = .5m1vf^2 - .5m1vo^2
    but how do I find d?
    I think this is right
    how do I use
    vf^2-vo^2 = 2a (x) <--whats x ?
  5. Oct 26, 2008 #4
    With what you have you won't be able to find work and finding energy is also not going to work out. I can't help if you dont supply numbers, I solved it simply with the units, plugging the numbers in should have yielded the answer.
    From what I can understand by your explanation that is anyway, it doesn't seem like work is in anyway involved.
Similar Discussions: Launching from Mars
Loading...
