Lightning Strike: Examining Electric Field, Capacitance & Power
In summary, the storm clouds build up large negative charges in a charge center located 10 km above the ground. A charged capacitor is formed between the charge center and the ground, with a potential difference of 4 x 10^8 V. The electric field between the two electrodes can ionize the air and create a conducting path. To find the magnitude of the electric field between the charge center and ground, you must use the equation E=V/d, where V is the potential difference and d is the distance between the electrodes. The capacitance of the system can be found using the equation C=Q/V, where Q is the charge and V is the potential difference. Finally, to find the average power when the cloud transfers all
bkl4life
25
Lighting strike: Storm clouds build up large negative charges that dwell in a charge center. Suppose a storm cloud has -25 C in a charge center located 10 km above the ground. The negative charge center attracts an equal amount of positive charge that is spread on the ground below the cloud. The charge center and the ground function as a charged capacitor, with a potential difference of 4 x 10^8 V. The large electric field between these two electrodes may ionize the air leading to a conducting path between the cloud and the ground.
a) What is the magnitude of the electric field between the charge center and the ground?
b) What is the capacitance of the charge center ground system?
c) If the cloud transfers all of its charge to the ground via several rapid lighting flashes lasting a total of 1 s what is the average power.
I started off by using F=k(q'*q')/r^2
-25=8.99*10^9*(4 *10^8)(q')/(10,000)^2
q'=-3.29*10^-10.
Am I even on the right track?
Uh, no, not really.
You're plugging in 4 *10^8 for the charge, but that number refers to the potential, not the charge.
You're plugging in -25 for the force, but that number refers to the charge, not the force.
Hint for (a): the units of electric field are Volts per meter. You are given a voltage, and a distance in meters.
(b): there should be an equation defining capacitance in your textbook. It involves voltage and charge, which are given in the problem statement.
Get those, and then we'll work on (c).
I appreciate your attempt at applying the fundamental equation for electric force. However, in this situation, we are dealing with a charged capacitor, not just a single point charge. Therefore, we need to use different equations to calculate the electric field, capacitance, and power.
a) To calculate the electric field between the charge center and the ground, we can use the equation E = V/d, where E is the electric field, V is the potential difference, and d is the distance between the two electrodes. Plugging in the given values, we get:
E = (4 x 10^8 V) / (10 km) = 4 x 10^4 V/m
b) The capacitance of a charged capacitor is given by the equation C = Q/V, where C is the capacitance, Q is the charge, and V is the potential difference. Plugging in the values given, we get:
C = (-25 C) / (4 x 10^8 V) = -6.25 x 10^-8 F
Note that the negative sign indicates that the charge on the cloud is opposite in sign to the charge on the ground.
c) To calculate the average power, we can use the equation P = IV, where P is the power, I is the current, and V is the potential difference. In this case, the current is equal to the charge transferred divided by the time, so we have:
P = (Q/t) * V
Since the cloud transfers all of its charge (-25 C) in a total time of 1 s, the average power would be:
P = (-25 C / 1 s) * (4 x 10^8 V) = -1 x 10^10 W
Again, the negative sign indicates that the power is being transferred from the cloud to the ground. This is a very large amount of power, which is why lightning strikes can be so destructive.
In conclusion, to fully understand the electric field, capacitance, and power involved in a lightning strike, we need to consider the charged capacitor formed by the storm cloud and the ground. By applying the appropriate equations, we can calculate the magnitude of the electric field, the capacitance, and the average power involved in this phenomenon.
1. What causes lightning strikes?
Lightning strikes are caused by a buildup of electric charge in the atmosphere, typically between a negatively charged storm cloud and the positively charged ground. When the charge separation becomes large enough, it creates a powerful electric field that can result in a lightning strike.
2. How does capacitance play a role in lightning strikes?
Capacitance is the ability of a system to store electric charge. In the case of a lightning strike, the buildup of electric charge in the atmosphere is a result of capacitance. The larger the capacitance between the storm cloud and the ground, the more energy can be stored and released in a lightning strike.
3. What factors affect the strength of an electric field in a lightning strike?
The strength of an electric field in a lightning strike is affected by several factors, including the distance between the storm cloud and the ground, the amount of charge buildup, and the presence of conductive objects such as tall buildings or trees that can act as lightning rods.
4. Can lightning strikes be predicted?
While scientists have made advancements in predicting weather patterns that may lead to thunderstorms, predicting the exact location and time of a lightning strike is still a difficult task. Lightning strikes are highly unpredictable and can occur in unexpected locations.
5. What type of power is involved in a lightning strike?
A lightning strike involves a massive amount of electrical power, typically in the range of 100 million to 1 billion volts. This high voltage results in a surge of electrical current, which can cause damage to structures and electronic devices.
