Law of Impulse Preservation in Positron-Electron Annihilation
  • Thread starter Physicsissuef
  • Tags
    Impulse Law
In summary: No, since the general expression for momentum is related via:E^2 = p^2c^2 + m^2c^4 So for massless particles (as the photon):P = E/c
Physicsissuef
908
Annihilation (connecting positron and electrons) gives us 2 gamma rays. I.e
[tex]^{0}_{-1}e+ ^{0}_{+1}e \rightarrow 2 \gamma[/tex]
In my textbook says:
mytextbook said:
The pair positron-electron is processing according to the laws of preservation of the energy and the impulse...
Impulse of the gamma quant is equal to the both particles, same as the nucleus (which is in interaction with), but, the summary impulse is same before and after the process... That is confirmed in The Wilson's chamber which is inside of magnetic and electric field. In that field the electron and the positron like opposite charged particles are going into opposite directions.
Now my question, what is law of preservation of impulse??
Why [tex]e[/tex] is written like [tex]^{0}_{-1}e[/tex] instead of [tex]e^-^1[/tex] or something??
1. Your text must be translated from one language to another.
I think when it says "preservation of impulse", it just means conservation of momentum.
2. That clumsy notation is what is used in nuclear physics.
It means nucleon number=0. The subscripts are the charge.
That notation is almost never used for simple electrons.
Yes, I mean conservation of momentum... What is that?
Conservation of momentum means that the total momentum is the same after the reaction as before. For a particle with mass the momentum is
[tex]\textbf{p}=m\textbf{v}[/tex]
where m is the mass and v the velocity of the particle.
For photons:
[tex]|p|=\frac{E}{c}[/tex]
where E is the energy and c the speed of light (in vacuum).
in this case, it imply for the gamma ray? So
[tex]
|p|=\frac{E}{c}
[/tex] is the one that we look for, right?
Yes in the final state you have two phonons, but in the initial state you have one positron and one electron and they have mass.
so mv=[itex]\frac{E}{c}[/itex], right?
and why p is in long brackets i.e |p| ?
is it same with conservation of energY?
Momentum is a vector. It has both magnitude and direction. The vertical bars indicate that we are talking about the magnitude only.
conservation of energy and conservation of impulse are same in this casE?
[tex] E^2 = p^2c^2 + m^2c^4 [/tex]
[tex] P = E/c [/tex]
There is no way that you can get mv = E/c
Nope.
Conversvation of total energy and conservation of momentum/impulse is not the same thing.
Physicsissuef said:
Why [tex] e [/tex] is written like [tex]^{0}_{-1}e [/tex]
or something??
They follow the nuclear notion, as pam pointed out.
E is energy, so what is the difference?
i) momentum is a vector, energy is a scalar.
ii) you have massive particles on the Left Hand Side (LHS) of the reaction.
So conservation of energy is for the gamma ray, and conservation of momentum for the particles, right?
NO
conservation of energy for the whole reaction &
consercation of momentum for the whole reaction!
momentum(LHS) = momentum(RHS)
Energy(LHS) = Energy (RHS)
Both equations must be fullfilled.
RHS = right hand side
LHS = left hand side
And what is conservation of impulse, said with simpler words? Maybe some analogy?
impulse is just change of momentum. That is the real definition of it. So it can't be conserervation of impulse.
Pam wrote:
"1. Your text must be translated from one language to another.
I think when it says "preservation of impulse", it just means conservation of momentum." in pots #2
And sometimes, authors uses impulse sloppy instead of momentum. So I confirm what Pam wrote, what is meant is conservation of momentum.
but what is the impulse of the mass objects? Massless objects like gamma ray, the impulse is that line (which is not straight)
whar are you talking about? Impuse is that line (which is not straight)?! :confused:
Instead of talking about impulse, let's just use the word momentum in the future, to avoid misunderstanding ;)
The momentum of massive obejcts is (if non relativistic) p = mv
if relativistic particles, use relativistic kinematics.
And how it says that the momentum is same before and after the reaction (when at the start we have massive objects and at the end massless objects)? First we have p=mv and second p=E/c^2, right? So those two should be equal?
well yes, in this specific case, you would have something like: 2*mv = 2E/c
I wanted to stress that (i) momentum is vectors and (ii) how momentum relations works.
You wasn't specific enough when you made your statement "mv=E/c", I think.
and why p=E/c. I don't figure out what is the logic. In m*v there is mass*change in velocity... But In p=E/c I don't see much the logic...
a photon is massless.
THIS is the formula for momentum that ALWAYS holds:
As i said in post #12 ...
E is total energy, i.e kinetic energy + rest energy (mass) and potential energy.
¤ so for massive particles, non relativistic ( v < 0.1c) we get (after some work): p = mv
¤ and for mass-less particles we get: p = E/c
How you got: "m*v there is mass*change in velocity" is for me a riddle, v is not change i velocity.. v is the velocity.
and what is p?
Physicsissuef said:
and what is p?
What has p resembled this entire thread?
And if I say that:
"THIS is the formula for momentum that ALWAYS holds:"
And says what E is, can't you draw the conclusion what p is then?
I even 'derived' this for you from that perticular formula:
p = mv & p = E/c
So, again, what do you think p is?
EDIT: If you want to know how [tex] E^2 = p^2c^2 + m^2c^4 [/tex] is derived, borrow books in special relativity from your library and/or google.
p=change in momentum ?
post #4
Ok, my mistake, but... If the speed of the electrons and their mass is same, than the momentum will be equal to 0 kg*m/s before the collision... Also after the collision will be
0 kg*m/s if there is conservation of momentum. Will that momentum correspond to the gamma ray?
Ok you mean if their speed is equal in magnitude and in direction, and their masses is the same?
Again, one must use vector notation, momentum is really a vector (see again post #4)
[tex] \vec{p} = \sum _{i=1}^3p_i\hat{x}_i = m \vec{v}[/tex]
where the hat-x is unit vector for the i:th coordinate.
So from [tex] E^2 = p^2c^2 + m^2c^4 [/tex] one gets the total magnitude of momentum:
[tex] p = |\vec{p}| = \sum _{i=1}^3p_i [/tex]
Then one has to perform all the vector algebras and so on.
  • #31
How will I know all those this for the gamma ray? I mean, will the momentum of the gamma ray be 0?
  • #32
You have one more equation; conservation of energy...
We have as many unknowns as equations -> the system can be described completely.
Now this thread has gone to discussing basic fundamental Newtonian mechanics. I really don't have the time to explain this for just one person when there are thousands of textbooks and internet tutorials about linear Newtonian dynamics.
Ps. it is GAMMA RAYS, you have two of them, not just one.
  • #33
Yes. IT is gamma rays. As we said conservation of energy and conservation of momentum are two different things... So will the momentum of gamma ray be zero?
  • #34
yes they are completley different things, but since both must be fullfilled, we can get information of the quantities need in the equation for momentum conservation (and vice versa, it depends on which quantities that are given in the orginal problem).
have you not done physics courses yet?..
No, the momentum of a gamma ray will not be zero, such things don't even exists.
Think about it, if momentum is zero, then E is zero. If E = 0, then it does not exists. E of a gamma ray is also related according to:
[tex] E = h\nu [/tex], where [tex] \nu [/tex] is the frequency of that gamma ray. h is a constant. So [tex] \nu = 0 [/tex] , and the gamma ray does not exist.
Even if it WAS possible to have zero energy photons, energy will not be conserved in this reaction.
HOWEVER the total momentum of the RHS of the reaction must be equal to the 0-vector:
[tex] \vec{0} = \vec{p}_{\gamma 1} + \vec{p}_{\gamma 2} [/tex]
(if now the electron and positron on the LHS has the same mass and moves with equal magnitude of velocity and in exactly opposite directions)
As an example, this might be the case, that from the conservation of energy equation that:
[tex] E_{\gamma 1} = E_{\gamma 2}[/tex]
Then the gamma rays must be moving at exactly opposite directions in order to maintain momentum conservation, i.e:
[tex] \hat{x}_{\gamma 1} = - \hat{x}_{\gamma 2} [/tex]
Where [tex]\hat{x} [/tex] is an arbritrary direction-vector.
I don't think I can't make myself clearer without writing a short book about this topic.
  • #35
Yes, in my textbook says that they are moving in opposite directions... But still can't understand. I found this site which states for mass http://www.glenbrook.k12.il.us/gbssci/Phys/Class/momentum/u4l2b.html
And it says that the momentum will be zero, if we have two same objects (same mass and same velocity, but moving in opposite directions)...
  • High Energy, Nuclear, Particle Physics
