Lie derivative of vector field = commutator
In summary, the conversation discusses the Lie derivative of a vector field and how it can be expressed as [X,Y]_p. The conversation also mentions a proof using a special coordinate system and an elegant proof by Spivak. The conversation then delves into a discussion about the Lie derivative of scalar fields and the difference between evaluating at two different points versus using a diffeomorphism to evaluate at the same point.
Fredrik
Staff Emeritus
422
Can somone remind me how to see that the Lie derivative of a vector field, defined as
[tex](L_XY)_p=\lim_{t\rightarrow 0}\frac{\phi_{-t}_*Y_{\phi_t(p)}-Y_p}{t}[/tex]
is actually equal to [itex][X,Y]_p[/itex]?
Nevermind, I got it. Nakahara's book had the clue I needed to figure out the rest.
I tried to prove this again the other day, and I couldn't remember how. Then I remembered that I had started a thread about it some time ago. Unfortunately it turned out to be useless. I'm not sure what clue in Nakahara's book I was referring to in #2. I suspect it was the result that the Lie derivative can also be expressed as
[tex](\mathcal L_XY)_pf=\lim_{t\rightarrow 0}\frac{Y_p-\phi_t_*Y_{\phi_{-t}(p)}}{t}[/tex]
but I don't see how to use it (or prove it).
I would still like to prove the result I mentioned in #1, but I need some help filling in some missing details. A trick that seems promising is to add and subtract a term in the numerator:
[tex](\mathcal L_XY)_pf=\lim_{t\rightarrow 0}\frac{\phi_{-t*}Y_{\phi_t(p)}f-Y_pf}{t}=\lim_{t\rightarrow 0}\frac{Y_{\phi_t(p)}(f\circ\phi_{-t})-Y_{\phi_t(p)}f+Y_{\phi_t(p)}f-Y_pf}{t}[/tex]
Now the last two terms give me one of the terms of the commutator:
[tex]X_p(Yf)=\phi(p)_*D_0 (Yf)=D_0(Yf\circ\phi(p))=\frac{d}{dt}\bigg|_0 Y_{\phi_t(p)}f[/tex]
Here [itex]\phi[/itex] is the flow of X, and [itex]\phi(p)[/itex] is the map [itex]t\mapsto\phi_t(p)[/itex], i.e. the integral curve of X through p. [itex]D_0[/itex] is the operator that takes a real-valued function of one real variable to its derivative at 0.
So far so good, but I'm having difficulties with the rest. I think I have proved that
[tex]Y_p(Xf)=-\frac{d}{dt}\bigg|_0 Y_p(f\circ\phi_{-t})[/tex]
Edit: I said something dumb here, so I deleted it.
There's a simple proof using a special coordinate system. If you introduce a coordinate system {t, qa} such that X = ∂t, then the coordinates of the pushforward of Yp to φ(t) are the same as those of Yp, so the difference between Y at φ(t) at the pushforward of Yp is simply the ordinary derivative of Y with respect to t (since X is equal to ∂t) multiplied by t, so
[tex] \mathcal{L}_{X}{Y} = \frac{\partial Y^t}{\partial t}\partial_t + \sum_{a}\frac{\partial Y^a}{\partial t}\partial_a [/tex]
Evaluating the Lie bracket [∂t, Ytt + ∑Yaa], we get the same result:
[tex] [X, Y] = \frac{\partial Y^t}{\partial t}\partial_t + \sum_{a}\frac{\partial Y^a}{\partial t}\partial_a [/tex]
So, LXY = [X, Y] in this coordinate system, and this must be true in all coordinate systems because both sides are coordinate independent.
Thanks for the replies. I haven't been able to access the internet for a few days, so I haven't been able to reply. The Spivak proof was just what I needed. When I finally understood it (including the mistake he made in the definition of g), I was able to use the same idea to finish the proof I started in #3.
I was having some difficulties with the expression
[tex]\lim_{t\rightarrow 0}\frac{Y_{\phi_t(p)}(f\circ\phi_{-t})-Y_{\phi_t(p)}f}{t}[/tex]
To deal with this, we note that [itex]f\circ\phi_{-t}[/itex] is the function that takes [itex]q[/itex] to
[tex]f(\phi_{-t}(q))=f(q)+t\frac{d}{dt}\bigg|_0 f(\phi_{-t}(q))+\mathcal O(t^2)=f(q)-tX_qf+\mathcal O(t^2)[/tex]
so we have
[tex]f\circ\phi_{-t}=f-tXf+\mathcal O(t^2)[/tex]
and the rest is easy.
Fredrik said:
...the Lie derivative can also be expressed as
It's funny how dumb I can be sometimes. This identity seemed difficult to prove, but I eventually realized that you get this result immediately if you just set t'=-t in the definition in #1.
Yes, that was something which also took some time for me when I first read Nakahara :D It's nice to see that other people have similar issues ;)
I have a small question on this, which is about Lie derivatives of scalar fields (for simplicity). I'll simply write down my reasoning, and if someone finds a mistake I'll be happy to hear!
We can define a Lie derivative of a scalar field with respect to a vector field xi as
[tex]
\delta_{\xi}\phi(x) = \phi'(x) - \phi(x)
[/tex]
Here xi induces the coordinate transformation. I see this as the following: We first induce a coordinate transformation via xi,
[tex]
\phi(x) \rightarrow \phi'(x') , \ \ \ \ \ \ via \ \ \ \ \ \xi = x'-x
[/tex]
which means that we are switching from a coordinate system F to a coordinate system F'. From my point of view, {x} in the coordinate system F and {x'} in the coordinate system F' refer to the same point P on the manifold M. After that, we change our coordinate {x'} in F back to its original value x,
[tex]
x' \rightarrow x
[/tex]
Obviously, in the coordinate system F' the coordinate {x'} refers to the point p on M, so the coordinate {x} in F' refers to a new point q on the manifold M, right?
So, am I right if I say that in looking at the variation
[tex]
\delta\phi(x) = \phi'(x) - \phi(x)
[/tex]
we are comparing the fields at two different points p and q on M, and that this variation is basically a Lie derivative? Something goes wrong here, because if I define a Lie derivative via a diffeomorphism I see that I evaluate everything at one and the same point: you have a point p, and a point q=f(p) where f is a diffeomorphism on the manifold M, and you evaluate for a tensor field T the object T(q)=T(f(p)); after that, you use the differential map f* induced by f to pull this whole thing back to the original point p to compare f*T(f(p)) with T(p).
What's wrong with my reasoning?
haushofer said:
we are comparing the fields at two different points p and q on M, and that this variation is basically a Lie derivative? Something goes wrong here, because if I define a Lie derivative via a diffeomorphism I see that I evaluate everything at one and the same point ...
What's the contradiction? By pulling back structures by the infinitesimal diffeomorphism induced by the vector field, you are using information not present at point p.
-edit
The contradiction I'm seeing is that in my definition in the right hand side
[tex]
[/tex]
I'm really evaluating the two fields at different points on the manifold, while in the definition with diffeomorphisms I'm not; I compare two tensor fields at one and the same point on the manifold. How can this be?
T(f(p) is the value of T at the point q = f(p), as you said. q and p are not the same point.
No, but I pull the field T(f(p))=T(q) back to the original point p with the differential map, and f*(T(f(p)) IS evaluated in the point p. And this field you compare with T(p). And that's what I can't match up with my definition in terms of coordinates.
I'm missing something very silly here, I suppose.
But f(p) = q! Just because you write T(q) as T(f(p)) doesn't mean you're evaluating the field at p. The field is T, and it is evaluated at q. To compare with the field at the original point, it must be pulled-pulled back to that point, or you can push-forward T at the original point to q and compare it there.
This is what Lie differentiation means: A vector field is a family infinitesimal transformation of the manifold (call them φε). Think of vectors as equivalence classes of parametrized curves. Such a set at one point is mapped by φ to another point, and gives a vector at the new point. You can imagine this being done to each vector of the tangent space at a point p. Thus we have a map between tangent spaces at two points, P and φε(P); call this map f. Given another vector field v, the Lie derivative is lim ε → 0 of the vector (1/ε)(v(φε(P)) - f(v(P)). Similarly, you can define the Lie derivative of 1-forms, which are equivalence classes of functions. Once you have the Lie derivative of vectors anf 1-forms, you can Lie differentiate any tensor field.
Yeah, I see that now. But now the question is: how do you rephrase this in our "coordinate" definition of the Lie derivative which you often see,
[tex]
\delta_{\xi}T = T'(x) - T(x)
[/tex]
or T'(x') - T(x'), which shouldn't make a difference I suppose, because in the end you take the limit of xi = x'-x goes to 0.
So obviously this is a nasty question. Let me compare the passive and the active way of defining Lie derivative. That is, the coordinate way and the diffeomorphism way.
In
[tex]
\delta\phi(x) = \phi'(x) -\phi(x)
[/tex]
I first do a coordinate transformation [itex]\phi(x) \rightarrow \phi'(x') [/itex] and after that I set back the value of the coordinate x' back to x. This I compare with [itex]\phi(x)[/itex].
In the diffeomorphism expression I calculate the field at the point [itex]f(p)[/itex] and after that I use the differential map [itex]f_*[/itex] to pull this expression back to the point p via [itex]f_*\phi(f(p))[/itex]. This I compare with [itex]\phi(x)[/itex].
How can i rephrase these two situations into each other? There seems to be some sort of duality, but I still can't see it, and that was a problem I already had quite some time ago.
Can you explain more clearly what the 'coordinate definition' is? What is the 'coordinate definition' of the lie derivative of a vector field v with respect to a vector field w?
The "coordinate definition" (by which I mean a definition in terms of the coordinates, without mentioning diffeomorphisms on the manifold) can be found in books like d'Inverno, and is defined as
[tex]
[/tex]
or
[tex]
\delta_{\xi}T = T'(x') - T(x')
[/tex]
with xi infinitesimally.
Well, that's just notation. You haven't explained what x' and x are and how they are related. Where does the vector field with respect to which the differentiation is being performed come in? What is T'? I don't have d'Inverno and I have found no pages online which describes this. I also don't see any limits, which is weird because the Lie derivative is defined as a limit.
I'll be using the same notation as I did earlier. The Lie derivative of a function f in the direction of a vector field X is defined as
[tex]\mathcal L_Xf=\lim_{t\rightarrow 0}\frac{\phi_t^*f-f}{t}[/tex]
So if x is a coordinate system, we have
[tex]\mathcal L_Xf(p)=\lim_{t\rightarrow 0}\frac{f\circ\phi_t(p)-f(p)}{t}=\lim_{t\rightarrow 0}\frac{f\circ\phi_t\circ x^{-1}\circ x(p)-f\circ x^{-1}\circ x(p)}{t}[/tex]
[tex]=\lim_{t\rightarrow 0}\frac{F_t(x(p))-F_0(x(p))}{t}[/tex]
where I have defined [itex]F_t=f\circ\phi_t\circ x^{-1}[/itex]. The above takes the form
[tex]=\lim_{t\rightarrow 0}\frac{F'(x)-F(x)}{t}[/tex]
if we agree to write x instead of x(p), F instead of F0, and F' instead of Ft.
This is probably what you're looking for, at least for scalar fields. I'm sure we can do something similar for arbitrary tensor fields, but I don't see why we would want to. I consider d'Inverno's notation and terminology obsolete.
Yeah, I agree, but d'Inverno was my first exposition to the subject, and I became curious how the coordinate free formalism is connected to the formalism like d'Inverno's. Thanks for the answer, I'll check it for arbitrary tensor fields and give it some thought tomorrow! :)
What is the definition of a Lie derivative of a vector field?
The Lie derivative of a vector field is a mathematical operation that describes the change of a vector field along the flow of another vector field.
What is the commutator in this context?
The commutator, also known as the Lie bracket, is a mathematical operation that measures the extent to which two vector fields do not commute with each other (i.e. the order in which they are applied matters).
How is the Lie derivative of a vector field related to the commutator?
The Lie derivative of a vector field is defined as the commutator of the vector field with the flow of another vector field. In other words, it measures the infinitesimal change of the vector field as it is "dragged along" by the other vector field.
What is the physical significance of the Lie derivative of a vector field?
The Lie derivative of a vector field has a variety of physical interpretations, such as describing the rate of change of a physical quantity along a trajectory or the change in a vector field due to a transformation of coordinates. It is also used in fields such as fluid mechanics and general relativity.
How is the Lie derivative of a vector field calculated?
The calculation of the Lie derivative of a vector field involves taking the commutator of the vector field with the flow of another vector field and then applying it to the original vector field. This can be done using various mathematical techniques, such as differential calculus and differential geometry.
  • Differential Geometry
