Physics Homework: Calculating Motorcycle Jump Distance Without Air Resistance"
  • Thread starter J89
  • Tags
    Motion
In summary, the physics professor attempted to jump across a river on a motorcycle with a takeoff ramp inclined at 53 degrees. Ignoring air resistance, the professor needed to have a certain speed at the top of the ramp to make it to the far edge of the bank. If his speed was only half of this value, he would land somewhere else. The equations for projectile motion and a drawing were used to solve for the necessary speed and landing location.
J89
30
A physics professor is attempting to jump across a river on a motorcycle. The takeoff ramp was inclined at 53 degrees, the river was 40 m wide, and the far bank was 15 m lower than the top of the ramp. Ignoring air resistance, a) what should his speed have been at the top of the ramp to have just made to the far edge of the bank. If his speed was only half the value found in a), where did he land?
vx=v0cosa0
vy=vysina0
I tried a bunch of methods..all came out wrong:( Help please. I made a drawing for reference..
Can you find an equation of projectile motion which gives the relation between x-displacement, y- displacement, angle of projection and initial velocity?
No not really :frown:
OK.
y = x[tan(theta)] - g*x^2/2[Vo*cos(theta)]^2
1. What is leaping motion?
Leaping motion refers to a type of movement where an object or organism propels itself off the ground in a sudden upward or forward motion.
2. What causes leaping motion?
Leaping motion is typically caused by an external force, such as muscle contractions or the release of stored energy, that propels an object or organism into the air.
3. What are some examples of animals that use leaping motion?
Some common examples of animals that use leaping motion include frogs, kangaroos, grasshoppers, and some species of birds.
4. How does leaping motion compare to other types of movement, such as running or swimming?
Leaping motion is different from running or swimming in that it involves a sudden and forceful movement off the ground, rather than a continuous motion. It also typically requires more energy and coordination.
5. Can leaping motion be applied to human movement?
Yes, leaping motion can be applied to human movement, such as in sports like long jump or high jump. However, it is not as efficient or commonly used as other types of movement such as walking or running.
