- #36
PeterDonis
Mentor
- 45,639
- 22,659
Heikki Tuuri said:That is, the rock does not have time to adjust to the changed distances.
The light which is used to measure the distance, on the other hand, does adjust very quickly. We are able to measure the new distance with the light.
That doesn't mean the light "adjusts" to the changed distance. It means the distance changed, and the light, which didn't change, tells us the distance changed.
The rock also tells us the distance changed, but in a different way: by the change in its internal stresses. But that's much, much harder to measure given the tiny changes involved. That's why Weber-style bar detectors for gravitational waves, which operate on the same principle--sensing the changes in internal stresses in a large solid object caused by GWs--never got to the point that LIGO has reached.
Heikki Tuuri said:If the frequency of the gravitational wave would be very slow, then the stress in the rock would eventually bring the ends of the arm to the same distance as they were before the gravitational wave.
Not if the rock remains solid; then its length would change much less than the length between the sensor and end-of-arm mirrors in LIGO, which can move independently of each other. The atoms of the rock can't because they are bound by internal forces; so the effect of the GW shows up in the rock mostly as a change in internal stresses, rather than a change in externally measured length. There will be some small change in overall length, but again, much less than the length changes in the arms that LIGO measures.
Heikki Tuuri said:Then you would no longer notice any changed spatial geometry.
Yes, you would, because the internal stresses in the rock will have changed. See above.
