Libet's half-second delay
  • #126
747
moving finger said:
OR (B) the RNG generates different alternatives on the second “run”, in which case the agent (still operating determinsitically) might make a choice which is different to the choice that it made on the first run. In other words, if we could re-play the agent’s moment of choice with all of the conditions exactly as they were before EXCEPT that the alternatives for consideration are different, then the agent will not necessarily make the same choice as it did before. This (the agent’s choice) again is a completely deterministic scenario and is again completely compatible with determinism (ie re-play with different starting conditions and one may obtain a different result).
No, this isn't completely deterministic , because determinism requires
a rigid chain of cause and effect going back to the year dot. One part
of the process, the selection from options may be deterministic, but
the other part, the generation of options to be selected from, isn't.
D-ism doesn't mean that cause cause effects every now and then,
it means everyhting happens with iron necessity and no exceptions.
The only difference between re-play (A) and re-play (B) is that in (A) the conditions are indeed set to the way they were the first time round, whereas in (B) the conditions (at the moment of choice of the agent) are not the same as they were before. THIS FACT ALONE (and not any supposed “free will” on the part of the agent) is the source of the agent’s ability to make different choices in each run.
But they are different becuase of indeterminism in the chain
of causes leading up to that moment, and in my naturalistic
account of FW, that indeterminism is one of the things that constitutes
FW. You seem to be assuming that FW is supernatural or nothing;
I am not making that assumption.
In fact, we do not need the RNG in the proposed mechanism to be ontically indeterministic. It need only be an RNG in the sense of a computer software RNG, which operates to generate epistemically random, but ontically deterministic, numbers. What matters in the RA mechansim (the “apparent source of free will”) is ONLY that the agent is provided with DIFFERENT ALTERNATIVES in each re-play (this will ensure that the agent will not necessarily make the same choice in each re-play, scenario B above), and NOT that these alternatives are generated by a genuinely (ontically) indeterministic process.
Pseudo-random numbers (which are really deterministic)
may be used in computers, and any indeterminism the brain
calls on might be only pseudo-random. But it does not have
to be, and if we assume it is not, we can explain realistically
why we have the sense of being able to have done otherwise.
People sometimes try to explain this as an 'illusion', but
it do not make it clear why we would have that particular illusion.
I could quite easily \"build\" such models of \"free-will\" agents using computer software, incorporating an RNG to \"generate\" apparently random alternatives for my deterministic software agent to consider, and from which to choose. Since I am generating the computer agent\'s alternatives randomly (thus ensuring that it\'s choice need not be the same each time) does that mean my computer agent now has \"free will\", where it had no \"free will\" before (prior to me introducing the RNG)? I think everyone would agree that this notion is very silly. And does it make any difference if the RNG is genuinely random (ontically indeterministic), or whether it simply appears to be random (epistemically indeterminable)? No, of course not. It does not matter what we do with the RNG, we cannot use indeterminsim to \"endow\" the Libertarian version of free will onto an otherwise deterministic machine
Naturalists think it is not impossible to artificially duplicate human
mentality, which would have to include human volition, since there
is not 'ghost' in the human machine. You are levelling down, saying huamns have
no FW and computers don't either. I am levelling up, saying humans have FW and appropriate computers could have it as well. It all depends on what
you mean by FW. The contentious issue, vis a vis determinism, is the
ability to have doen otherwise, and that is explainable naturalistically in an indeterministic universe.
I think one will find that if one models the above RA mechanism and examines it rationally and logically, looking at the possible sequences generated, then one will find that the introduction of the RNG prior to the moment of choice acts in much the same way as introducing the RNG after the moment of choice. In both cases, there is a point at which a deterministic choice is made by the agent based on alternatives available, but in both cases the final result is in fact random. This is not free will. This is simply a random-choice-making mechanism.
No it isn't the same. Intorducing randomness after choice removes 'ownership'.
The hypothetical AI wouldn't be able to explain why it did as it did.
  • #127
1,604
moving finger said:
OR (B) the RNG generates different alternatives on the second “run”, in which case the agent (still operating determinsitically) might make a choice which is different to the choice that it made on the first run. In other words, if we could re-play the agent’s moment of choice with all of the conditions exactly as they were before EXCEPT that the alternatives for consideration are different, then the agent will not necessarily make the same choice as it did before. This (the agent’s choice) again is a completely deterministic scenario and is again completely compatible with determinism (ie re-play with different starting conditions and one may obtain a different result) .
Tournesol said:
No, this isn't completely deterministic , because determinism requires a rigid chain of cause and effect going back to the year dot.
Please read what I wrote.
“re-play with different starting conditions and one may obtain a different result”
This is completely deterministic.
Tournesol said:
One part of the process, the selection from options may be deterministic, but the other part, the generation of options to be selected from, isn't. D-ism.
Agreed - this is the point of “indeterminism”. But introducing indeterminism into the process simply introcduces indeterminism into the results – how do you think it introduced free will?
Tournesol said:
But they are different becuase of indeterminism in the chain of causes leading up to that moment, and in my naturalistic account of FW, that indeterminism is one of the things that constitutes FW. You seem to be assuming that FW is supernatural or nothing.
No, you seem to be assuming that introducing indeterminism also introduces free will.
Tournesol said:
Pseudo-random numbers (which are really deterministic) may be used in computers, and any indeterminism the brain calls on might be only pseudo-random. But it does not have to be, and if we assume it is not, we can explain realistically why we have the sense of being able to have done otherwise. People sometimes try to explain this as an 'illusion', but it do not make it clear why we would have that particular illusion.
You have not explained anything. You have assumed that indeterminism is equivalent to free will simply because indeterminism results in an indeterministic outcome.
Tournesol said:
Naturalists think it is not impossible to artificially duplicate human mentality, which would have to include human volition, since there is not 'ghost' in the human machine. You are levelling down, saying huamns have no FW and computers don't either.
I am not saying that humans do not have free will, I am saying that free will as defined by you cannot exist, period.
Tournesol said:
I am levelling up, saying humans have FW and appropriate computers could have it as well. It all depends on what you mean by FW.
Do you agree that the computer I have just described has free will? The computer “could have done otherwise” since it’s choices were dependent on a RNG input – therefore according to your philosophy it must have free will? Yes? Or no? And if no then why not?
Tournesol said:
No it isn't the same. Intorducing randomness after choice removes 'ownership'. The hypothetical AI wouldn't be able to explain why it did as it did.
Incorrect. Why do you think the AI would not be able to explain why it did as it did? It operates deterministically, there is no reason why it should not understand the reason for its choices…..
MF
:smile:
  • #128
1,604
moving finger said:
With respect, I suggest you are trying to compare different types of knowledge.
Knowledge of “what green looks like” is not foreknowledge, it is acquired knowledge.
Paul Martin said:
Hmmmmm.
Hmmmmm? Is that a yes or a no?
moving finger said:
Your definition of free will is dependent on infallible foreknowledge, it is not dependent on infallible acquired knowledge.
Paul Martin said:
Hmmmmmm. It does appear that way.
Thank you.
moving finger said:
I do not understand your suggestion “The asteroid could wipe out the PNS -- but in my view, not the agent.”
Paul Martin said:
The asteroid is in the physical world; the agent is not. Thus the agent is immune from the asteroid.
Interesting. Can you please define what else your “agent” is also immune to? The common cold?
moving finger said:
Are you suggesting that the agent is immortal, indestructible?
That it is impossible for the agent to be destroyed?
Paul Martin said:
No. Just not by an asteroid.
“Just” by an asteroid? Thus, your agent can be destroyed by absolutely anything else…… but not by an asteroid?
Really?
Strange.
moving finger said:
If you are indeed suggesting that an agent must necessarily be indestructible in order to have free will, then this needs to be explicit in your necessary conditions?
Paul Martin said:
No. It's just that as soon as the agent is destroyed, it no longer has free will.
Well that does seem logical. You are not suggesting that your agent is necessarily indestructible then.
moving finger said:
Are you suggesting that the agent somehow exists outside of the physical world?
Paul Martin said:
Yes, absolutely. That is one of the most significant assumptions in my view of the world. It is probably second only to my assumption of the existence of only a single consciousness, since I think "a single consciousness" implies a non-physical world.
Perhaps you should therefore include this in your “necessary conditions” for free will?
Paul Martin said:
For more elaboration, I'll let you prompt me with questions or comments.
OK, maybe later.
moving finger said:
We are talking here specifically about foreknowledge. And IMHO infallible foreknowledge is not possible.
Paul Martin said:
I see your point.
Thank you. Does that mean you “agree”?
moving finger said:
Can you explain why you think your definition of free will is necessarily incompatible with determinism?
Paul Martin said:
I tried to explain that with my thought experiment of re-running identical circumstances and getting different results. Determinism would say that the results would be identical.
Sorry, I still don’t understand how you introduce “different results”, unless this is purely due to indeterminism? (but if it is indeterminism, then what has this to do with free will?)
moving finger said:
(for the record, I believe your type of free will does not exist because your definition requires infallible foreknowledge, which I do not believe is possible, in either a deterministic or an indeterministic world)
Paul Martin said:
Your points about foreknowledge are begining to sink in.
Sink in? Does this mean you agree?
moving finger said:
MF definition of free will : the ability of an agent to anticipate alternate possible outcomes dependent on alternate possible courses of action, and to choose which course of action to follow and in so doing to behave in a manner such that the agent’s choice appears, both to itself and to an outside observer, to be reasoned but not consistently predictable.
Paul Martin said:
Except for a small quibble, I find this definition to make sense and I would accept it.
Wonderful!
moving finger said:
I am not saying that the world is necessarily determinsitic, but I think you will find that the above definition is entirely consistent with determinism, and also consistent with the way that humans (who claim to have free will) actually behave.
Paul Martin said:
Yes, you are right. I did find it consistent with determinism and with human behavior.
Even more wonderful!
moving finger said:
There is no mystery involved in this definition or in the way that free will operates.
Paul Martin said:
OK, but there still remains the slightly nagging question of whether or not there is free will in the naïve sense. (Could I really have taken a lunch break? I just don't know.)
If you would define “free will in the naïve sense” then I could tell you.
moving finger said:
I agree the MF definition does not accord with the naïve conception of free will - but that is because the naïve conception of free will is based on unsound reasoning, and leads to a kind of free will which is not possible.
Paul Martin said:
That could very well be the reason.
Wonderful!
moving finger said:
No mystery.
Paul Martin said:
Not one worth debating anyway.
Does this mean that you now accept my suggested changes to your necessary conditions? (ie that agents "believe that thay have infallible knowledge" of options, rather than agents "have infallible knowledge" of options?)
MF
:smile:
  • #129
340
Yes. I accept your changes. I think you have improved on my original conditions. Thank you.
I am by nature slow but persistent. It took me a while but after thinking about your arguments, I finally saw that you are right. Sorry it took so long, and thank you for your effort.
Paul
  • #130
1,604
Paul
You are most welcome.
We have arrived at our necessary conditions for free will :
1. The agent must be conscious.
2. The agent must believe that multiple options for action are available.
3. The agent must know (or believe that it knows) at least something about the probabilities of near-term consequences of at least some of the options in case they are acted out.
4. The agent must be able to choose and execute one of the options in the folklore sense of FW.
The above conditions (IMHO) are compatible with a deterministic world; they are also compatible with my definition of free will, as well as being (IMHO) an accurate description of exactly what humans experience when they claim to be acting as free agents.
As for the concern you expressed about the existence naïve free will :
What I believe you mean here is : “If I had my time over again, could I have done otherwise than what I did?”. This IMHO is the naïve concept of free will, it is the concept usually espoused by Libertarians, and it is the concept we naturally think of based on “gut feeling” and “intuition” without really thinking rigorously about the issue.
My answer : Does it really matter whether you “could” have taken a lunch break or not? The fact is that “you were able to consider the option of taking a lunch break”, and "you believed at the time that this was an option available to you", and “you were able to evaluate the advantages and disadvantages of taking a lunch break”, and at the time of your decision you were NOT coerced into NOT taking a lunch break, and (most importantly) you did what you wanted to do at the time, which was "not take a lunch break".
If you could replay that time over again, with literally everything the same way as it was before, then the same things would happen – you would consider the option, you would believe the option is available, you would evaluate advantages and disadvantages, you would not be coerced, and you would once again DO WHAT YOU WANT TO DO, which is "not take a lunch break".
What I believe most Libertarians ACTUALLY MEAN when they ask “if I could replay the same situation exactly as before, could I have done otherwise than what I actually did?” is in fact that they want the "freedom" to NOT replay it exactly as it was before, they want to be able to "choose differently" which means in turn they want to be able to "want to choose differently", which is NOT REPLAYING EXACTLY AS IT WAS BEFORE. The Libertarian who thinks he can replay and choose differently is therefore (IMHO) deceiving himself into thinking that he is actually replaying the same situation, when in fact he is not.
To the naïve question of free will expressed as “if I could replay the same situation EXACTLY as before, could I have done otherwise than what I actually did?” the answer is (IMHO) NO, YOU COULD NOT HAVE DONE OTHERWISE, BUT IT DOESN’T MATTER!
MF
:smile:
  • #131
1,604
Tournesol,
I just realised that I misunderstood your comment here. Apologies. Let me reply correctly this time :
I agree that in the case of the RNG after the moment of choice, the agent would not be able to explain why it chose what it did choose.
But on the other hand, in the case of the RNG before the moment of choice, the agent would not be able to explain why it considered the alternatives that it did consider – it would in fact have no control over the alternatives being considered because those alternatives are being generated, not by any rational process within the agent, but randomly.
In both case, the outcome is random.
In both cases, the agent does not completely control what it does.
MF
:smile:
  • #132
1,604
Tournesol said:
It's to do with the ability to have done otherwise .
Seems like a harmless expression doesn't it? Surely it stands to reason that all free will agents "have the ability to have done otherwise"?
I wish to show that this naive Libertarian concept of free will is an impossibility.
Libertarians seem to believe that "free will" is somehow associated with the fact that "if one could replay the circumstances exactly the same as before, then one must have been able to have done otherwise than what one actually did".
For example, one hour ago I could have chosen to take a lunch break, or I could have chosen to continue typing. In fact, I chose to continue typing. The Libertarian would say that if I could replay the circumstances exactly the same as before, then (if I have free will) I must have been able to choose to take a lunch break rather than to continue typing.
At first sight, this idea seems intuitively "right"; our naive impression of free will is surely that we can choose to do whatsoever we wish, and therefore (our intuition tells us), if we have free will then that also means that, given identical circumstances, we still must have been able to do otherwise than what we actually did?
Let us analyse this seemingly "obvious" statement a little more closely.
Firstly, what do we mean by "circumstances exactly the same as before"? Do we mean simply that the circumstances should be similar, but not necessarily identical? No, of course not, because obviously if the circumstances were even slightly different then that might affect our choice anyway, regardless of whether we "choose freely" or not.
Therefore, when we say "circumstances exactly the same as before" we do mean precisely the same, including our own internal wishes, desires, volitions.
Secondly, what do we mean by "able to have done otherwise"?
Do we mean "physically able", in the sense that one is physically capable of carrying out different actions? No of course not.
Do we mean "able to choose", in the sense that one is capable of selecting one of among various alternatives?
This seems closer to what we actually mean. But surely "our choice" is determined by "us"; we "freely" decide our choice based upon the prevailing circumstances.
Now combine these two. Repeat the scenario, with "circumstances exactly the same as before".
If circumstances are indeed exactly the same as before, then all of our internal wishes, desires, volitions etc will also be exactly the same as before. In which case, why one earth would we WANT to choose differently than the way we did before? Replay the scenario with exactly the same conditions, and any rational "free thinking" agent will choose exactly the same way each and every time. The only reason why it should ever "choose differently" in the carbon-copy repeat is if there is some element of indeterminism in the choice - but do Libertarians REALLY want to say that their free will choices are governed by indeterminism? I think not.
My answer to this naive Libertarian concept of free will : Does it really matter whether I “could” have taken a lunch break or not?
The fact is that “I was able to consider the option of taking a lunch break”, and in addition "I believed at the time that this was an option available to me", and even “I was able to evaluate the advantages and disadvantages of taking a lunch break”, and furthermore at the time of my decision I was NOT coerced into NOT taking a lunch break, and (most importantly) I did what I wanted to do at the time, which was "not take a lunch break".
If I could replay that time over again, with literally everything the same way as it was before, then the same things would happen – I would consider the options, I would believe the options are available, I would evaluate advantages and disadvantages, I would not be coerced, and I would once again DO WHAT I WANTED TO DO, which is (because the circumstances are identical) "not take a lunch break".
What I believe most Libertarians ACTUALLY MEAN when they say "if one could replay the circumstances exactly the same as before, then one must have been able to have done otherwise than what one actually did" is in fact that they want to have the "freedom" to NOT replay it EXACTLY as it was before, they want in fact to be able not only to "choose differently" to the way they did before, but they also want to "want to choose differently", which is then NOT REPLAYING EXACTLY AS IT WAS BEFORE.
The Libertarian who thinks he can replay perfectly and still choose differently is therefore (IMHO) deceiving himself.
The naïve concept of free will is expressed as “"if one could replay the circumstances exactly the same as before, then one must have been able to have done otherwise than what one actually did"
- and the rational response is (IMHO) YOU COULD NOT HAVE DONE OTHERWISE THAN WHAT YOU DID, BUT IT REALLY DOESN’T MATTER!
MF
:smile:
  • #133
loseyourname
Staff Emeritus
moving finger said:
I have no idea what you mean by strong free will
(but from the rest of your post I suspect we have some similar beliefs)
May I ask - do you believe your concept of free will is compatible with determinism?
MF
:smile:
Sure. I suppose I can formulate what I mean when I say that an action of mine is free:
Any action X is a freely willed action if, and only if, the impulse to carry it out was internal to my own psyche and I was conscious of this impulse. This basically just means that so long as I ordered the action, then it's freely willed. Even if this I is nothing more than a particular unique confluence of physical and historical forces networking to determine the behavior of my body, that's fine with me. It doesn't even matter if I couldn't have done otherwise. 'Strong' free will is just that and seems to be what everyone else wants - contracausal, non-deterministic, and could have done otherwise.
By the way, Paul Martin asked a while back what I meant by by distinction between 'experiential' and 'functionalist' knowledge. Functionalist isn't the best word to use, as it conjurs up images of psychological theories that I'm not endorsing, and these aren't accepted technical terms or anything, so I probably should explain. Maybe a better distinction would be between conscious and non-conscious knowledge, since the point that I was trying to make was simply that I don't agree that knowledge is just the experiential state that one is one when one acquires knowledge. For instance, everyone in this thread likely knows that 2+37=39, even though they may not have been thinking about it at that time. Given the results of hypnotic therapy and such, it's entirely possible that you have knowledge of the past that you are not and may never be conscious of. This knowledge (suppressed memories) would fit the non-conscious knowledge mold but wouldn't fit what I meant by functional knowledge, as functional knowledge has to be usable in some way. A good example of what I meant by functional, non-experiential knowledge, is a typist's knowledge of the keyboard. I know exactly where all of the keys are on the board and use that knowledge to type out words on a screen. Rarely am I conscious of where the keys are, however. I'm certainly not thinking about it; I'm just thinking about the words I want to produce. In the same way, a good pitcher never thinks about the mechanics needed to produce a good curveball; he just throws the pitch. Nonetheless, he must have knowledge of those mechanics in order to have the ability to throw a curveball in the first place.
  • #134
selfAdjoint
Staff Emeritus
Dearly Missed
6,786
And loseyourname, you could add that if some of those causes were randomly altered, that would change either the given parameters, or your desires, and you either would want to do differently because of the different causes, or else you would want differently because your desires were different, but in neither case would you be acting freely.
  • #135
loseyourname
Staff Emeritus
Well, they'd be free under my conception, but I suppose not in a strong sense. I'm kind of with Stace's language analysis, though, when he demonstrates that the common usage of the term 'free' only denotes that an action was not compelled by an external force as a proximate cause. As someone said (I can't remember who), we may be free to do as we please, but we are not free to please as we please.
  • #136
1,604
selfAdjoint said:
......... in neither case would you be acting freely.
Can you please define what you mean by "acting freely"?
Thanks
MF
:smile:
  • #137
1,604
Agreed. And this kind of free will is indeed compatible with determinism.
My preferred definition of free will I think you will find agrees completely with your above description :
"Free will is the ability of an agent to anticipate alternate possible outcomes dependent on alternate possible courses of action and to choose which course of action to follow and in so doing to behave in a manner such that the agent’s choice appears, both to itself and to an outside observer, to be reasoned but not consistently predictable."
This kind of “Strong” free will, IMHO, is a “will-o-the-wisp” and cannot exist. This seems to be the kind of “free will” that Libertarians want, but I have yet to find anyone who can both unambiguously define it and rationally defend it.
MF
:smile:
  • #138
1,604
Peter O'Toole, as the character T E Lawrence in the epic Lawrence of Arabia, says (in a memorable scene with Omar Sharif, where he finally comes to terms with his limited ability to change the course of history in the Arabian peninsular) :
"We are free to do what we want. But we are not free to want what we want."
MF
:smile:
  • #139
747
But you can be consciously aware of impulses that are not your conscious wish. A kleptomaniac is consciously aware of an impulse to steal, originating within herself, but it is not her wish or will to steal.
what does "I ordered" mean ?
That is compatible with indeterminism as well as determinism. Depending on what you mean by "choose" it might even require indeterminism.
If the universe is indeterministic, there is nothing miraculous about the ability
  • #140
loseyourname
Staff Emeritus
That's a compulsion, not an impulse. Subtle difference.
I made a decision to take any given particular action.
I don't think you were responding to me here, but I certainly don't view choices as indeterministic. They certainly can be, but don't have to be (go back to the Mars Rover example).
If the universe is indeterministic, there is nothing miraculous about the ability to have done otherwise.
There's nothing willed about it, either.
  • #141
747
Yes, but the salient difference isn't made explicit by your definition. Consc. awareness is not enough -- consc approval is also required.
the problem of defining FW is to 'unpack' it, not just substitute synonyms.
How do you know? Can you demonstrate that FW is not just a particular complex combination of deterministic and undetermined events and processes?
Do you insist, along with MF that it must involve a ghost ?
  • #142
192
I am determined to inform those who give a differance that reality does not.
As for sub/conscious decisions being determined the subconscious is programmed beforehand both by experience and conscious deliberation and reasoning.
  • #143
1,604
The determinist can demonstrate that the "feeling of free will" which many humans claim to possess is easily explainable on the basis of pure determinism, with no need to invoke any metaphysical concepts of libertarian free will. This then becomes a scientific "hypothesis", based on accepted understanding of how the world works, which explains the human feeling of free will. It is accepted scientific practice that scientific hypotheses are not proven true, they are only ever proven false.
See, for example : http://www.wjh.harvard.edu/%7Ewegner/pdfs/Wegner&Wheatley1999.pdf [Broken]
The defender of libertarian free will is also free (no pun intended) to propose an hypothesis of how libertarian free will is supposed to work (ie how the human feeling of free will is explained based on the real existence of some kind of libertarian free will) - but as in the case of the determinist hypothesis, such a libertarian explanation should be based on accepted understanding of how the world works, and be free of metaphysical "sleight of hand" (otherwise it risks being branded as incoherent). Can the libertarian do this?
Best Regards
MF
If one pays attention to the concepts being employed, rather than the words being used, the resolution of this problem is simple (Stuart Burns)
Related Threads on Libet's half-second delay
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Poll
  • Last Post
  • Last Post
  • Last Post
