Finding the Limit of a Fraction with Square Roots | Calculus Homework Help
  • Thread starter Дьявол
  • Tags
    Function
I didn't get it. :smile:@tiny-timHow do you got equal (cosθ/2 - cos45º) = sin(θ/4 + 22.5º) sin(θ/4 - 22.5º)...I didn't get it. :smile:well, I did say it wasn't pretty! :redface: it's the product-to-sum formula: sin A sin B = (1/2)(cos(A - B) - cos(A + B)) :smile:well, I did say it wasn't pretty! :redface: it's the product-to-sum formula: sin A sin B = (1/2)(cos
Дьявол
365
Find [tex]\lim_{x \rightarrow 0}=\frac{\sqrt{x+a^2}-a}{\sqrt{x+b^2}-b}[/tex]
[tex]\lim_{x \rightarrow 0}=\frac{\sqrt{x+a^2}-a}{\sqrt{x+b^2}-b}=\lim_{x \rightarrow 0}=\frac{\sqrt{x+a^2}-a}{\sqrt{x+b^2}-b}*\frac{\sqrt{x+b^2}+b}{\sqrt{x+b^2}+b}=\lim_{x \rightarrow 0}=\frac{(\sqrt{x+a^2}-a)(\sqrt{x+b^2}+b)}{x}[/tex]
On the next step I divided by x, but again nothing.
I tried several different methods by substituting [itex]y=\sqrt{x+a^2}[/itex] and [itex]z=\sqrt{x+b^2}[/itex] but useless. Please help! Thanks in advance.
Hi Дьявол! :smile:
If you're allowed to, use l'Hôpital's rule …
if you're not, use a Taylor expansion. :wink:
@tiny-tim I have never used both of them. Aren't there any elementary transformations?
ok … here's a trick …
whenever I see a √ sign, I think :rolleyes: of using a trig substitution, so …
define θ and φ by x = asinθ = bsinφ, and let θ and φ tend to zero, and use standard trigonometric identities …
what do you get? :smile:
Maybe, that is nice trick. If θ and φ tend to 0 then asin0 and bsin0 tend to 0 so that x tend to 0.
But after substituting I get the things messed up :smile:
Should I try like this:
[tex]\frac{\sqrt{asin(\theta)+a^2}-a}{\frac{\sqrt{asin(\theta)+\frac{a^2sin^2\theta}{sin^2(\varphi)}}}{-\frac{asin(\theta)}{sin(\varphi)}}[/tex]
or maybe:
[tex]\frac{\sqrt{asin(\theta)+a^2}-a}{\sqrt{bsin(\varphi)+b^2}-b}[/tex]
oops!
Sorry … I couldn't read my own handwriting :redface:
I should have said x = a2tan2θ = b2tan2φ …
or even better x = a2cosθ = b2cosφ, with θ and φ -> π/2 :smile:
Maybe it is better if we use x = -a2cosθ = -b2cosφ (it is the same thing), and I get:
[tex]\frac{asin^2(\theta)-a}{bsin^2(\varphi)-b}[/tex]
for θ and φ -> π/2
but I can't do anything out of here, or I can (circular movement) :smile:
If I do like this:
-a(1-sin2θ/-b(1-sin2φ)=acos2θ/bcos2φ=0/0 :smile:
for θ and φ -> π/2
No, you get (a/b)√(1 - cosθ)/√(1 - cosφ) :smile:
Well, this is all getting very complicated. It's better to learn a more universal method.
The point is, what can we use to approximate [itex]\sqrt{x+a^2}[/itex] when [itex]x[/itex] is small?
In general, answering this sort of question involves using a Taylor expansion,
[tex]f(x)=f(0)+f'(0)x+{\textstyle{1\over2}}f''(0)x^2+\ldots[/tex]
Typically only the first two terms are needed for a limit problem.
In the case of interest, [itex]f(x)=(x+a^2)^{1/2}[/itex], and so [itex]f'(x)=\frac12 (x+a^2)^{-1/2}[/itex]. Thus we have [itex]f(0)=a[/itex] and [itex]f'(0)=1/(2a)[/itex], and so [itex]\sqrt{x+a^2}\simeq a + x/(2a)[/itex] when [itex]x[/itex] is small.
Here's an alternative method for this particular problem that doesn't use Taylor expansions. Multiply the original expression by
[tex]\Biggl(\frac{\sqrt{x+a^2}+a}{2a}\Biggr)\Biggl(\frac{2b}{\sqrt{x+b^2}+b}\Biggr)[/tex]
which has a limit of 1 as [itex]x\to0[/itex].
ooh, that's much better!
nice one, Avodyne! :smile:
@Avodyne
That's great. I didn't think that I could use something like that, but that's obviously lim1=1; so again I can use it in my particular problem. Thanks a lot.
@tiny-tim
Thanks for the replies. But let's solve it also on your way of thinking.
If x = a2cosθ = b2cosφ, with θ and φ -> π/2
then in the original equation:
√(a2cosθ+a2)-a/ √(b2cosφ+b2)-b=
=a√(1+cosθ)-a/ b√(1+cosφ)-b =a(√(1+cosθ)-1)/b(√(1+cosφ)-1)
What could I do know? Again stuck.
Using Avodyne's method I got b/a which is actual correct, but also I found your way very good and I would like to solve it. Thanks again.
Дьявол said:
@Avodyne
@tiny-tim
Well. it's not pretty :blushing:
= a((√2)cosθ/2 - 1)/b((√2)cosφ/2 - 1)
= a(cosθ/2 - 1/√2)/b((cosφ/2 - 1/√2)
= a(cosθ/2 - cos45º)/b((cosφ/2 - cos45º)
= a sin(θ/4 + 22.5º) sin(θ/4 - 22.5º) / b sin(φ/4 + 22.5º) sin(φ/4 - 22.5º)
~ a (θ/4 + 22.5º) (θ/4 - 22.5º) / b (φ/4 + 22.5º) (φ/4 - 22.5º)
= a (θ + 90º) (θ - 90º) / b (φ + 90º) (φ - 90º);
using (θ + 90º)/(φ + 90º) ~ 180º/180º = 1
and b2/a2 = cosθ/cosφ = sin(θ - 90º)/sin(φ - 90º) ~ (θ - 90º)/(φ - 90º),​
~ (a/b)(b2/a2) = b/a :redface: :redface:
:smile:
How do you got equal (cosθ/2 - cos45º) = sin(θ/4 + 22.5º) sin(θ/4 - 22.5º) ?
Дьявол said:
:smile:
Standard trig formula: cosA - cosB = 2 sin(A+B)/2 sin(A-B)/2 …
work it out! :wink:
There's another approach that I didn't see in this thread, that's much simpler than most of the approaches that were suggested:
Multiply the original expression by 1, in the form of
[tex]\frac{\sqrt{x + a^2} + a}{\sqrt{x + b^2} + b} * \frac{\sqrt{x + b^2} + b}{\sqrt{x + a^2} + a}[/tex]
This makes the limit very easy to evaluate, which when simplified, is b/a.
Hi Mark! :smile:
Yes, that's nice …
but Avodyne beat you to it in post #10,
and his version was neater 'cos it had less square-roots! :wink:
Sorry for asking, but where the sine gone here?
tiny-tim said:
Hi Mark! :smile:
Yes, that's nice …
I noticed Avodyne's approach and thought that mine was similar to his (hers?), but still different. Avodyne multiplied by something that is 1 in the limit. I mulitplied by something that is 1 (taking domain into account).
Magic! :biggrin:
hmm … on reflection :redface:, I can only magic away the minus brackets … I have to treat the plus brackets separately …
sin(θ/4 + 22.5º) / sin(φ/4 + 22.5º) ~ sin45º / sin45º = 1,
and
sin(θ/4 - 22.5º) / sin(φ/4 - 22.5º) ~ (θ/4 - 22.5º) / (φ/4 - 22.5º)
because as θ -> 90º, (θ/4 - 22.5º) -> 0, and sinx ~ x as x -> 0 :smile:
ah, yes, but that's what I prefer about his method … it's more compact! :wink:
Haha. Ok, now I understood :smile:
You must have worked out for about 20 years with Maths to know all this stuff. It is pretty complicated. Also Mark44's way is great. All of you are great! :smile:
Anyway, I still can't figure how somebody find out the formula for cosA-cosB or some of the other sum-to-product identities.
If P = A+B/2 and Q = A-B/2, then A = P+Q/2 and B = P-Q/2 …
so write cosA - cosB in terms of P and Q, and use the usual trig formula (same method works for cosA + cosB, and for sinA ± sinB)
anyway, you should learn all these formulas!
1. What is the definition of a limit in calculus?
A limit in calculus is the value that a function or sequence approaches as the input or index approaches a certain value. It is used to describe the behavior of a function near a specific point.
2. How do you find the limit of a fraction with square roots?
To find the limit of a fraction with square roots, you can use the rationalizing technique. This involves multiplying both the numerator and denominator of the fraction by the conjugate of the denominator. Then, you can simplify the resulting expression and evaluate the limit as the input approaches the given value.
3. Can you find the limit of a fraction with square roots without using the rationalizing technique?
Yes, it is possible to find the limit of a fraction with square roots without using the rationalizing technique. This can be done by simplifying the expression using algebraic techniques, such as factoring or canceling out common factors. However, the rationalizing technique is often the most efficient method for finding the limit.
4. What are the common mistakes to avoid when finding the limit of a fraction with square roots?
One common mistake to avoid is forgetting to use the conjugate when rationalizing the fraction. It is also important to check for any algebraic mistakes, such as incorrect factoring or canceling out terms incorrectly. Additionally, be sure to check for any potential undefined values, such as dividing by zero.
5. How can finding the limit of a fraction with square roots be applied in real-world situations?
Finding the limit of a fraction with square roots can be useful in various real-world applications, such as engineering and physics. For example, it can be used to determine the maximum height of an object thrown into the air, or the maximum speed of a falling object. It can also be used in financial calculations, such as finding the maximum profit or minimum cost for a given situation.
