Understanding Stellar Lifespans: Comparing Luminosity & Mass
In summary: This estimate can be calculated using the formula:In summary, to find out how much longer a star will live compared to another, one can use a stellar evolution simulation for a precise result or an order of magnitude scaling for an approximate result. The mass of the star plays a crucial role in its lifespan, with more massive stars having shorter lifespans. The general scaling formula is \tau \sim 10^{10} \textrm{ yrs} \left( \frac{M}{M_\odot}\right)^{-3}, although it may vary depending on the mass range. This formula is based on the assumptions that the temperature of the star is determined by equipartition, the luminosity is thermal, and the amount of
tommyboo
Hi, all how would you go about finding out how much longer a star would live compared to another if you knew the one star was x times more luminous and y times more massive?
Astronomy news on Phys.org
For a precise result, you would use a stellar evolution simulation to calculate the result numerically. For an approximate result, you can use an order of magnitude scaling for how long stars live---which is determined primarily by its mass.
[tex]\tau \sim 10^{10} \textrm{ yrs} \left( \frac{M}{M_\odot}\right)^{-3}[/tex]
*The more massive the star, the (much) shorter its lifetime is, because its luminosity increases rapidly.
Depending on the mass range, the exponent can range somewhat (between about 2 and 3), but this is the general scaling. If you're curious about how to derive it, its based on a few simple assumptions---namely, the temperature of the star is determined by equipartition (i.e. its 'virialized'), the luminosity is thermal, and the amount of fuel is linearly related to the mass of the star.
I think you inverted M/Msolar, zhermes. The customary formula is
10^10 x 1/M^2.5 where M is in solar masses
re: http://mais-ccd-spectroscopy.com/Stellar%20Evolution%20Lesson.pdf
Chronos said:
I think you inverted [itex] M/Msol [/itex]zhermes.
Oh, damn. Thanks Chronos!
The mass-luminosity index is more like 4.75 for stars from 0.7-2.0 times the Sun's mass. Very low mass stars are more convective than such Sun-like stars, and so fuse more of their fusion fuel during the Main Sequence. At the other end of the scale the index is more like 3, and high-mass stars live very rapidly indeed - typically just a few million years. Interestingly they ramp up in core temperature and fuse their way through heavier elements with very little change.
Stars are having gases like hydrogen and helium as their elemental compositions.They are continiously active in their core region.The life of star is dependent on this activity and quite difficult to measure it.
1. What is the relationship between a star's luminosity and its mass?
The luminosity of a star is directly proportional to its mass. This means that the more massive a star is, the more luminous it will be. This relationship is known as the mass-luminosity relationship.
2. How does the mass of a star affect its lifespan?
The mass of a star plays a crucial role in determining its lifespan. Generally, the more massive a star is, the shorter its lifespan will be. This is because more massive stars burn through their fuel at a faster rate, leading to a shorter overall lifespan.
3. Can a low-mass star have a longer lifespan than a high-mass star?
Yes, a low-mass star can have a longer lifespan than a high-mass star. This is because low-mass stars have less mass to burn through, so they use up their fuel at a slower rate and can live for billions of years.
4. Is there a limit to how massive a star can be?
Yes, there is a limit to how massive a star can be. This limit is known as the Eddington limit and is determined by the balance between the outward pressure of radiation and the inward pull of gravity. If a star exceeds this limit, it will face instability and potentially explode as a supernova.
5. Can a star's luminosity change over its lifespan?
Yes, a star's luminosity can change over its lifespan. As a star burns through its fuel, it will eventually run out and can either become a white dwarf, a neutron star, or a black hole. Each of these objects has a different luminosity, so the overall brightness of the star will change as it evolves.
  • Astronomy and Astrophysics
