Domed Cities on Mars: Life, Temperature & Light
  • Thread starter GTOM
  • Tags
    Life
In summary, the idea is that a dome on Mars could be made out of silica aerogel, which would allow the inhabitants to grow plants and get enough sunlight. However, this would require artificial light, and it's not clear if this is really feasible or practical.
GTOM
955
64
Lets suppose we could build domed cities on Mars.
The surface of the planet has major temperature shifts. Would people inside the domes experience such things too, or no, since if the dome can provide enough radiation protection, it provides enough heat insulation too? With present day anti-rad materials, could they have enough visible light for plants and everything else, or should they have artifical lighting during daytime too?
Likes 256bits
That's a good question.
As a physical barrier, just like a window in a house, which keeps warm air in a cold air out, or vice versa.
Would the thin Martian atmosphere have a significant conductive and convective heat transfer coefficient acting upon the dome barrier for the inhabitants to worry about if their heat source malfunctioned. Could the dome be made opaque or reflective to long wavelength heat radiation produced within the interior, while at the same time passing radiation from the sun for the plants and to also warm the interior.
If you want to get to Earth-level radiation you'll need thick shielding. Not impossible with glass but impractical. Plants for food will grow better in a place with thinner shielding. They won't mind elevated radiation doses.
Likes GTOM
mfb said:
If you want to get to Earth-level radiation you'll need thick shielding. Not impossible with glass but impractical. Plants for food will grow better in a place with thinner shielding. The won't mind elevated radiation doses.
Well i thought about lead glass or something like that.
https://www.sciencedirect.com/science/article/abs/pii/S0925838817329754
That talks about borate glass. I don't know what kind of materials can be easily mined on Mars.
Yes, green areas can have lighter protection than actual living places, there can be a mixed underground/dome solution.
If the inhabitants can feel it then the engineers had messed up, no?
A better question would be about the necessary effort to prevent the (noticeable, or: inconvenient) temperature shifts.
The solar irradiation on Mars is ~ half of what you get on Earth. Based on this I think light would be barely enough outside. Inside - that depends on the material of the dome.
Honestly, I think artificial light will be necessary and that makes this dome-thing questionable in whole. Maybe a cave with only a decent sized PV array outside would work better?
This article, from Nature Astronomy 2019, seems relevant: Enabling Martian habitability with silica aerogel via the solid-state greenhouse effect.
The authors' pertinent conclusion is this:
we demonstrate via experiments and modelling that under Martian environmental conditions, a 2–3 cm-thick layer of silica aerogel will simultaneously transmit sufficient visible light for photosynthesis, block hazardous ultraviolet radiation and raise temperatures underneath it permanently to above the melting point of water, without the need for any internal heat source.
The article is behind a paywall, but this
Smithsonian Magazine article discusses the idea in some detail.
Likes GTOM
1. What is a domed city on Mars?
A domed city on Mars is a hypothetical structure that could potentially sustain human life on the red planet. It would be a large, self-contained dome-like structure that would provide a habitable environment for humans to live and work in on Mars.
2. How would a domed city on Mars support life?
A domed city on Mars would be equipped with all the necessary systems and resources to support human life. This could include air and water filtration systems, food production facilities, and waste management systems. Additionally, the dome itself would protect inhabitants from the harsh Martian environment, including extreme temperatures and radiation.
3. What would the temperature be like inside a domed city on Mars?
The temperature inside a domed city on Mars would be regulated and controlled by the city's environmental systems. However, due to Mars' thin atmosphere and lack of a strong magnetic field, the temperature would likely be significantly colder than on Earth. It would be important for the dome to have proper insulation and heating systems to maintain a habitable temperature for humans.
4. How would light be provided inside a domed city on Mars?
Light inside a domed city on Mars could be provided through a variety of methods. One option could be through artificial lighting systems powered by solar panels. Another option could be to use mirrors or reflective surfaces to redirect natural sunlight into the dome. It would also be important for the dome to have windows or other openings to allow for natural light to enter.
5. What are the challenges of building a domed city on Mars?
Building a domed city on Mars would present numerous challenges, including the harsh Martian environment, limited resources, and the need for advanced technology and engineering. The transportation of materials and construction of the dome itself would also be a significant undertaking. Additionally, the long-term sustainability of a domed city on Mars would require careful planning and management of resources.
  • Astronomy and Astrophysics
37K
  • Aerospace Engineering
  • General Engineering
