Uncovering the Truth Behind LIGO's Gravity Wave Detection: A Critical Analysis
In summary, the conversation discusses an article from Forbes questioning the validity of LIGO's gravity wave detection, and a response from a Danish group claiming that the detection may have been an artifact. The article's author, Sabine Hossenfelder, is knowledgeable in the field but the LIGO collaboration scientists disagree with the methods used by the Danish group. Lubos Motl, a string theorist, dissects the Danish paper and concludes that it is entirely wrong, but the findings have not been formally responded to by the LIGO collaboration. The conversation also mentions the use of blind injections as a way to check the validity of the detection.
  • #71
mfb said:
the seismic sensors detect it and it doesn't enter data analysis.
Question here is were/how to draw the line?
First you mention that the other signals are not strong enough, but it turns out other (strong) signals are not accepted.
  • #72
The sensitivity depends on that line, but in the worst case you miss a signal - you don't get a significant signal where there is no signal.
You are mixing two completely different analysis steps.
  • #73
OK. I guess the article is a bit misleading when they write: 'a jackhammer going off in the town near one detector won’t show up as noise in the other'. It gave me the impression that the drill showed up at least in the noise of that one detector.
So there are 2 (or more) separate levels of noise, how many filters are there?
BTW I took an other look at this remark:
mfb said:
Their claim that you should see exactly (?) zero correlation in the residuals is one of the worst ones.
Their claim seems to be rather that the GW signal is small compared to the overall noise, and that it's difficult to get a signal so different from a GW waveform noise correlation. They even allowed 10% leeway for the templates and it change nothing for the correlation.
  • #74
LIGO published a lot how exactly they analyze their data.
The GW signal is huge compared to the residuals where the Danish group is looking for correlations. Even tiny differences between fitted template and the gravitational wave will lead to large correlations in the residuals.
10% in what? The template is not a one-dimensional number.
LIGO checked all this, as every good scientific analysis does.
The Danish group did not. Or if they did, they didn't discuss the results, which would be even worse.
  • #76
That's my point. The amplitude is not everything.
  • #77
Ok, one last thing that kept hanging in my mind was this comment in the Quantamagazine article about the raw data:
“The only persons qualified to analyze this paper are in the LIGO Scientific Collaboration,” said https://physics.stanford.edu/people/faculty/robert-wagoner, a theoretical physicist at Stanford University who is not affiliated with LIGO. “They are the only ones who have had access to the raw data.”
And this related to your comment on the seismic sensors that filter out the vibrations of a drill:
Does this mean that some signals like that of the drill nearby aren't in the provided raw data on the LIGO website? Or are those sensors automatically filtering out seismic vibrations with a kind of mechanical damping detector?
  • #78
If the seismic sensors detect some activity, the measurements in this time period are not used to search for gravitational waves. I guess the raw data provided by LIGO is only from times where no seismic activity was detected.
  • #79
mfb said:
They make a lot of claims.
Their claim that you should see exactly (?) zero correlation in the residuals is one of the worst ones. You only expect this if the template matches exactly. No one expects that, and LIGO explored possible deviations. Again something the Danish authors seem to ignore.
And random fluctuations. Not every non-zero correlation is directly something interesting. You expect a lot of non-zero correlation events in noise just by random chance. They will all have small amplitudes. Did I mention that you have to look at the amplitude?
The problem is not that there are (or seem to be) non-zero correlations, the problem is that the non-zero cross-correlations which are seen are extremised and close to |1| nearly exactly for the delay times between detectors for GW signals, i.e. for 7 ms, 1 ms and -3 ms for respectively the first, second and third GW signals.
These exact same correlations are also found using null output sets, which are null input sets made by subtracting the unfiltered theoretical GW templates from the raw data sets and subsequently cleaning these input sets per LIGO's cleaning prescriptions.
Their claim is neither that you should see zero correlation nor that the GW signal is small compared to the actual noise. Their claim is instead:
Creswell et al. said:
While our findings do not contradict the previous statement about near Gaussianity during the time of the events, this is to be contrasted with the present demonstration that the residuals show apparent correlations between the detectors. It is striking that these correlations are maximized by applying nearly the same time shifts as found for the GW events themselves — for all three GW events reported to date. The purpose in having two independent detectors is precisely to ensure that, after sufficient cleaning, the only genuine correlations between them will be due to gravitational wave effects. The results presented here suggest this level of cleaning has not yet been obtained and that the detection of the GW events needs to be re-evaluated with more careful consideration of noise properties.
  • #80
That is exactly what you expect if the templates are not perfect.
  • #81
Why exactly?
  • #82
Every deviation between GW and template will lead to correlated residuals, with the same time delay as the GW and the template.
No one expects that the template fits perfectly, so yes, what the authors observe here is expected to some extent. I don't understand what all the noise is about (scnr).
Likes haushofer, vanhees71 and Auto-Didact
  • #83
Would such correlations be expected as well in raw or cleaned data sets of both detectors which do not contain any GW signals?
And can you elaborate on the phase correlations mentioned here:
The cleaned data should contain signal and residual noise. Although the strength of the signal and noise are comparable during the 0.2 s of the GW150914 event, noise is completely dominant for the remainder of this 32 s record. In other words, the Fourier amplitudes shown here are noise dominated. Since random noise would have a uniform distribution of phases, it is evident that the noise is neither stochastic nor even roughly stochastic. We also note that plots of the phases of the 4096 s data show similar correlations. Such correlations can either be numerical artifacts or a genuine consequence of the physically meaningful coupling of nearby frequencies. We point out the rather surprising fact that the phase correlations in the Livingston detector (middle row in Fig. 3), already present in the raw data, are significantly increased by the cleaning procedure. This suggests that their origin may be physical. Whatever its origin, the non-stochastic behavior indicated by phase correlations in the supposedly clean data immediately presents an a priori challenge to the reliability of any significance estimates of possible GW events.
  • #84
As random fluctuations, sure, but not beyond that. And that's what the Danish authors find. A strong correlation within the signal, a very weak correlation outside.
I think the blog article linked earlier covers that.
  • #85
During the visit at LIGO Lousiana quite recently (organized by the german Journal "Bild der Wissenschaft" for our group) there was the opportunity to ask the scientist who spoke to us how LIGO would respond to the Danish group (primary source mentioned in #4). He said that there isn't any correlation, if one looks at the whole noise signal, which wasn't shown in the LIGO publication and that this was stated already in response to the paper of the Danish group. I'm not sure however if he meant the article of one of the LIGO postdocs mentioned in #21 or an official answer of LIGO which I'm not aware of.
  • #86
There's a new signal detected now along with VIRGO in Italy:
https://dcc.ligo.org/LIGO-P170814/public/main
It keeps on being a bit weird, in the SRN graphs they look very different and in the Whitened Strain* they suddenly look the same.
*The whitening emphasizes different frequency bands for each detector, which is why the reconstructed waveform amplitude evolution looks different in each column.
  • #87
The SNR plots have a single peak for all three detectors, as you would expect for a single event. It is an integrated SNR.
I wonder what the Danish group will do now. Admitting that the LIGO analysis method is sound? I doubt it.
  • #88
Again they show just a very small sample, and have probably used templates to get the match for the withened strain, the peaks in the SRN are still very different.
I'd like to see what a 30 sec. stretch looks like.
Also how fast is the Earth moving (turning) in relation to the signal and how much does the angle changes of the location in Italy vs. those in the US over that period?
  • #89
The Earth is 12,800km in diameter. Maximum possible delay between reception is therefore a little over 0.04s (for a lightspeed signal). That works out to about 0.64 seconds of arc as an upper bound on angle change.
  • #90
Yes, but we are also moving at 627 km/s relative to the CMB. So how much would the signal be skewed?
  • #91
Skewed in what sense? I think that the difference between Earth-centred and FLRW co-moving coordinates on the scales LIGO cares about is just a Lorentz transform, although I could be being overconfident there.
  • #92
That one detector runs into the wave head on and the other sideways.
  • #93
That is just a relative motion of the source and the detectors. It has nothing to do with the CMB. And it is negligible at the current level of sensitivity. Redshift is relevant (~10%).
Of course they used templates. That's the analysis method.
The peaks in the SNR are not expected to be the same. The different detectors have different sensitivities and they have different orientations.
You are trying to make up issues that don't exist.
  • #94
Unless there's some reason you can't use standard aberration formulae, failing to distinguish between the Earth-centred inertial frame and the local FLRW co-moving frame will knock your angle estimates off by about 1/500 of a radian, or around a tenth of a degree (so says the back of an envelope).
I find it difficult to imagine people capable of planning on generating gravitational wave solutions for different source types forgetting about the possibility that the sources are in motion.
  • #95
Of course it has got nothing to do with the CMB itself, but the CMB acts like a reference frame.
The detectors could be moving away or running into the GW, or be hit from the side, skewing the signal. So it all depends on running into the wave at a particular time of day (orientation), a few hours later and we wouldn't notice a thing if the signal is perpendicular.
  • #96
Imagine having a flag to define where the wind comes from, now start waving that flag around, and things become a lot more complicated.
  • #97
Yes, but is that a good analogy for this observational setup? If the flag were planted on a glacier, you wouldn't worry so much that the glacier's movement might mess up your measurements of wind speed and direction.
So do the calculation. What is an upper bound on the error introduced from the relative motion between different points on the surface of the rotating and orbiting earth? Can this effect be large enough toffee to the validity of the reported results?
Likes glappkaeft
  • #98
Nugatory said:
Yes, but is that a good analogy for this observational setup? If the flag were planted on a glacier …
No, it's not perfect. A flag has many 'points' that serve as a reference to define direction etc. LIGO and Virgo combined only 3.
  • #99
Yes, so we have an example of why we do science with math instead of analogies.
Until you've quantitatively demonstrated an upper bound on the possible error produced because we only have three points and they are in relative motion you're just speculating idly.
Likes Ibix
  • #100
I don't consider that to be how confidence works in science if we apply the maxim that extraordinary claims require extraordinary evidence.
I tend to put the burden of proof that potential sources of error are smaller than their error bars on those publishing or defending extraordinary new experimental claims rather than on skeptics suggesting potential sources of error.
Likes Auto-Didact and RockyMarciano
  • #101
The problem is that many times the skeptics aren't bound by any burden of proof. Often the skeptic is ill informed (and possibly has their own agenda) and makes disparaging, derisive claims that add nothing and only cast doubt. The baseless claims receive unwarranted attention and must be defended. Much of this discussion seems to follow that model.
Likes weirdoguy
  • #102
True, but one presumes that a skeptic has some kind of response to "why on Earth would you think that's a relevant factor", which is all I think @Nugatory is asking. I don't think that it's unreasonable to ask a skeptic to provide some kind of order-of-magnitude calculation showing that the effect they're worried about is somewhere near a range that might affect the results. I can't even see why a linear speed relative to the CMB frame would be relevant unless the LIGO people were unaware that astronomical bodies move relative to the Earth, which seems slightly unlikely.
  • #103
Well if Redshift is relevant how much did the GW redshifted over time and loose energy?
For Galaxies moving away we can keep track about what's going on, the Hubble constant, but a GW is just one short single pulse.
Sure, we can know if it comes from one side or the other, 1 dimensional, but we know nothing about the 2nd dimension.
An other issue is how symmetric is the Gravity Wave, two spiralling-colliding objects are not 100% spherical.
Lots of unknowns!
  • #104
That's how democracy works, people get to ask questions. The duty of the opposition is to oppose. :wink:
  • #105
Science is not a democracy.
Likes vanhees71, m4r35n357, weirdoguy and 1 other person
  • Astronomy and Astrophysics
  • Beyond the Standard Models
