Proving $\lim_{n\to\infty}a_n^2 = a^2$ with Delta-Epsilon
  • MHB
  • Thread starter Dustinsfl
In summary, we are trying to prove that if $\lim\limits_{n\to\infty}a_n = a$, then $\lim\limits_{n\to\infty}a_n^2 = a^2$. Using the delta-epsilon definition, we can show that for any given epsilon, we can find an $N$ such that for all $n > N$, $|a_n - a| < \epsilon$. By manipulating the expression $|a_n^2 - a^2| = |(a_n - a)(a_n + a)|$, we can show that it is also less than $\epsilon$. This is because $|a_n + a|$ can be bounded by $2
Dustinsfl
2,281
Suppose $\lim\limits_{n\to\infty}a_n = a$. Prove using the delta-epsilon definition that $\lim\limits_{n\to\infty}a_n^2 = a^2$.
Let $\epsilon > 0$ be given. Let $N\in\mathbb{Z}$. Then for $n > N$, $|a_n - a| < \epsilon$.
Then
|a_n^2 - a^2| = |(a_n - a)(a_n + a)| < \epsilon |a_n + a|
I am stuck here.
I think you can argue as follows: consider
$$|a_n +a| = |a_n - a + 2a| \leq |a_n -a| + 2|a| < \varepsilon + 2|a|.$$
The result is trivial if $a =0$, therefore it's safe to assume $a \neq 0$.
Since $\varepsilon$ is arbitrary, you could say that $|a_n +a| \leq 2 |a|$.
Thus, take $N_0 \in \mathbb{N}$ such that for all $n \geq N_0$ we have $|a_n -a| < \frac{\varepsilon}{2 |a|}$.
It follows that for all $n \geq N_0$ we have
$$|a_n^2 -a^2| = |(a_n -a)(a_n +a)| \leq |(a_n -a)| \cdot 2 |a| < \frac{\varepsilon}{2 |a|} \cdot 2 |a| = \varepsilon.$$
Again, not entirely sure. Hope it helps, at least. :D
Then
I am stuck here.
Let's suppose to have two sequences $a_{n}$ and $b_{n}$ and that $\displaystyle \lim_{n \rightarrow \infty} a_{n}=a$ and $\displaystyle \lim_{n \rightarrow \infty} b_{n}=b$. That means that...
$\lim_{n \rightarrow \infty} (a_{n}-a)=\lim_{n \rightarrow \infty} (b_{n}-b)=0$ (1)
... and therefore, given a $\varepsilon>0$, it exists an $N$ for which $\forall n>N$ is...
$\displaystyle |(a_{n}-a)-0|< \sqrt{\varepsilon}$
$\displaystyle |(b_{n}-b)-0|< \sqrt{\varepsilon}$ (2)... and then multiplying the (2) toghether...
$|(a_{n}-a)\ (b_{n}-b)-0|=|a_{n}-a|\ |b_{n}-b| < \varepsilon \implies \lim_{n \rightarrow \infty} (a_{n}-a)\ (b_{n}-b)=0$ (3)
Now we use (3) and the identity...
$\displaystyle a_{n}\ b_{n}= (a_{n}-a)\ (b_{n}-b) + b\ a_{n} + a\ b_{n} - a\ b $ (4)
... to obtain... $\displaystyle \lim_{n \rightarrow \infty} a_{n}\ b_{n} = \lim_{n \rightarrow \infty} (a_{n}-a)\ (b_{n}-b) + \lim_{n \rightarrow \infty} b\ a_{n} + \lim_{n \rightarrow \infty} a\ b_{n} - \lim_{n \rightarrow \infty} a\ b = b\ a + a\ b - a\ b = a\ b$ (5)
In other word the limit of the product is the product of limits. In the particular case $b_{n}=a_{n}$ You have $\displaystyle \lim_{n \rightarrow \infty} a^{2}_{n}= a^{2}$... Kind regards $\chi$ $\sigma$
Line (4) should be $+ab$. We would need a $-ab$ though which we don't have since we have a negative times a negative.
Why don't develop the expression...
$\displaystyle (a_{n}-a)\ (b_{n}-b) + a\ b_{n} + b\ a_{n} -a\ b$ (1)
... and observe what is the result?...
Kind regards
$\chi$ $\sigma$
What does the Delta-Epsilon definition of a limit mean?
The Delta-Epsilon definition of a limit is a mathematical concept used to formally prove the existence of a limit. It states that for a given function f(x) and a limit L, there exists a positive number ε (epsilon) such that for all values of x within a certain distance δ (delta) of the limit, the corresponding values of f(x) are within ε of L.
How is the Delta-Epsilon definition used to prove $\lim_{n\to\infty}a_n^2 = a^2$?
In order to prove $\lim_{n\to\infty}a_n^2 = a^2$, we must show that for any given ε, there exists a corresponding δ such that for all n greater than some value N, the difference between $a_n^2$ and $a^2$ is less than ε. This can be done by manipulating the Delta-Epsilon definition and using algebraic techniques to find a suitable δ in terms of ε and N.
What are the key steps in proving $\lim_{n\to\infty}a_n^2 = a^2$ with Delta-Epsilon?
The key steps in proving $\lim_{n\to\infty}a_n^2 = a^2$ with Delta-Epsilon are as follows:
  1. Start by writing out the Delta-Epsilon definition for the limit.
  2. Manipulate the definition to isolate $a_n^2$ on one side.
  3. Use algebraic techniques to find a suitable δ in terms of ε and N.
  4. Choose a specific value for δ that satisfies the conditions of the definition.
  5. Show that for all n greater than N, the difference between $a_n^2$ and $a^2$ is less than ε.
What are some common mistakes to avoid when using Delta-Epsilon to prove $\lim_{n\to\infty}a_n^2 = a^2$?
Some common mistakes to avoid when using Delta-Epsilon to prove $\lim_{n\to\infty}a_n^2 = a^2$ include:
  • Assuming that a suitable δ can be found for any given ε, without considering the specific properties of the function.
  • Incorrectly manipulating the Delta-Epsilon definition, leading to an incorrect δ value.
  • Using algebraic techniques that are not appropriate for the given function.
  • Not being careful with the choice of N, which can affect the validity of the proof.
How does proving $\lim_{n\to\infty}a_n^2 = a^2$ with Delta-Epsilon relate to the concept of convergence?
The Delta-Epsilon definition of a limit is closely related to the concept of convergence. In order to prove that a limit exists, we must show that the values of the function converge to a specific value as n approaches infinity. Therefore, proving $\lim_{n\to\infty}a_n^2 = a^2$ with Delta-Epsilon is a way of proving that the sequence of values $a_n^2$ converges to $a^2$ as n approaches infinity.
  • Topology and Analysis
