Homework Help: Lie Algebras
  1. Sep 14, 2011 #1
    Let [tex]\mathfrak{g} , \mathfrak{h}[/tex] be Lie algebras over [tex]\mathbb{C}.[/tex]
    (i) When is a mapping [tex]\varphi : \mathfrak{g} \to \mathfrak{h}[/tex] a homomorphism?
    (ii) When are the Lie algebras [tex]\mathfrak{g}[/tex] and [tex]\mathfrak{h}[/tex] isomorphic?
    (iii) Let [tex]\mathfrak{g}[/tex] be the Lie algebra with basis vectors E,F,G such that the following relations for Lie brackets are satisfied: [tex][E,F]=G,\;\;[E,G]=0,\;\;[F,G]=0.[/tex] Let [tex]\mathfrak{h}[/tex] be the Lie algebra consisting of 3x3 matrices of the form [tex]\begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix}[/tex] where a,b,c are any complex numbers. The vector addition and scalar multiplication on [tex]\mathfrak{h}[/tex] are the usual operations on matrices. The Lie bracket on [tex]\mathfrak{h}[/tex] is defined as the matrix commutator: [tex][X,Y] = XY - YX[/tex] for any [tex]X,Y \in \mathfrak{h}.[/tex] Prove that the Lie algebras [tex]\mathfrak{g}[/tex] and [tex]\mathfrak{h}[/tex] are isomorphic.
    3. The attempt at a solution
    Firstly, is this the definition for (i):
    [tex]\varphi[/tex] is a homomorphism if [tex]\varphi [x,y] = [\varphi (x) , \varphi (y) ][/tex] for all [tex]x,y\in\mathfrak{g}\,?[/tex]
    What is the definition for (ii)?
    For (iii) presumably I first have to show that a mapping [tex]\varphi : \mathfrak{g} \to \mathfrak{h}[/tex] is a homomorphism? If so how do I show [tex]\varphi [x,y] = [\varphi (x) , \varphi (y) ]\,?[/tex]
  3. Sep 14, 2011 #2
    For (i), don't you also want to demand that [itex]\phi[/itex] is linear and stuff?? That is, phi should at least be an algebra morphism.
    The definition for (ii) is of course that there exists an isomorphism [itex]\phi:\mathfrak{g}\rightarrow \mathfrak{h}[/itex]. That is: a bijective homomorphism such that its inverse is also a homomorphism.
    For (iii), let's not do too much first. Let's first try to figure out what the isomorphism is exactly. Any suggestions??
  4. Sep 14, 2011 #3
    So we need to define some [tex]\varphi[/tex] which is an isomorphism. Could you help me here?
  5. Sep 14, 2011 #4
    Well, you need to send a basis to a basis. So you need to send E,F and G to a basis. Do you know a basis of those 3x3-matrices?
  6. Sep 14, 2011 #5
    [tex]\left\{ \begin{bmatrix} 0 & 1 & 0 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix} , \begin{bmatrix} 0 & 0 & 1 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix} , \begin{bmatrix} 0 & 0 & 0 \\ 0 & 0 & 1 \\ 0 & 0 & 0 \end{bmatrix} \right\}[/tex]
  7. Sep 14, 2011 #6
    That is a nice proposal. So we set
    [tex]\phi(aE+bF+cG)=\left(\begin{array}{ccc} 0 & a & b\\ 0 & 0 & c\\ 0 & 0 & 0 \end{array}\right)[/tex]
    So, some questions remain:
    - is it bijective?
    - is it linear?
    - Does it respect the commutator?
  8. Sep 14, 2011 #7
    Let
    [tex]E = \begin{bmatrix} 0 & 1 & 0 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    [tex]F = \begin{bmatrix} 0 & 0 & 0 \\ 0 & 0 & 1 \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    [tex]G = \begin{bmatrix} 0 & 0 & 1 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    Then [tex][E,F] = EF - FE = \begin{bmatrix} 0 & 0 & 1 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix} = G[/tex]
    [tex][E,G] = EG - GE = \begin{bmatrix} 0 & 0 & 0 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    [tex][F,G] = FG - GF = \begin{bmatrix} 0 & 0 & 0 \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    Does this show that the commutator is satisfied?
    How do you show that [tex]\varphi[/tex] is a homomorphism? How do you show [tex]\varphi [x,y] = [\varphi (x) , \varphi (y) ][/tex] for all [tex]x,y\in\mathfrak{g}\,?[/tex]
  9. Sep 14, 2011 #8
    Well, take x=aE+bF+cG and take y=a'E+b'F+c'G. Try to work out both
    [tex]\varphi [aE+bF+cG,a^\prime E+b^\prime F+c^\prime G][/tex]
    and
    [tex][\varphi(aE+bF+cG),\varphi(a^\prime E+ b^\prime F+c^\prime G][/tex]
    Use the properties of the commutator and the definition of [itex]\varphi[/itex].
  10. Sep 14, 2011 #9
    OK, so:
    [tex]\varphi ( [x,y] ) = \varphi ( xy - yx)[/tex]
    [tex]= \varphi \left( \begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix} \begin{bmatrix} 0 & a' & c' \\ 0 & 0 & b' \\ 0 & 0 & 0 \end{bmatrix} - \begin{bmatrix} 0 & a' & c' \\ 0 & 0 & b' \\ 0 & 0 & 0 \end{bmatrix}\begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix} \right)[/tex]
    [tex]= \varphi \left( \begin{bmatrix} 0 & 0 & ab' - a'b \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix} \right) = \begin{bmatrix} 0 & 0 & ab' - a'b \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    [tex]= \begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix} \begin{bmatrix} 0 & a' & c' \\ 0 & 0 & b' \\ 0 & 0 & 0 \end{bmatrix} - \begin{bmatrix} 0 & a' & c' \\ 0 & 0 & b' \\ 0 & 0 & 0 \end{bmatrix} \begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix}[/tex]
    [tex]= \varphi (x) \varphi (y) - \varphi (y) \varphi (x) = [\varphi (x) , \varphi (y) ][/tex]
    Therefore [tex]\varphi[/tex] is a homomorphism?
  11. Sep 14, 2011 #10
    No, since you don't know that [itex][x,y]=xy-yx[/itex]. You know nothing about the Lie bracket in [itex]\mathfrak{g}[/itex], except [E,F]=G, [E,G]=[F,G]=0. So use these relations to calculate
    [tex][aE+bF+cG,a^\prime E+b^\prime F+c^\prime G][/tex]
  12. Sep 14, 2011 #11
    OK, so using the bilinearity property of the Lie bracket and the property that [x,x] = 0 for all [tex]x\in\mathfrak{g}[/tex] together with those 3 relations I get:
    [tex]\varphi ( [x,y] ) = \varphi ( (ab' - a'b)G ) = \varphi \left( \begin{bmatrix} 0 & 0 & ab' - a'b \\ 0 & 0 & 0 \\ 0 & 0 & 0 \end{bmatrix} \right)[/tex] and from here the calculation continues like it did in my last attempt.
    Does this now show that [tex]\varphi[/tex] is a homomorphism?
  13. Sep 14, 2011 #12
    Yes, this is ok!
  14. Sep 14, 2011 #13
    So do I have to show that [itex]\varphi[/itex] is also a linear transformation?
    i.e. [itex]\varphi ( x + y) = \varphi (x) + \varphi (y)[/itex] for all [itex]x,y\in\mathfrak{g}[/itex]
    and [itex]\varphi (\alpha x) = \alpha \varphi (x)[/itex] for all [itex]\alpha \in\mathbb{C} , x\in\mathfrak{g}\,?[/itex]
    Then this shows [itex]\varphi[/itex] is a homomorphism. Then how do I show that it is a bijective map to show [itex]\varphi[/itex] is an isomorphism? After this the question is answered is it not?
  15. Sep 14, 2011 #14
    Well, try to show that the function is injective and surjective. This is the last thing you need to do.
  16. Sep 14, 2011 #15
    Don't I have to show that it is linear (i.e. a linear transformation) to complete the proof of it being a homomorphism or is this clear already?
  17. Sep 14, 2011 #16
    Ah yes! But isn't that trivial?
  18. Sep 14, 2011 #17
    Yeah it is.
    Did I have to include the bit below in the argument? (Is it correct that I'm using the Lie bracket commutator in h to show that it satisifes the relations in g?)
    Also are there any theorems that I can appeal to to show that a homomorphism is an isomorphism rather than go through the injective/surjective proofs from first principles? Things like the Group and Ring theory theorems.
  19. Sep 14, 2011 #18
    Yes, this is good.
    I suppose there are also isomorphism theorems for Lie algebra's, but they're of no use here. It's very easy to show injective/surjective in this case!!
  20. Sep 14, 2011 #19
    Isn't [itex]\varphi[/itex] the identity function?
  21. Sep 14, 2011 #20
    No: E,F and G are not matrices in general.
