How to Schedule an LHC tour
  • Thread starter seazal
  • Tags
    Lhc
In summary: China is quite confident that they can build a larger accelerator - first used for electron-positron collisions, with the option to have proton-proton collisions...
seazal
119
Who has traveled to see LHC in Switzerland? How much of it have you seen and allowable to see?
For 2019, What is the schedule of visit? Does it only occur during shutdown?
What hotel did you stay? How was your LHC tour overall? Please share your experiences.
I have been there many times, but I got access from working there and I have never been on an official tour, so it probably doesn't help if I answer the questions literally.
There are different types of tours, they typically have surface facilities only. CERN Control Center or ATLAS Control Center, the Magnet Test Facility, the Globe, the Microcosm exhibition or something like that.
In 2019 and 2020 we have a long shutdown so some tours can include underground visits, but they will have limited slots and they will be very popular. Check the CERN website for more information and be quick with registration if they offer a tour that includes a detector underground.
There are many hotels in Geneva but they tend to be expensive. If you don't mind a bus trip (or if you have a car anyway) you can stay somewhere on the French side, things tend to be much cheaper there. Or plan the trip to not stay there over night, if possible.I don't know your overall travel plans, but if you are flexible: There are many research institutes that offer tours, some of them have more things you can see.
DESY (Hamburg, Germany) had the HERA accelerator which is shut down now, that means all their tours go there. You can see parts of the Hera-B experiment (partially decommissioned, but most of it is still there), you can go into the actual accelerator tunnel and see the accelerator (something you normally cannot do at the LHC, even during a shutdown), you can see an experiment hall for the PETRA facility while it is running (the actual accelerator ring is behind a lot of concrete shielding, however).
GSI (Darmstadt, Germany) has tours that include various experimental stations and a view at the FAIR construction site.
PSI (middle of nowhere, northern Switzerland) has tours, I don't know what exactly they include ("takes you around the large research facilities or the energy research labs" according to the website).
And so on.
Likes fresh_42
I'll tour it as a tourist and not as a visiting physicist. You were referring to tourist tour package and not university sanctioned tours, right?
In 2019 and 2020 we have a long shutdown so some tours can include underground visits, but they will have limited slots and they will be very popular. Check the CERN website for more information and be quick with registration if they offer a tour that includes a detector underground.There are many hotels in Geneva but they tend to be expensive. If you don't mind a bus trip (or if you have a car anyway) you can stay somewhere on the French side, things tend to be much cheaper there. Or plan the trip to not stay there over night, if possible.
According to Hossenfelder. It may be the last particle accelerator ever built. So want to see it before we return to the desert particle landscape and era. http://backreaction.blogspot.com/2018/12/how-lhc-may-spell-end-of-particle.html
"In summary: Since the naturalness-based predictions did not pan out, we have no reason to think that the remaining LHC run or an even larger particle collider would see any new physics that is not already explained by the standard model of particle physics. A larger collider would be able to measure more precisely the properties of already known particles, but that is arguably not a terribly exciting exercise. It will be a tough sell for a machine that comes at $10 billion and up. Therefore, it may very well be that the LHC will remain the largest particle collider in human history."
Everything I wrote was for tourists. I edited my post and added some more information.
That is certainly not true, even if we count the big fundamental science projects only (there are something like 10,000 particle accelerators used in the industry, medicine and so on). SuperKEKB was built after the LHC. It started operation earlier this year.
Largest and last are not the same thing.
China is quite confident that they can build a larger accelerator - first used for electron-positron collisions, with the option to have proton-proton collisions later.
mfb said:
Everything I wrote was for tourists. I edited my post and added some more information.That is certainly not true, even if we count the big fundamental science projects only (there are something like 10,000 particle accelerators used in the industry, medicine and so on). SuperKEKB was built after the LHC. It started operation earlier this year.
I should have added "Largest". But what "10,000 particle accelerators used in the industry, medicine and so on" were you referring to, for example?
Can something still came up after 100 TeV or more?
Electron microscopes, focused ion beams/ion implantation, radionuclide production, ion beam therapy, material science with synchrotron radiation, neutron sources, ...
Wikipedia says 30,000 accelerators.
After 100 TeV? We know for sure there is new physics at very high energy levels, way beyond the reach of anything we could dream of today, we just don't know if it starts earlier. Before 100 TeV? Possible. The next years will be interesting. There are some interesting anomalies in B physics that could point to new particles, if they are confirmed then the following years could give us a rough mass estimate.
1. Can anyone schedule an LHC tour?
Yes, anyone can schedule an LHC tour. However, there are certain requirements that need to be met in order to schedule a tour. These include a minimum group size of 15 people and advance booking of at least 2 weeks.
2. How do I schedule an LHC tour?
To schedule an LHC tour, you can fill out a request form on the official CERN website or contact their visit service directly. You will need to provide information such as the preferred date and time for the tour, as well as the number of participants and their names.
3. Can I choose which areas of the LHC to visit during the tour?
Unfortunately, due to safety reasons, visitors are only allowed in certain areas of the LHC. However, there are different tours available that cover different parts of the LHC, so you can choose the one that interests you the most.
4. Are there any age restrictions for the LHC tour?
Yes, due to safety reasons, visitors must be at least 16 years old to participate in the LHC tour. However, there are alternative tours available for younger visitors, such as the Microcosm exhibition and the Globe of Science and Innovation.
5. Is there a fee for scheduling an LHC tour?
No, there is no fee for scheduling an LHC tour. However, visitors are responsible for their own transportation to and from CERN. There may also be additional fees for certain tours or activities, such as the underground visit to the LHC tunnel.
  • General Discussion
13K
9K
  • Beyond the Standard Models
11K
