Homework Help: Lewis structure of SO2
  1. May 14, 2014 #1
    Hi,
    I drew the lewis structure of SO2. The one with 0 formal charges gives me two double bonds. But, I see on the web that one single bond and another double bond is an acceptable resonance structure. What do they mean? Sulfur can expand its octet. Having 0 formal charge is much more advantageous!
  3. May 14, 2014 #2
    Qube
    Sulfur might be able to expand its octet but that doesn't mean other resonance forms can't exist. As long as there is no grouping of like charges - i.e. having positive formal charges on adjacent atoms - your Lewis structure should be fine.
  4. May 15, 2014 #3
    AGNuke
    The catch is, you can show Sulphur having double bonds with Oxygens or having a covalent bond with one AND dative bond with other. Both are equally acceptable.
  5. May 15, 2014 #4
    Qube
    Perhaps not to the more calculation-inclined chemists!
  6. May 15, 2014 #5
    DrDu
    Nope. This has been disproven about 50 years ago.
  7. May 15, 2014 #6
    I don't understand. When we draw Lewis structures (at undergrad level), we must satisfy formal charges for sure if it can expand its octet. So, why is the other one with a single bond accepted!?
  8. May 15, 2014 #7
    Qube
    It's because the d-orbitals aren't generally accessed by sulfur. The d-orbitals are too high in energy. So sulfur just sticks with structures that are best described using charge-separated Lewis structures.
  9. May 15, 2014 #8
    Hmm. How can I know if an atom can expand octet?
  10. May 15, 2014 #9
    Qube
    Atoms generally don't expand their octets. Unless you're dealing with d-block elements.
  11. May 16, 2014 #10
    Qube is simply wrong (although this is possibly just a difference in semantics). Chlorine pentafluoride comes to mind. PCl5, SF6, the list is endless...
    O=S=O ?? So, if I understand you, the sulfur atom, which you surely KNOW is less electronegative than oxygen, is what? - surrounded by 10 electrons? (that is :S(=O)₂ ). comparing the difference in electronegativity, is a zero formal charge reasonable? Ozone with the same (formal) bonding has a dipole moment of 0.53D compared to SO₂ 's 1.62 D. So, if that isn't telling you that there is a LOT of charge separation, I don't know what could. Why will having a zero formal charge result in the lowest energy state ("is advantageous"). News to me. Wikipedia says:" a formal charge is the charge assigned to an atom in a molecule, assuming that electrons in a chemical bond are shared equally between atoms, regardless of relative electronegativity." IOW, "regardless of energy", since electronegativity is a proxy for the extra energy of bonding 'due to' quantum mechanics and was an early (fairly successful) attempt at including canonical ionic contributions to bond energy (ie at 'explaining' why bond energy of A-B is usually greater than the average of the A-A and B-B bond energies). Formal charge is an accounting 'gimmick', and should be viewed as having only very narrow utility. (The same can be said for electronegativity, but formal charge is more often used in organic chemistry, while electronegativity is more often used in inorganic, I think.) (Both can be (carefully) applied, but the reality is that neither are as good as Density Functional, Molecular Orbital, or Valence Bond quantum mechanical treatments of what is inherently a QM problem.) Up till about the 1990's, chemists relied on a lot of rules of thumbs like these, DFT has allowed them to instead rely on (more accurate) calculations and models (but at the expense of intuitiveness). Instead of relying on our crude mental models of the geometry and bonding of chemicals, we can instead look at the results of DFT theory to determine where electron density is. Its an attempt to fit more classical electrostatics to what is properly only solved with the use of QM. As a student, it makes sense to learn the easy stuff first, and then move on to better (but more complex) stuff. The real foundation of chemistry IS quantum mechanics, but that is beyond the mathematical competence of most undergraduates. At the same time, there is a boat load of chemistry which can be (more or less) put into some sort of coherent body of knowledge without knowing the QM. Learning about bonding begins the process of connecting the two.
  12. May 16, 2014 #11
    Qube
    http://en.wikipedia.org/wiki/Hypervalent_molecule
  13. May 18, 2014 #12
    DrDu
    Wrong in which respect?
    Main group atoms not extending the octet?
    Well, in the compounds you mention, bonds are highly polar, so that the important resonance structures don't contain more than 4 covalent bonds plus several ionic bonds. But as you suspect, this involves a lot of semantics:
    The following paper "Chemical bonding in hypervalent molecules: Is the octet rule relevant?" sums up the discussion
    http://alpha.chem.umb.edu/chemistry/Seminar/06-09 WQE/InorgI.Carter.pdf
    see also
    http://www.chem.umn.edu/groups/tonks/Organometallics/VSEPR/Gillespie_CCR_2002_233_53_Hypervalence.pdf [Broken]
    and also contains some examples where the valence shell of the central atom may contain more than 8 electrons.
Have something to add?
Draft saved Draft deleted
