Law of conservation of energy
  1. Dec 30, 2012 #1
    A particle of mass 0.400 kg is shot from P . The particle has an initial velocity vi with the horizontal component of 30 m/s. The particle rises to a maximum height of 20 m above P. Using the law of conservation of energy, determine :
    (a) the vertical component of vi
    (b) the work done by the gravitational force on the particle during its motion from P to B
    (c) the horizontal and the vertical components of the velocity vector when the particle reaches B
    P is in height of 60 m.
    2. Relevant equations
    Ek = -Ep
    3. The attempt at a solution
    a.)
    1/2mv2 = -(m*g*h)
    1/2v2 = -(-9,8*20)
    v2 = 2*9,8m/s2*20m
    v=19,7 m/s¨
    b.)
    A=m*g*h
    A=0,4kg*9,8m/s2*60m
    A=294 J
    c.)
    1/2mv2 =-(m*g*h)
    1/2v2=-(9,8*-80)
    v2=2*9,8m/s2*80m
    v=39,5m/s
    I do not know if I should calculate with minus Ep. And then if the acceleration should be with minus in a.) and in c.) the acceleration positive and height negative?
  3. Dec 30, 2012 #2
    I am a bit confused. You say the particle reaches a max heighth of 20 m but use use 60 m in the solution. Seems like part a is correct. The first statement of part b is correct but the second line makes no sense to me.
  4. Dec 30, 2012 #3
    Sorry, it is confusing. The particle is shot from P (P is in the height of 60m above the ground) and then particle rises to height of 20m above P so the particle is in the total height of 80m above the ground and then reaches the ground - B . I hope that I made it clear.
  5. Dec 30, 2012 #4
    haruspex
    You can choose to measure distance upwards or downwards - entirely up to you, so long as you are consistent. Note that swapping swaps the sign on both acceleration and height, so leaves the sign of PE unchanged.
Similar Discussions: Law of conservation of energy
Loading...
