Solve Jet Mass Problem w/ Laws of Motion - HELP Needed ASAP!
In summary, the jet can be catapulted from 0 to 155 miles per hour in 2 seconds. If the average force exerted by the catapult is 5.10 * 10^6 Newtons, the mass of the jet is 138.6 meters.
mamelancon84
Been struggling wih this problem all afternoon.
On an aircraft carrier, a jet can be catapulted fom 0 to 155 mi/hr in 2.00 sec. If the average force exerted by the catapult is 5.10 * 10^6 Newtons, what is he mass of the jet?
We converted the velocity into meters/second and got 69.276 meters/second
initial velocity = 0
initial X = 0
final X = (initial X) + (velocity of X)(time)
= 0 + 69.276(2.00)
= 138.6 meters
We don't know where to go from here...Summer classes. Test every Friday! NEED HELP ASAP!
Thanks
Write down everything the problem gives you.
F = 5.1 * 10^6 N
m = ?
[itex] \Delta [/itex]V = 69.276m/s
[itex]\Delta[/itex]t = 2s
What do you think comes next? You're trying to find M.
Ok, you know a force made by the catapult produces an acceleration, so the jet will get from 0 to 155 in 2 seconds, you can find the acceleration (throught its definition) and then use Newton's 2nd Law.
That's too simple. If we were to use F=ma, acceleration would most likely be -9.8 m/s^2. then that would be 5.10 *10^6N/ -9.8m/s^2
But what is the time used for?
We were given this equation: X(final) = X(initial) + velocity of x * time + .5(acceleration)(time^2)
Where we are confused is we were never given an angle that it was catapulted, or a distance to go by, so we are stuck on this next step?!?
The formula was introduced earlier in the chapter, and it is something we have been using in other problems. I assume that is what we are supposed to be using.
You believe the airplane doesn't run a horizontal trajectory before taking off?, This problem, indeed, has several simplifications, i imagine the purpose was what Whozum and i suggested.
You need to use the impuls equation which I hinted at already. Acceleration would not be 9.8m/s^, it would be 69.276/2 = 34.638m/s^2.
[tex] F\Delta t = m\Delta v [/tex]
edit: clarificatoin
Newton's 2nd Law
[tex] F = ma [/tex]
Average acceleration can be expressed as
[tex] a = \frac{\Delta v}{\Delta t} [/tex] which follows directly from it's definition. Plug that into the above to get what I just gave you.
Thank you so much! Really appreciate it...don't you hate when its staring you in the face :(
What is the Jet Mass Problem?
The Jet Mass Problem is a physics problem that involves calculating the mass of a jet using principles of motion and force.
Why is it important to solve the Jet Mass Problem?
Solving the Jet Mass Problem allows scientists and engineers to accurately determine the weight and mass of a jet, which is crucial for safe flight operations and fuel efficiency.
What laws of motion are used to solve the Jet Mass Problem?
The Jet Mass Problem can be solved using Newton's laws of motion, specifically the second law which states that the force applied to an object is equal to its mass multiplied by its acceleration.
What is the process for solving the Jet Mass Problem?
The first step is to gather all relevant information, such as the jet's velocity and the force applied to it. Then, using the equation F=ma, solve for the mass of the jet.
Are there any real-world applications for solving the Jet Mass Problem?
Yes, solving the Jet Mass Problem has real-world applications in aviation and aerospace industries, as well as in understanding the fundamental principles of motion and force.
