Expanding f(z) in a Laurent Series
In summary, the conversation discusses expanding the function f(z)=1/z(z-2) in a Laurent series that is valid for the annular region 0<|z-3|<1. The equations for this expansion are provided, including the Taylor series for 0.5(1/(z-2)) and the question of why the answer for 0.5(1/z) is not 1/2(z-3) *∑((-1)k*(3/(z-3))k). The significance of the annular region is also mentioned as being important in understanding the answer to the original question.
Pouyan
103
Expand the function f(z)=1/z(z-2) in a Laurent series valid for the annual region 0<|z-3|<1
I know 1/z(z+1) = 0.5(1/(z-2)) - 0.5(1/z)
Taylor for 0.5(1/(z-2)) is : ∑(((-1)k/2) * (z-3)k) (k is from 0 to ∞)For the second 0.5(1/z) the answer is a Taylor : ∑((1/6)*(-1/3)k * (z-3)k)
But why the answer for 0.5(1/z) is not 1/2(z-3) *∑((-1)k*(3/(z-3))k) (k is from 0 to ∞) ?
The correct answers for both are from Taylor but I thought for the second is a Laurent
Did you consider the annular region you were given?
Likes Pouyan
Yes but I can't draw it in this page !
You don't need to draw it.
What's the significance of the annular region? Why did the problem bother giving it to you? If you understand that, it's the answer to your original question.
What is a Laurent Series?
A Laurent Series is a representation of a complex function, f(z), as an infinite sum of terms. It is used to express a function in terms of its power series expansion around a point, including both positive and negative powers of (z-a), where a is the center of the series.
Why is it important to expand f(z) in a Laurent Series?
Expanding f(z) in a Laurent Series allows for a better understanding of the behavior of a function in a given region. It can also help with calculating integrals and derivatives of the function, as well as finding the zeros and poles of the function.
What is the difference between a Taylor Series and a Laurent Series?
A Taylor Series only includes positive powers of (z-a), whereas a Laurent Series includes both positive and negative powers. This allows for a Laurent Series to be used for functions with singularities or poles, while a Taylor Series is only valid for functions that are analytic in a given region.
How do you find the coefficients in a Laurent Series?
To find the coefficients in a Laurent Series, one can use the formula for the nth derivative of f(z) at the center, a, divided by n!, multiplied by (z-a)^n. Another method is to use the Cauchy Integral Formula to calculate the coefficients.
What is the region of convergence for a Laurent Series?
The region of convergence for a Laurent Series is the set of all points in the complex plane where the series converges. This can be determined by finding the radius of convergence, which is the distance from the center, a, to the nearest singularity or pole of the function.
