Homework Help: Lifting Line Code in Matlab
  1. Nov 24, 2013 #1
    My apologies if the error is an obvious one and many thanks in advance for any help given:
    I am trying to create a Matlab code that simulates Lifting Line Theory in order to provide an estimate of the lift and drag of a 3D wing. My hope is to later use this as part of an optimization routine for the wing design.
    The plot showing the variation of the lift distribution with taper ratio appears to be the wrong way round. That is, it shows that the lift generated at the wing tip is greater for a smaller taper ratio. I thought that it should be the other way around (more taper, less lift generated at the wing tip).
    2. Relevant equations
    Code based on the one presented in the following document:
    http://faculty.dwc.edu/sadraey/Chapter 5. Wing Design.pdf
    3. The attempt at a solution
    % Lifting Line Code
    clc;clear all;close all
    % Input Wing Geometry
    for Lambda = 0.25:0.25:1
    % Number of wing segments
    N_seg = 30;
    % Wing Area [m^2]
    S = 65;
    % Aspect Ratio
    AR = 25;
    % Twist [deg]
    twist = -6;
    % Wing Setting Angle/ AoA [deg]
    set_ang = 2;
    % Wingspan [m]
    b = sqrt(AR*S);
    % Input Aerofoil Data
    % Lift Curve Slope [1/rad]
    slope = 6.9;
    % Mean Aerodynamic Chord
    MAC = S/b;
    % Zero Lift Angle of Attack
    zl_AoA = -6.56;
    % root chord (m)
    Root_Chord = (2*S) / ((1 + Lambda) * b);
    % tip chord (m)
    Tip_Chord = ((2*S) / ((1 + Lambda) * b)) * (1 - ((2* (1 - Lambda)) / b) * (b/2) );
    % MAC
    MAC = (2/3) * (Root_Chord + Tip_Chord - (Root_Chord*Tip_Chord) / (Root_Chord +Tip_Chord));
    % Lifting Line Algorithm
    theta = pi/(2*N_seg):pi/(2*N_seg):pi/2;
    % create vector containing each segment's angle of attack
    alpha = set_ang + twist: -twist/(N_seg-1):set_ang;
    z = (b/2)*cos(theta);
    % Mean Aerodynamic Chord at each segment (m)
    c = Root_Chord * (1 - (1-Lambda)*cos(theta));
    mu = c * slope / (4 * b);
    LHS = mu .* (alpha-zl_AoA) * (pi/180);
    % Determine Coefficients A(i) by Solving N_seg Equations:
    for i=1:N_seg
    for j=1:N_seg
    B(i,j) = sin((2*j-1) * theta(i)) * (1 + (mu(i) * (2*j-1)) / sin(theta(i)));
    end
    end
    A=B\transpose(LHS);
    for i = 1:N_seg
    sum1(i) = 0;
    sum2(i) = 0;
    for j = 1 : N_seg
    sum1(i) = sum1(i) + (2*j-1) * A(j)*sin((2*j-1)*theta(i));
    sum2(i) = sum2(i) + A(j)*sin((2*j-1)*theta(i));
    end
    end
    % Determine Lift Coefficient For Each Segment
    CL = 4*b*sum2 ./ c;
    % Plot Lift Distribution
    CL1=[0 CL];
    y_s=[b/2 z];
    if Lambda == 0.25
    plot(y_s,CL1,'-o')
    elseif Lambda == 0.5
    plot(y_s,CL1,'-*')
    elseif Lambda == 0.75
    plot(y_s,CL1,'-s')
    else
    plot(y_s,CL1,'-d')
    end
    hold on
    % Output Lift Coefficient for Wing
    CL_wing = pi * AR * A(1)
    % Output Oswald Efficiency Factor Induced Drag Coefficent
    for n = 2:30
    delta(n) = n * (A(n)/A(1))^2;
    end
    delta1 = sum(delta);
    e = 1 / (1 + delta1)
    CD_induced = CL_wing^2 / (pi * e * AR)
    end
    % Plot Elliptical Lift Distribution For Comparison
    y_ellipse = linspace(0,(b/2),100);
    for i = 1:length(y_ellipse)
    CL_ellipse(i) = CL1(end) * sqrt(1 - ((2*y_ellipse(i)) / b)^2 );
    end
    plot (y_ellipse, CL_ellipse, 'r-')
    grid on
    title('Variation of Lift distribution with Taper Ratio')
    xlabel('Semi-Span Location [m]')
    ylabel ('C_L')
    legend('location','best','Lambda = 0.25','Lambda = 0.5','Lambda = 0.75','Lambda = 1','Elliptical Lift Distribution')
  3. Nov 24, 2013 #2
    jedishrfu
    Staff: Mentor
    could you please edit your post and bracket your code listing with code tags?
    It will look much nicer on the eyes and will preserve indentations.
    Also you haven't said what the error is.
  4. Nov 24, 2013 #3
    Apologies, but I'm not sure how to go about doing that. I am a Matlab, and coding in general, novice.
    The error is in the plot that is generated - higher taper ratios have a better efficiency (closer to elliptical lift distribution) which I don't think should be the case. Many thanks for any help you can provide.
  5. Aug 20, 2014 #4
    Hi HACRS4,
    I'm not sure that i perfectly understand your question. I have tried to use your code, and I noticed that the efficiency goes from a minimum to a maximum and then decreases again while lambda goes from 1 to 0.25. This is exactly what is suppose to happen. In fact for a fixed aspect ratio wing the maximum efficiency should happen at a tapper ratio of approximately 0.4.
    Don't know if it was of any help or if it was too late. But I have actually used your code in my master thesis to do some simple calculations, and I also added the functionality to calculate the best linear wash-out geometric twist. Unfortunately I can't make a proper reference to your work. If you are so kind to tell me who to reference to I will.
    Thanks you in advance
  6. Aug 20, 2014 #5
    SteamKing
    Staff Emeritus
    It's pretty simple to add
    Code (Text):
     tags to your reply.
    You can hit the 'Go Advanced' tab at the bottom of the page and select the icon at the top which looks like a sheet of paper with a '#' on it.
    To check what you've done, hit the 'Preview Post' button and check the post before hitting the 'Submit Reply' button.
  7. Aug 20, 2014 #6
    AlephZero
    Don't hold your breath waiting for a response. Check the dates of the previous posts :smile:
  8. Aug 20, 2014 #7
    SteamKing
    Staff Emeritus
    Ah, the necropost!
  9. Aug 26, 2014 #8
    gsb
    hi, i am having some problem with a code in matlab. my code is:
    t = 30;
    H= 30;
    h= 3;
    n = H/h;
    qqq= 10;
    a= 3;
    b = .2;
    k= 0.04;
    Lo= 100;
    g= 9.81;
    for i = 1:t
    q(i) = 0;
    for j = 1:n
    nl = qqq + (j*h)/(a + b*(j*h));
    nlt = nl*(0.0172*log(i) + 1);
    q(i) = q(i) + 2*k*(Lo/100)*(nlt/3)*g*exp(-k*(i));
    end
    plot((1:t), q);
    end
    this is the code and i keep getting this error- "Attempted to access q(2); index out of bounds because numel(q)=1."
    help would be greatly appreciated.
    thanks
Have something to add?
Draft saved Draft deleted
