• Support PF! Buy your school textbooks, materials and every day products Here!
Law of motion problem
  • Thread starter Zynoakib
Q69
F=ma
v = u + at
v^2 = u^2 + 2as
s = ut + (1/2)at^2
Find the deceleration by friction:
F = ma
0.1 = (0.2)a
a = 0.5 ms^-2
and the acceleration of the mug would be 3 - 0.5 = 2.5 ms^-2
Find the time required for the tablecloth to travel 30 cm
u = 0, , s = 0.3, a = 3, t = ?
s = ut + (1/2)at^2
0.3 = (1/2)(3)(t^2)
t = 0.447 s
Find the displacement of mug within 0.447s
t = 0.447, s = ?, u = 0, a = 2.5
s = ut + (1/2)at^2
s = (1/2)(2.5)(0.2)
s= 0.25 m , but the answer is 0.06 m
Thanks!
Answers and Replies
jbriggs444
2019 Award
8,756
3,520
F = ma
0.1 = (0.2)a
a = 0.5 ms^-2
In which direction is the mug accelerating? In which direction does friction between mug and tablecloth act? And what, exactly, do you mean by "a" here?
65
s = ut + (1/2)at^2
s = (1/2)(2.5)(0.2)
Thanks!
Is the acceleration of block 2.5m/s-2 in ground frame ?
Hope this helps .
jbriggs444
2019 Award
8,756
3,520
Is the acceleration of block 2.5m/s∧-2 in ground frame ?
If you draw a free body diagram for the block, what forces act on it?
Likes Zynoakib
65
2.5m/s-2 is acceleration of block relative to cloth .
jbriggs444
2019 Award
8,756
3,520
Good. And its acceleration relative to the ground is?
Likes Zynoakib
65
0.5m/s-2 - Thanks jbriggs444 .
why is the acceleration of the mug relative to the ground not (2.5 + 3) because the acceleration of the tablecloth is 3 and the mug is sitting on it and accelerate with 2.5 ms^2, so the acceleration of the mug relative to the ground should be 5.5 ms^2
but even if I use a = 0.5 to calculate, I still cannot get the answer. Why's that?
65
Okay - you seem to be confused .
Try answering these questions :
then
Acceleration of block relative to cloth is ?
and then
65
Use a = 0.5m/s2 only in your last step - you will get your answer .
s = ut + (1/2)at^2
s = (1/2)(2.5)(0.2)
Thanks!
Likes Zynoakib
Thanks, I have got the answer!
But if I want to make the calculation process easier (without the free body diagram), can I just think it in this way?
Since the friction between the mug and the tablecloth is 0.1N, meaning that the force transferred from the tablecloth to the mug for the mug to move can only be 0.1N, so I should
F = ma
0.1 = 0.2a
a = 0.5 ms^-2
65
F = ma
0.1 = 0.2a
a = 0.5 ms^-2
Force is not transferred , it is exerted . And no , you don't need the FBD for this question - it was only for you to visualize a bit better .
The rest is fine .
Likes Zynoakib
Your working is wrong.
The correct solution is:
mass of mug = 200g = 0.2kg
mug located = 30cm = 0.3m (from the edge of the table)
Acceleration of cloth = 3m/s^2
Using s = ut + 1/2at^2
Finding time:
0.3 = 0+1/2*3*t^2
t = 0.2 sec
Finding the how far mug can move.
s = ut + 1/2at^2
s = 0 + 1/2x3x(0.2)^2
s = 0.06m
The answer is 0.06m.
65
Finding time:
0.3 = 0+1/2*3*t^2
t = 0.2 sec
You've made a mistake here - t2 = 0.2 sec .
Also , try to not solve the entire question - You can read about this in the guidelines .
haruspex
Insights Author
5,414
Finding time:
0.3 = 0+1/2*3*t^2
t = 0.2 sec
s = ut + 1/2at^2
s = 0.06m
That's completely wrong.
First, the given distance is not to the edge of the table, it's to the edge of cloth.
Second, your calculation of the time would find how long it takes for the cloth to move .3m. This does not tell you where the mug is in relation to the cloth at that time.
Third, you then used the acceleration of the cloth as though it were the acceleration of the mug. The only reason you did not end up with an answer of 0.3m is your fourth error, confusing t with t2, as Qwertywerty noted.
Fwiw, the quickest way is to note that the acceleration of the mug is 1/6 that of the cloth. Since t2 is the same for both, it travels 1/6 of the distance. The difference between the two distances is 0.3m.
Related Threads on Law of motion problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
