Length of the shadow
At the outside, there is a vertical stick with a length of 1.1 meter and its shadow on the surface of an earth is 1.3 meter, there also is light pole and its shadow length is 5.2 meters, what is the height of that light pole?
Trigonometry equations to relate height one to height two.
I drew a right triangle, one leg being 1.1 meter, which is the length of a stick, and another leg being 1.3 meter, which is the length of the shadow. Let angle which is between 1.3 meter side and hypotenuse be alpha, so tangent alpha=1.1/1.3. Now I drew another right triangle, one leg being 5.2 meters (shadow length) and another x, which essentially is the height of the light pole. Because light rays emitted from the Sun on the surface of an Earth is almost parallel (because of big distance between the Sun and an Earth), I can say that an angle between 5.2 meters side and hypotenuse will also be alpha, thus x/5.2=1.1/1.3, now solving for x I get 4.4 meters, but I checked the answer and that does not seem to be right answer.
Answers and Replies
stockzahn
136
Your answer makes sense, I also calculated 4.4 m. What are a the other possible answers?
Other possible answers are:
5.2 m; 5.3 m; 5.5 m; 5.8 m.
And from answers, it says that the correct one is 5.5 m.
haruspex
Insights Author
2020 Award
36,163
6,782
Clearly 4.4 m is correct.
Thanks, I had doubt but now I'm sure of my answer.
Related Threads on Length of the shadow
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
G
