Homework Help: Length Contraction Question
  1. Oct 5, 2009 #1
    A spaceship travels past a planet at a speed of 0.80 c as measured from the planets frame of reference. An observer on the planet measures the length of a moving spaceship to be 40m.
    a)How long is the spaceship, according to the astronaut?
    b) At what speed would the spaceship have to travel for its relativistic length to be half of its "proper " length?
    2. Relevant equations
    L = Lo sqrt(1 - v^2/c^2)
    3. The attempt at a solution
    = 40 m sqrt {1 - (o.80)^2/c^2}
    = 40 m (0.6)
    = 24 m
    b) For this question im not too sure what to do
    this is all i can think of:
    i rearranged the equation t^2 = 4L^2 / c^2 - v^2 to get v^2 = c^2/4L^2
    by using this:
    v^2 = (3.00 x 10^8 m/s)^2 / 4(20m)^2
    = (9.0 x 10^16 m^2/s^2) / 1600 m^2
    = 5.625 x 10^13
    v = sqrt (5.625 x 10^13)
    = 7.5 x 10^6 m/s
    I am pretty sure thats not right, however, its all i can think of momentarily. Any suggestions??
  3. Oct 5, 2009 #2
    For part a, you did it backwards. The proper length, which is the length of an object in its own frame is always the longest length. If the length seen from some observer is 40m, you know the proper length of the spaceship is longer than 40m. So instead of 40/gamma, it is 40*gamma. You are overcomplicating part b. You can use the equation L=Lp/gamma, where Lp is the proper length. Since you are trying to find the speed so that the relativistic length is half the proper length, substitute in 1/2Lp for L and solve for the v term in gamma.
  4. Oct 5, 2009 #3
    alright but what do i do for a? do i divide 40m by .6? and for part b, im honestly not sure how to rearrange the equation to make it the term v, sadly. I missed that part for rearranging square roots.
  5. Oct 5, 2009 #4
    gamma=1/sqrt(1-v^2/c^2). Gamma is not .6. For a, you should be multiplying the relativistic length by the gamma factor which will be greater than one. For b:
    L=Lp/gamma
    (1/2)Lp=Lp/gamma
    1/gamma=1/2
    gamma=2
    1/sqrt(1-(v^2/c^2)=2
    From here, just solve for v.
  6. Oct 5, 2009 #5
    I honestly did multiply it, and checked the calculations and i get the same answer. what is gamma? i've honestly never heard of that term in physics
  7. Oct 5, 2009 #6
    gamma is the factor by which the classical physics equations must be multiplied or divided by in order for the equations to work at relativistic speeds
    http://my.morningside.edu/slaven/Physics/relativity/relativity6.html [Broken]
  8. Oct 5, 2009 #7
    really? i've never ever heard of that. but for a i've been multiplying it since the beginning, i keep getting 0.6 for that final answer.
  9. Oct 5, 2009 #8
    I have no idea how you are getting 0.6 for part a. I don't even know what your 0.6 equals. Show what you did step by step.
  10. Oct 5, 2009 #9
    alright, so L = Lp sqrt(1 - v^2/c^2)
    = 40m sqrt (1 - (0.80 c)^2 / c^2)
    = 40m sqrt (1 - 0.64 c^2 / c^2) (c^2 cancels eachother)
    = 40 m sqrt (0.36)
    = 40m (0.6)
  11. Oct 5, 2009 #10
    then multiplying its 24 m
  12. Oct 5, 2009 #11
    Okay, so you made the mistake I thought you were making. L does not equal Lp*sqrt(1-v^2/c^2), rather Lp equals L*sqrt(1-v^2/c^2). This way you can find the proper length to be the relativistic length[40m] times the gamma factor[1/.6]. Do you see now?
  13. Oct 5, 2009 #12
    but where does the 1/.6 come from?
  14. Oct 5, 2009 #13
    i'd get the same answer if i divided L by .6
  15. Oct 5, 2009 #14
    thanks for the help by the way
  16. Oct 5, 2009 #15
    Sorry, I mistyped. Lp should equal L*(1/sqrt(1-(v^2/c^2))). Also, you should know that gamma will always be greater or equal to one, so an answer of 0.6 for gamma makes no sense. You need to divide 1 by this number to get 1.667. This makes sense then when you multiply it by the relativistic length because the proper length will be longer.
  17. Oct 5, 2009 #16
    oh okay i understand that, but if you honestly just rearrange the original equation to be L/sqrt(1-(v^2/c^2) you'll end up with the exact same answer, without dividing by 1.
  18. Oct 5, 2009 #17
    ohh our equations are different. my original equation from the text is L = Lo sqrt(1 - v^2/c^2 thats why i'm so confused
  19. Oct 5, 2009 #18
    You're right, Lp= L*(1/sqrt(1-(v^2/c^2))) is the same thing as Lp=L/sqrt(1-(v^2/c^2)). However, earlier you were saying that it was L times just sqrt(1-(v^2/c^2)). Since the symbol gamma represents a fraction, you have to be careful when substituting it into equations or you will run into problems like this one where you confuse numerators and denominators. More importantly anyway, I hope you understand now. For part b, you just do the same thing but in place of the relativistic length you substitute (1/2)Lp.
  20. Oct 5, 2009 #19
    thanks, but i still need to rearrange it right? so that it equals v
  21. Oct 5, 2009 #20
    Correct
  22. Oct 5, 2009 #21
    cause i got to L^2 = Lp (1 - v^2/c^2) and i know i can divide the whole gamma part, but i dont know where to go from there
  23. Oct 5, 2009 #22
    currently im at L^2/ (1 - v^2/c^2) = Lp
  24. Oct 5, 2009 #23
    Wait, you should not have an L term in there. The problem specifies that they want to find v when the relativistic length L is equal to (1/2)Lp. Therefore, starting from the equation L=Lp/gamma, you can substitute in to get (1/2)Lp=Lp/gamma. This way you don't even have to worry about any length terms since they cancel to get (1/2)=1/gamma. From here, gamma is equal to 2. Now solve for v.
  25. Oct 5, 2009 #24
    oh.. sorry i appreciate the patience, i honestly haven't been able to do physics at all today, normally i'm not this bad. so i rearranged it and i got v^2 = 1 + 2c^2
    then v = sqrt (1 + 2c^2).
  26. Oct 5, 2009 #25
    i forgot about the sqrt, if im correct the final equation should be v = sqrt(1+4c^2)
