Homework Help: Light Interference Lab
  1. Apr 28, 2012 #1
    When you shine light through a diffraction grating/double slit/single slit, I understand that you see an interference/diffraction pattern on the wall, so that you have:
    light source -- grating/slit ---pattern on wall
    But if you put a grating/slits between your eyes and a light source, why do you see a pattern on the wall in the direction of the light source? i.e. the configuration
    eyes --- slits --- light source --- pattern on wall
    as opposed to
    pattern on wall/eyes --- slits --- light source
    Thanks!
  3. Apr 28, 2012 #2
    Most likely light sources behind you, or reflection (if I understand your question).
  4. Apr 28, 2012 #3
    How would reflection work?
  5. Apr 28, 2012 #4
    If we go by vector diffraction theory we see that the field behind the aperture is
    [tex]\vec{E}(\vec{x})=\vec{E}^{(0)}(\vec{x})+ \vec{E}^{(1)}( \vec{x} )-
    \vec{E}_{diff}(\vec{x})[/tex]
    Where E^0 and E^1 describes the sources behind the aperture given a perfectly conducting plane at the aperture plane.
    I'm sure you just want to cut the chase though. In the region behind the aperture, we see both the reflections of the source AND the diffraction pattern. So you can see, the diffraction pattern is produced both in front, and behind the aperture.
  6. Apr 28, 2012 #5
    Are the diffraction patterns produced in front and behind the aperture the same? (so you see one image)?
    Thank you! :)
  7. Apr 28, 2012 #6
    jtbell
    Staff: Mentor
    First, where does the light actually end up? (what is the actual "screen" in this situation?)
    Second, what kind of sensations would you expect this to produce?
  8. Apr 28, 2012 #7
    The diffraction itself will be same, but the image will be different. Since detectors (such as eyes) measure the field's intensity, in the reflection case there are three terms that contribute to intensity as a function of position.
  9. Apr 28, 2012 #8
    The light that goes through the slits hits your eyes so your eye is the screen?
    So the light is reflected off your eyes?
    Uhhh... your eye hurts?
    But if there are two images, why do you only see one?
    Thanks you guys!!
Loading...
Similar Threads for Light Interference Date
Double Slit Wave Interference - what is m? Apr 3, 2018
Light wave Interference - Angler Fish Problem Jan 18, 2018
Interference of several waves Jan 11, 2018
Number of fringes in YDSE Dec 20, 2017
Interference in thin films Dec 11, 2017
