- 135
Can anyone tell me how light waves propogate. Will a photon have a trailing cone?
If a photon left a trailing cone, like a wake behind a boat or any other body moving through a medium, then we would be able to track its progress. But we can't.Can anyone tell me how light waves propogate. Will a photon have a trailing cone?
The way to test this would be to have two spheres one inside the other. The inner sphere would contain the slits as in the two slit experiment with a photon fired through. Detecting a 360 degree interference pattern around the sphere would be a proof.
You could also have two cones one within the other at a set angle.
Any experiment that you can devise in an arbitrary inertial state that is supposed to identify the propagation of light will result in a false positive. So you better only do the experiment one time since on the surface of the earth, we are continually changing our approximately inertial state (due to the rotation of the earth, its revolving around the sun and the motion of the sun through our galaxy) and you apparently want to ignore all the other experiments that already confirm that we cannot identify the propagation of light.Interestingly if this worked you may actually measure the size of a photon.
You haven't heard of the Michelson Morley Experiment?I haven't read the experimental data. Do you have any links?
How do you expect to film a photon? It's not a bullet that you can shine a light on and see it from reflected light. A photon is light traveling away from you or on some path that doesn't intersect you. If it does intersect you, particularly in the eye, that's the end of the photon and you see it when it arrives at your eye but it doesn't provide a clue about when and where it was on its way to you, does it?I have read it and digested it. The interference patterns are very interesting. In particular the spacing and width of the dark band. This doesn't, however preclude what I was saying in the first instance. Light speed is constant to all observer's. Whatever frame you are in. There is a peculiarity to light that no one seems to have noticed. If it were possible to film a photon from directly behind as it was fired, what would you record? The photon is traveling away from the observer. Would you still record it? Would you record it's entire journey to its target?
You have not suggested an experiment. All you did was say something that is gibberish and assume it means something. The phrase "...film a photon from directly behind as it was fired..." is meaningless at best. Scientists (and not just scientists!) film photons all the time. How photons are "filmed" is understood exquisitely well. You "film" a photon by colliding a detector with it. Period.How do you know you are right? Have you tried the suggested experiment?
"Will it leave a trailing cone?" Is not an experiment either. Your "sphere experiment" is just the double slit experiment and it doesn't produce the results you suggest.I also suggested the sphere and cone experiments.
Of course. Spacecraft do this. Heck, you can test this yourself by looking at satellites from your backyard.OK how about this. If you had two spacecraft outside the earth's atmosphere that shine a wide beam of light directly from one to the other so that the photons are absorbed completely at the target, would you see the light? There is no medium through which it travels so reflection would not be an issue.
No, you would not see the beam. Yes, it is invisible.Would you see it through a telescope? It is not travelling in your direction. Working from your argument the light beam would be invisible.
No, you would not see the light. How could you, you just said "the photons are absorbed completely at the target".OK how about this. If you had two spacecraft outside the earth's atmosphere that shine a wide beam of light directly from one to the other so that the photons are absorbed completely at the target, would you see the light?
If you want to see the beam, then you need to have some kind of an atmosphere to reflect part of the light back to you.There is no medium through which it travels so reflection would not be an issue. Would you see it through a telescope? It is not travelling in your direction. Working from your argument the light beam would be invisible.
