Understanding Newton's First Law of Motion: Exploring the Concept of Inertia
In summary, the conversation discusses an example of Newton's first law of motion, where a pile of dirt falls off a shovel when it makes a sudden stop. The net force on the object (dirt) must equal zero for this to happen, which can be achieved when the applied force is canceled out by the force of friction. The inertia of the dirt causes it to continue moving in a constant velocity until it falls due to gravity. A sudden deceleration of the shovel can cause the dirt to break loose and slide off, as predicted by Newton's laws.
Girix
Let's say a shovel carrying a pile of dirt is moving right and then make a sudden stop. The dirt then falls off the shovel moving in the same direction as the shovel was moving. This is an example of Newton's first law of motion. For this to happen, the net force must equal 0 on the object, so when does the net force on the object (dirt) equal zero? Is the net force of the dirt pile zero when it is on the shovel? If so, then how would it fall off the shovel if the shovel makes a sudden stop? The net force would equal zero because the applied force is canceled out by the force of friction on the shovel. Or is the net force unequal to zero when it is flung off the shovel, which means the applied force overcomes the frictional force?
The net force is zero when the shovel (and dirt along with it) isn't accelerating. As soon as you go to stop the shovel, you have to apply a net force, which accelerates it in the opposite direction as it is moving, thus slowing it down. If the net force, which is transferred through the shovel to the dirt, is too great, then the dirt falls off of the shovel (either by sliding off or by the pile "toppling" over).
So, the net force being applied to the shovel (and the dirt) turns zero once the shovel stops accelerating, therefore the dirt has a net force of zero, which means the inertia causes it to continue moving in a constant velocity to the right until it falls down due to gravity, correct?
If you've ever shoveled dirt, you should know that's not how it works.
For sticky earth, you give the shovel a large acceleration. A backwards jerk at the release point. This exploits Newton's second law, F=ma. A large acceleration requires a large force. More force than the adhesion between Earth and shovel can sustain. The dirt breaks loose.
Having broken loose, there is little force left acting on the dirt. It continues in a free fall trajectory toward the pile where you've aimed it. Except for gravity, that's pretty much Newton's first law in action.
Let's say that, starting from rest, you slowly accelerate the shovel and dirt up to some velocity and then cease applying any net force. The shovel and dirt both continue their movement with no change in velocity. Then, you suddenly pull backwards (or sideways) hard, such that you quickly decelerate the shovel. The dirt, being held onto the shovel only by friction and together with relatively weak forces, cannot stay together under the net force the shovel is trying to apply to it (this force being transferred from your hands through the shovel to the dirt). So it falls apart and slides off of the shovel, as Newton's laws tell us it should.
Likes CWatters
What is Newton's First Law of Motion?
Newton's First Law of Motion, also known as the Law of Inertia, states that an object at rest will remain at rest and an object in motion will remain in motion with a constant velocity unless acted upon by an external force.
What is the concept of inertia?
Inertia is the tendency of an object to resist changes in its state of motion. This means that an object will continue to stay at rest or in motion unless a force acts upon it.
How does Newton's First Law of Motion apply to everyday life?
Newton's First Law of Motion can be seen in everyday life. For example, when riding in a car and it suddenly stops, your body continues to move forward because of inertia. Similarly, when a ball is rolled on a smooth surface, it will continue to roll in a straight line unless acted upon by a force such as friction.
What are some examples of inertia?
Some examples of inertia include a book resting on a table, a car moving at a constant speed on a straight road, and a person sitting in a moving train.
How does understanding Newton's First Law of Motion help us in science?
Understanding Newton's First Law of Motion is essential in science as it helps us predict and explain the motion of objects. It also forms the basis for understanding the other laws of motion developed by Isaac Newton.
  • Mechanics
  • Mechanics
