How Far is the Third Interference Minimum in a Double Slit Experiment?
  • Thread starter wahsup13
  • Tags
    Light Pair
In summary, the question is asking for the distance from the center of the pattern to the third interference minimum, given the wavelength of light (655 nm), the distance between the slits (245 µm), and the distance to the screen (9.0 m). Using the equations sinθ=λm/d and tanθ=y/D, it is determined that the third maximum is found at m=3. To find the minimum, m needs to be adjusted to m=2.5. This results in a distance of 72.2 mm from the center of the pattern to the third interference minimum.
wahsup13
Light of wavelength = 655 nm passes through a pair of slits that are 245 µm apart and travels to a screen 9.0 m away. How far from the center of the pattern is the third interference minimum? (in mm)
d=245e-6
λ=655e-9
m=3
D=9
y=distance from center of 3rd interference minimum
sinθ=λm/d
tanθ=y/D
sinθ=λm/d=(655e-9)(3)/(245e-6)
θ=0.4595 degrees
tanθ=y/D
y=Dtanθ=9tan(0.4595)
y=0.722m=72.2mm (incorrect)
Hi Wahsup, welcome to PF!
It seems to me you have found the 3rd maximum, but the question asks for the MINIMUM. You'll just have to adjust your m value.
thanks!
if m=3 is the max, would that mean m=2 is the min?
nevermind. i got it.
Since m=3 is the max, the min is m=2.5
thank you for the help
1. What is the concept behind "Light Through a Pair Slits"?
The concept behind "Light Through a Pair Slits" is that when light passes through two narrow slits, it diffracts and creates an interference pattern.
2. How does diffraction contribute to the interference pattern in "Light Through a Pair Slits"?
Diffraction is the bending of light as it passes through the slits, creating a pattern of light and dark bands known as an interference pattern.
3. What is the significance of the distance between the slits in "Light Through a Pair Slits"?
The distance between the slits plays a crucial role in determining the spacing of the interference pattern. The smaller the distance, the wider the spacing between the bands.
4. How does the wavelength of light affect the interference pattern in "Light Through a Pair Slits"?
The wavelength of light determines the spacing of the interference pattern. The smaller the wavelength, the wider the spacing between the bands.
5. What other factors can affect the interference pattern in "Light Through a Pair Slits"?
The intensity of the light source, the angle of the light passing through the slits, and the material of the slits can all affect the interference pattern in "Light Through a Pair Slits".
