B Light propulsion
  1. Nov 23, 2016 #1
    Hello all,
    Is electromagnetic radiation considered a driving factor of intergalactic space expansion similar to directed energy propulsion? I assume every point in space has countless photons passing through it from every direction at all times.
  3. Nov 23, 2016 #2
    PeterDonis
    Staff: Mentor
    Not at present, no. The energy density in EM radiation is much too small to matter in the universe at present. In the early universe, the energy density in radiation was much larger relative to other energy densities; then it did have a significant effect on the dynamics of the expansion.
    I'm not sure what you're referring to here.
  4. Nov 23, 2016 #3
    Orodruin
    Staff Emeritus
    2017 Award
    To expand (haha) on this a bit in relation to the OP
    In a radiation dominated flat universe the expansion is decelerating as ##a\propto \sqrt t##. In that sense, radiation never drives expansion.
  5. Nov 23, 2016 #4
  6. Nov 23, 2016 #5
    PeterDonis
    Staff: Mentor
    Ah, ok. Then the answer to that part of your question is that beam powered propulsion has nothing to do with the effect (if any) that radiation energy density has on the dynamics of the universe's expansion. Beam powered propulsion means radiation is pushing against some part of a spacecraft or other object. There is no sense in which radiation is pushing against the universe to expand it.
  7. Nov 23, 2016 #6
    I want to learn the meaning of these types of equations but it's been years since I've done any algebra, let alone anything related to physics. Are there any comprehensive reference guides for variables used in astrophysics online?
    Is this equation correct to calculate the current radiant energy density of the first photons emanated from the big bang:
    w
    e = Qe / ctH
    Or in case I used the wrong variables: radiant energy density = radiant energy / (speed of light x time x Hubble expansion rate)
  8. Nov 23, 2016 #7
    PeterDonis
    Staff: Mentor
    No. First, the units aren't right; the denominator on the right doesn't have units of volume (length cubed). Second, the "radiant energy" ##Q_e## is not a meaningful quantity; according to our best current models, the universe is spatially infinite, so there is no finite "total energy" contained in photons (or anything else). And if you try to just count the photons in our observable universe, that doesn't give you a meaningful "total energy" either, since photons can move into and out of our observable universe so you aren't counting a constant number of photons. (The same goes for any other particles.)
    The energy density of various kinds of substances is actually the fundamental variable in cosmology. What distinguishes the dfifferent kinds of substances in cosmology ("matter", "radiation", "dark energy" are the three main ones) is how their energy density behaves as the universe expands. "Matter" has an energy density that decreases as the cube of the scale factor; "radiation" (like photons) has an energy density that decreases as the fourth power of the scale factor; and "dark energy" has a constant energy density (at least as far as we can tell), it doesn't change as the universe expands.
  9. Nov 23, 2016 #8
    Thank Peter, this gives me a lot to chew on.
    Do these variables apply equally to substances in the protective orbit of a galaxy as they do substances in intergalactic space?
  10. Nov 24, 2016 #9
    PeterDonis
    Staff: Mentor
    The "substances" I was referring to are not individual objects like stars or planets or people. They are averaged distributions of energy density over very large distance scales, hundreds of megaparsecs and larger. The dynamics of the universe as a whole is driven by these average energy densities; the corrections due to the fact that the universe is not actually filled with a continuous fluid but instead with galaxies, stars, etc. separated by mostly empty space are too small to matter for most purposes.
  11. Nov 25, 2016 #10
    Gotcha, that makes sense. Is it accurate to say every point in this empty space has a very large number of electromagnetic waves of varying energies passing through it from nearly all directions?
  12. Nov 25, 2016 #11
    PeterDonis
    Staff: Mentor
    Sure, since the empty space will contain radiation from various stars and other light-emitting objects, and also the CMBR.
  13. Nov 25, 2016 #12
    I think the equation I was looking for in post #6 can be derived from the standard Doppler effect, to determine the spaghettification of infant EM waves from the big bang.
    fo = fc / ct
    where
    • fo is the observed frequency
    • f is the emitted frequency
  14. Nov 25, 2016 #13
    If this equation is correct, we should be able to calculate the original frequency of CMBR by:
    f = foc2(t0 - te)
    where
    • t0 is the age of the universe
    • te is the age of the universe emitting CMBR
  15. Nov 25, 2016 #14
    PeterDonis
    Staff: Mentor
    Which equation?
    This equation doesn't even have the correct units. The correct equation is
    1 + \frac{f_0}{f} = 1 + z = \frac{a}{a_0}
    where ##a## is the scale factor of the universe now and ##a_0## is the scale factor at the time of emission of the CMB. This equation is actually used in reverse, since we can directly observe the redshift ##z## of the CMB, to calculate ##a_0##. Relating the ratio ##a / a_0## to the time (in FRW coordinates) from CMB emission to now is a little complicated since the universe has switched from radiation dominated to matter dominated to dark energy dominated during that time, so the relationship between the scale factor and time has not been the same all along.
  16. Nov 25, 2016 #15
    Nice thanks Peter, wasn't sure if accounting for redshift was necessary, makes sense though.
    I posted another equation in post #12.
  17. Nov 25, 2016 #16
    PeterDonis
    Staff: Mentor
    Ok. That one isn't correct either (and the units aren't right).
  18. Nov 25, 2016 #17
    russ_watters
    Staff: Mentor
    2. The EM radiation in the universe is traveling in all directions, so even if it was pushing on "space", it would be pushing in all directions and thus cancel itself out.
  19. Nov 26, 2016 #18
    Sean Carroll's Dark Energy FAQ calculates its leading candidate "vacuum energy" to be "a fixed amount of energy attached to every tiny region of space, unchanging from place to place or time to time. About one hundred-millionth of an erg per cubic centimeter", or 10-9 joules (10-2 ergs) per cubic meter (10113 joules per cubic meter per QFT).
    http://www.preposterousuniverse.com/blog/2011/10/04/dark-energy-faq/
    Is the ratio between EMR and dark energy in a region of spacetime calculated, or even possible to calculate at this time?
    [Moderator's note: personal speculation deleted.]
  20. Nov 26, 2016 #19
    PeterDonis
    Staff: Mentor
    There is no fixed ratio of these two energy densities. The two types of energy densities behave differently as the universe expands, so the ratio changes with time. At present, IIRC the energy density in EM radiation (the major component of which is the CMBR) is about 4 orders of magnitude smaller than the energy density of dark energy. I'll try to find a reference.
  21. Nov 26, 2016 #20
    PeterDonis
    Staff: Mentor
    @stoomart, I have deleted the part of your latest post that you flagged with a "layman crackpot warning". If you feel the need to put something like that in front of something you intend to post, it means you shouldn't be posting it in the first place. Please bear in mind the PF rules on personal theory/speculation.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Light propulsion
  1. Light Cones (Replies: 0)
  2. Speed of light? (Replies: 2)
  3. Speed of light (Replies: 3)
  4. Tired light (Replies: 24)
  5. Light and Time (Replies: 7)
Loading...
